InputMapper for Mac
InputMapper is a Windows program with no Mac version, and on a Mac you do not need it. People used it for two jobs: making a PlayStation or other pad look like an Xbox controller to Windows games, and mapping it to keys and mouse. On a Mac the first job is already done by macOS, and the second is what InputConfig, the free mapper I make, is for.
Get games to see the pad
A Mac does not need an Xbox emulation layer. Mac games that support controllers read the DualSense, DualShock 4, Xbox, Switch Pro and MFi pads directly through Apple's Game Controller framework. Pair the pad in Bluetooth settings, or plug it in, and a controller game sees it. If a game still ignores it, connected but not working walks through why.
Map keys, mouse, touchpad and gyro
  • Buttons to keys. Any key or key combination, with turbo, toggle, hold and double tap.
  • Stick to mouse. With deadzones and response curves.
  • Touchpad to trackpad. On the DualSense and DualShock 4, one finger moves, a tap clicks, two fingers scroll.
  • Gyro aim. On the DualSense, DualSense Edge and DualShock 4, set up here.
  • Light bar. A color and brightness, or a color per preset so the pad shows which layout is running.
  • Rumble. As feedback on a binding, on the DualSense and on pads macOS drives haptics for.
An InputConfig preset for a DualSense, with the Live Visualizer key naming keys on the face buttons, the mouse on the right stick and the touchpad as a trackpad.
Figure 1. One preset, every part of the pad: keys, the mouse, the touchpad and the light bar.
Presets switch on their own when a game or app comes to the front, and the Smart Preset Maker has layouts for more than 450 games and apps.
Be careful with InputMapper download sites
When I checked on 22 September 2026, the old inputmapper.com address redirected to an unrelated site. Be careful with any download that claims to be InputMapper, and especially with one labeled for Mac: there is no Mac version. InputConfig is on the Mac App Store, and its source is public on GitHub under the MIT license.
Checked on 22 September 2026.
What it cannot do
InputConfig does not create a virtual controller, so it cannot make one pad look like another to a game. Mac games read PlayStation, Xbox and Switch pads directly, so that is rarely needed on a Mac.
Compare every mapper for Mac
If you meant any input mapper, not the Windows app, the best controller mapper for Mac page compares every option, free and paid, with price, last update and minimum macOS.
  • No Mac version. InputMapper is Windows only.
  • No emulation needed. Mac games read PlayStation pads directly.
  • Keys, mouse, touchpad and gyro. InputConfig covers these, and it is free on the Mac App Store.
Skip any download that calls itself InputMapper for Mac.
Is there an InputMapper for Mac?
No. InputMapper is Windows only. On a Mac, PlayStation pads work natively in controller games, and InputConfig maps them to keys, mouse, touchpad and gyro.
Does InputConfig emulate an Xbox controller like InputMapper?
No. It does not create a virtual controller. Mac games read PlayStation, Xbox and Switch pads directly, so it is rarely needed on a Mac.
Is InputConfig free?
Yes. It is free and open source on the Mac App Store, for macOS 14 or later on Apple silicon and Intel. There is an optional tip that adds no features.
