How to use mouse buttons in VS Code on a Mac
VS Code already treats the side buttons as back and forward, and the built-in way to do that on a Mac is a setting, not a mapper. The jobs a mapper adds are run, build, stop and the debugger steps, which are keys on a button. InputConfig, the free Mac app I make, scans any mouse button and sends a key or a whole shortcut, and it can follow VS Code as the front app. This app is completely free, and you do not have to make an account.
The keys come from Microsoft's macOS keyboard shortcuts sheet, the debugging page and the tasks page, which I read on October 21, 2026. A Xcode section further down uses Apple's own list.
On this page: 11 sections
  1. What VS Code and macOS give a mouse
  2. Find out what each button sends
  3. The Command bracket trap
  4. Put run, build and the debugger on the buttons
    1. Step 1: Scan and give it Run
    2. Step 2: Add build and stop
  5. Macros and multi-step jobs
  6. Hold, repeat, tap twice and switch by app
  7. Xcode on a Mac
  8. If a button does nothing in VS Code
  9. What it cannot do
  10. The short version
  11. Questions
VS Code has a setting, workbench.editor.mouseBackForwardToNavigate, described in its source as enabling mouse buttons four and five for the commands Go Back and Go Forward, and its default is on. That is from VS Code's source on GitHub, which I read on October 21, 2026. A mouse whose side buttons report as Button 4 and Button 5 should therefore navigate with no help.
The keyboard equivalents are Control minus for Go Back and Control Shift minus for Go Forward, from Microsoft's sheet. If your side buttons already navigate in VS Code, leave them alone, and use the mapper for the buttons that do nothing.
A mouse button reaches the Mac as Left click, Right click, Middle click or Button 4 and up. Press Scan, then click the button. If Scan names a key instead of a mouse button, the mouse is sending a key, and the fix is on F13 to F19 on a Mac.
ButtonHow it usually reportsA good VS Code job
Left click and right clickLeft click and Right clickLeave them. They cannot be blocked.
Wheel pressMiddle clickClose editor, Command W, or Go to Definition, F12.
Side buttonsButton 4 and Button 5Back and forward, which VS Code may already do.
Thumb grid or extra buttonsButton 6 and higherRun, Stop, Step over, Step into, Build.
Tilt wheelSideways scrollPrevious and next editor tab.
DPI or profile buttonOften nothing the Mac can readNothing. If Scan hears no press, no app can read it.
InputConfig has a built-in preset that puts back and forward on the side buttons by sending Command left bracket and Command right bracket, which browsers and the Finder understand. In VS Code, Microsoft's sheet lists the same two keys as indent and outdent line. If that preset runs while VS Code is in front, a side button press edits your code.
InputConfig's editor with a Mouse device and two rows: Button 4 sends Command and the left bracket key, and Button 5 sends Command and the right bracket key.
Figure 1. The back and forward layout, with Button 4 sending Command and the left bracket and Button 5 sending Command and the right bracket. Those two keys are right for browsers and wrong for VS Code, where they indent and outdent lines.
  • Option one. Leave the side buttons to VS Code's own setting, and keep this preset for other apps.
  • Option two. Make a VS Code preset that sends Control minus and Control Shift minus on the same buttons, and list VS Code under Activate when these apps are in front.
  • Option three. Tick Block the button's own action on the rows if both VS Code and the preset act, so back does not happen twice.
Only one preset runs at a time, so a VS Code preset and the back and forward preset need their own app lists. The same two buttons should send different keys in different apps, and that is what per-app presets are for.
  • You: Add a row, set the device to This Mac's mouse or trackpad, the input to Mouse and the kind to Button, then press Scan and click a thumb button. Set the output to Keyboard Key and pick F5.
  • InputConfig: Presses F5 each time you press the button.
  • Check: Open a project with a launch setup and press the button. The debugger starts, or continues if it is already running.
  • You: On the next button, set the output to Keyboard Key, pick Shift and Command under Modifier Keys, and add B. On another, Shift and F5.
  • InputConfig: Presses Shift Command B, which Run Build Task uses, and Shift F5, which stops debugging.
  • Check: Press build and the task picker or the default task runs. Press stop and the debugger ends.
JobVS Code key on a MacGood home
Go Back and Go ForwardControl minus and Control Shift minusButton 4 and Button 5
Start or continue debuggingF5A thumb button
Stop debuggingShift F5A hold on that button
Restart debuggingShift Command F5A second hold
Run Build TaskShift Command BA thumb button
Step over, into, outF10, F11 and Shift F11Three thumb buttons
Toggle breakpointF9A thumb button
Go to Definition and Peek DefinitionF12 and Option F12Wheel press and a hold
Quick Open and Command PaletteCommand P and Shift Command PTwo thumb buttons
Show integrated terminalControl backtickA thumb button
Close editorCommand WWheel press
VS Code's debug page lists F5 as continue or pause, and Shift F5 as stop. Run Build Task is Shift Command B on the tasks page.
A macro is a row with Run a sequence of steps ticked, and each step is a key, a shortcut or a click with its own wait. Three that suit code:
  • Save, then build. Command S, a short wait, then Shift Command B. It saves the file you are on and starts the build.
  • Stop and start again. Shift F5, a wait of a second, then F5. A rerun on one button.
  • Terminal at hand. Control backtick shows the integrated terminal, then a Type Text output can type a command you run all day. I would leave the Return off, so you check it first.
InputConfig's macro editor with Run a sequence of steps ticked and numbered steps that hold Command, tap a letter, release Command and wait between steps.
Figure 2. A macro's numbered steps, each holding, tapping or releasing a key with a wait between. A VS Code macro has the same shape, with Command S and Shift Command B as the steps.
I have not run these in VS Code myself, and a macro that stops and starts a debugger is worth a test run first. Keep Return out of any typed command, so a stray press cannot run it.
  • A tap and a hold. F5 on the tap and Shift F5 on the hold, so one button starts and stops. A quick tap sends the normal output, and holding past a time you set sends something else.
  • Repeat keys while held. For stepping with F10, this keeps stepping while the button is held. Leave it off for build.
  • Block the button's own action. Available for the middle button and the side buttons, so an app stops seeing them while the preset runs.
An InputConfig row whose Options show Different action when held, with Holding past 400 ms sending Command Shift S while a quick tap sends Command S.
Figure 3. The hold action. The example sends Command S on a tap and Command Shift S after 400 milliseconds. A VS Code layout would send F5 on the tap and Shift F5 on the hold.
To keep the layout in VS Code, open the preset's Automation & Gaming Utilities section, add Visual Studio Code under Activate when these apps are in front, and in Settings, Advanced, turn on Switch presets when the front app changes. The emergency stop is Control Option Command period.
Xcode on a Mac
Xcode is the same idea with different keys. Apple's archived table lists them in Apple's archived Xcode menu command shortcuts, which I read on October 21, 2026. It describes an older Xcode, so open the Product and Navigate menus in your version, where each command shows its current key.
JobXcode key from Apple's tableGood home
Go Back and Go ForwardControl Command Left Arrow and Control Command Right ArrowButton 4 and Button 5
RunCommand RA thumb button
BuildCommand BA thumb button
StopCommand periodA hold on Run
Open QuicklyShift Command OWheel press
CleanShift Command KA hold on Build
Give Xcode its own preset, and list it under Activate when these apps are in front. Scan the buttons, bind the keys from your Xcode menus, and Xcode never sees the VS Code keys. Run and Stop on a hold of one button is the simplest way to drive either editor.
  1. Check the preset is on. Click Activate, and make sure VS Code is the app the preset follows.
  2. Check Accessibility. In System Settings, Privacy & Security, Accessibility.
  3. Check for a double action. If back goes twice, VS Code's own setting and your row are both acting. Tick Block the button's own action.
  4. Check the function keys. F5 and F10 may need the Fn key on a laptop. Set the keyboard's function keys as standard in System Settings, Keyboard, or send the key from the row, which does not depend on that.
  5. Check the Scan. If the button scans as a key, set it to F13 to F20 in the maker's software first.
  6. Quit the maker's software. Logi Options+ and similar apps can take a button over.
What it cannot do
  • Read your code. InputConfig sends keys, clicks and scrolls. It cannot know which file or debugger state you are in.
  • Tell two mice apart. Every mouse connected counts as one device.
  • Change pointer speed. Use the Mac's settings, the maker's app, or LinearMouse, Mac Mouse Fix or SteerMouse.
  • Run only in one project. A preset follows the app in front, not the folder or workspace.
  • Check the setting first. VS Code can navigate with Button 4 and Button 5 by itself.
  • Avoid the bracket keys. Command left and right bracket indent lines in VS Code.
  • Follow the app. VS Code and Xcode each get their own preset.
Run on a tap and stop on a hold, on one thumb button, is the setup I would try first.
Can I use my mouse back and forward buttons in VS Code on a Mac?
Yes. VS Code has a setting for mouse buttons four and five as Go Back and Go Forward, and its source lists it as on by default. The keyboard keys are Control minus and Control Shift minus.
Why does my mouse back button indent lines in VS Code?
A preset is sending Command left bracket or Command right bracket, which VS Code uses to indent and outdent. Use a VS Code preset that sends Control minus instead.
What are the VS Code shortcuts for run and build on a Mac?
F5 starts or continues debugging, Shift F5 stops, and Shift Command B runs the build task.
How do I use a mouse button to run code in VS Code?
Scan the button in InputConfig, set the output to Keyboard Key, and pick F5. Add a hold action for Shift F5 so the same button stops it.
What is the Xcode shortcut to go back on a Mac?
Control Command Left Arrow, and Control Command Right Arrow goes forward, in Apple's table. Check your own Xcode menus, because the table is from an older version.
This page in other languages: العربية, Čeština, Dansk, Deutsch, Español, Suomi, Français, עברית, Magyar, Bahasa Indonesia, Italiano, 日本語, 한국어, Norsk, Nederlands, Polski, Português, Русский, Slovenčina, Svenska, ไทย, Türkçe, Українська, Tiếng Việt, 繁體中文, 简体中文
