The best controller, gamepad and joystick mapper for Mac
The best controller mapper for a Mac is the one that fits your job, and the quick picks below give that answer in one line each. Sixteen apps follow in one table, with price, version and minimum macOS, and a line on what each does well. I make one of them, InputConfig, so the bias is stated up front. Every fact comes from each app's own App Store listing, repository or website. For free options only, see the free controller mapper list.
  1. Quick picks
  2. Every Mac controller mapper
  3. What each one does well
  4. Check what macOS and Steam already do
  5. Understand what a mapper does
  6. Match the tool to the job
  7. Windows tools have no Mac version
  8. How I checked
  9. The short version
  10. Questions
Quick picks
  • Free, open source, nothing locked. InputConfig.
  • One Steam game. Steam Input, which is already installed.
  • Joy-Cons only. JoyKeyMapper, small and free.
  • Scripting and an on-screen keyboard. ControllerKeys, paid, with a trial.
  • An older Mac. JoyMapper from macOS 10.14.4, or Gamepad Mapper on macOS 12 and 13, since InputConfig needs macOS 14.
  • MIDI gear, switches, a tap on the MacBook, or screen regions as inputs. InputConfig. None of the others list these. Tapping the MacBook is the one with a hardware limit: it was tested on M4 MacBooks and did not work on an M1 Pro in our testing; the calibrator's status chip tells you whether yours listens.
Pick by the job first, then by price and the macOS version you run.
AppPriceLatest versionmacOSWhereLicense
InputConfigFree; optional tip jar1.8, Oct 202614.0Mac App Store, GitHubMIT
ControllerKeys14-day trial, then paid2.10.0, Oct 202614.6Own site, HomebrewSource available, non-commercial
Gamepad MapperFree download, in-app purchases1.8, Aug 202412.0Mac App StoreProprietary
JoyMapper5-day trial, then $7.991.22.0, Sep 202610.14.4Mac App StoreProprietary
ConMapperFree; Pro $6.991.7.0, Sep 202614.0Mac App StoreProprietary
RecontrolFree2.1.1, May 202615.6Mac App StoreProprietary
GameController Mapper$7.991.2.5, Feb 202614.6Mac App StoreProprietary
Controlly7-day trial, then $3.991.1.7, Nov 202511.0Mac App StoreProprietary
Joystick Mapper$4.991.2, Nov 201910.9Mac App StoreProprietary
JoyKeyMapperFree1.2.0, Aug 202010.14Mac App Store, GitHubMIT
GamePad Companion$7.993.3.1, Jun 201410.7Mac App Store, page not found on Oct 7, 2026Proprietary
EnjoyableFree1.2, Oct 201410.7Download, CodebergMIT
Controllers (Vivid Machine)Paid; Lite version free2.1.011.3Own site; Lite on the Mac App StoreProprietary
USB OverdriveFree to try, then a paid license5.412.0Own siteProprietary
Karabiner-ElementsFreeContinuousRecent macOSOwn site, GitHubPublic domain (Unlicense)
Steam InputFree inside SteamContinuousAny Steam MacSteamProprietary
Checked on 22 September 2026 against each app's App Store listing, GitHub or Codeberg page, and the maker's own site.
Every app here is good at something. One line each, from its own listing:
  • ControllerKeys. JavaScript scripting, an on-screen swipe keyboard, and OBS integration.
  • Gamepad Mapper. The longest-running App Store option with profiles, and it installs on macOS 12. The free alternative is on the page about a gamepad mapper for Mac.
  • JoyMapper. Stick or motion mouse, the DualSense touchpad, per-app switching, and the widest macOS range, back to 10.14.4.
  • ConMapper. Layers, radial menus, Shortcuts and app launching.
  • Recontrol. A free, focused gamepad-to-keyboard-and-mouse remapper.
  • Controllers. Per-game layouts that switch by app, with a long track record.
  • JoyKeyMapper. Tiny, free and open source, for Nintendo controllers.
  • Karabiner-Elements. The best keyboard customizer on the Mac, for pads that can act as a keyboard.
  • USB Overdrive. A long-running driver for mice, keyboards, trackballs, joysticks and gamepads from almost any vendor, set globally or per app. It does not take over Apple's own mice, trackpads or keyboards.
  • Joystick Mapper. Keys, mouse axes, mouse buttons and the wheel on any button, axis or hat of a Mac-compatible joystick or gamepad.
  • GameController Mapper. A controller as a remote control for the Mac, with mouse simulation, text input and a menu bar mode.
  • GamePad Companion. Any USB HID device as a keyboard or mouse, up to five devices at once. Its Mac App Store page could not be found on October 7, 2026: what happened to GamePad Companion.
  • Enjoyable. Free and open source, with ready mappings for a handful of games, and still the name many people remember.
  • Steam Input. Already installed if you have Steam, and the right tool for one Steam game.
  • InputConfig. Every controller plus MIDI, keyboards, mice, the trackpad, screen regions and a tap on the MacBook as inputs (the tap has a hardware limit, given in the quick picks above); MIDI out; accessibility features such as one-stick driving and spoken feedback; 450+ ready layouts; nothing locked.
Before installing anything, know where the built-in tools stop:
  • System Settings, Game Controllers. Remaps a controller's buttons to other controller buttons, inside games that already support controllers. It cannot send keys or move the mouse.
  • Steam Input. Maps a controller to keys, but only for Steam games.
Everything outside those two, from a keyboard-only game to the Finder, needs a mapper. More on what macOS can do on its own.
A controller mapper, also called a gamepad mapper, joystick mapper or input mapper, sits between a device and the Mac. It reads a button, a stick or a trigger and sends something every app already understands: a key press, a mouse click, pointer movement, scrolling, sometimes a macro. That is how a controller plays a game that only reads the keyboard, or runs a browser, the Finder or Anki. If you are leaving a paid one, the pages on a joystick mapper for Mac and a gamepad mapper for Mac show how to move the setup across.
The InputConfig main window with the Desktop Navigation preset selected, its rows listing a controller control on the left and the key or click it sends on the right.
Figure 1. A mapper preset is a list of rows: one control in, one key, click or pointer movement out.
A mapper that sends keys and clicks needs the Accessibility permission, because that is the permission that lets one app send input to another.
Searches use a lot of names for a few jobs. This is which tool fits which one:
  • Controller, gamepad or joystick mapper. The same job under three names: a controller in, keys and mouse out. Every app in the table does it. Choose by price, the controllers it lists and the macOS version you run.
  • Key remapper or keyboard mapper. Changes what a keyboard key does, such as Caps Lock to Escape. That is macOS's own Modifier Keys setting or Karabiner-Elements, not a controller mapper. The key remapper for Mac page sorts out which one you need.
  • Mouse button remapper. Gives side buttons a job. See mouse side buttons on a Mac.
  • Macro software for a controller. One press runs a timed sequence of keys. InputConfig builds these per button. See macros, turbo and toggle.
  • MIDI mapper. Pads and knobs to keystrokes. See MIDI to keystroke apps for Mac.
JoyToKey, Xpadder, reWASD, DS4Windows, InputMapper, x360ce and AntiMicroX have no macOS versions. Each has its own page with what the Mac does instead. Coming from DSX, the DualSense app on Windows? DSX for Mac shows where each of its jobs lives in InputConfig.
How I checked
Every row in the table comes from the app's own Mac App Store listing, its GitHub or Codeberg page, or the maker's website, read on the date in the table caption. Prices, versions and minimum macOS change, so the caption carries the date of the last check, and I change it whenever I recheck.
I do not give other apps star ratings, because I have not used each one on every macOS version, and a score from a competitor would not be worth much anyway. If you make one of these apps and a line here is out of date, tell me through the InputConfig issue tracker and I will fix it.
  • Free and open source. InputConfig, Enjoyable and JoyKeyMapper. Recontrol is free too.
  • One Steam game. Steam Input is enough.
  • Older macOS. Look at JoyMapper or Gamepad Mapper.
  • Beyond controllers. For MIDI, switches, the trackpad and screen regions as inputs, I would use InputConfig.
The right mapper is the smallest one that does your job on the macOS you run.
What is the best free controller mapper for Mac?
InputConfig is free and open source with nothing locked. Recontrol, Enjoyable and JoyKeyMapper are also free. The free list compares them.
Which Mac controller mappers are open source?
InputConfig, Enjoyable and JoyKeyMapper, all MIT licensed. ControllerKeys publishes its source under a non-commercial license.
Is there a JoyToKey for Mac?
No. JoyToKey is Windows only. The Mac apps on this page do the same job.
Does Karabiner-Elements map game controllers?
Only partly. It is built for keyboards and mice. Its release notes say it reads DirectInput gamepads and not XInput ones, and it works for pads that can switch into a keyboard mode.
Which mappers support the DualSense touchpad and gyro?
InputConfig and JoyMapper list both. Check each app's page for the rest.
Can a Mac controller mapper make my keyboard act like a game controller?
InputConfig cannot. It turns controllers, MIDI gear, keys, mice and the trackpad into keys, clicks, pointer movement, scrolling, macros, MIDI and system actions, not into a virtual game controller. For a game that only reads a controller, a real controller is the reliable answer.
Is it safe to give a controller mapper Accessibility access?
Any mapper that sends keys and clicks needs it. That permission is how one app sends input to another. Mac App Store apps also run in Apple's sandbox and pass App Review. InputConfig has no network access, no account and no analytics, and its source is on GitHub for anyone to read.
Does InputConfig run on Apple silicon and Intel Macs?
Yes. It is a universal app for macOS 14 or later, free on the Mac App Store.
Is there a Universal Controller Remapper or Input Mapper for Mac?
No. Both are Windows tools with no Mac version. The Mac apps on this page do the same job. InputConfig is the free, open-source one I make.
This page in other languages: Deutsch
