ControllerMate alternative for a current Mac
ControllerMate's own site lists macOS 10.13 High Sierra and 10.14 Mojave as the systems its current version is compatible with, and nothing newer. If you have moved to a newer Mac, the setups you built in it need a new home. I make InputConfig, a free, open-source Mac app for macOS 14 and later that covers the common ControllerMate jobs: a button or a MIDI message that types keys, clicks, runs a macro or opens something. It does not cover everything ControllerMate did, and this page says where.
  1. Install InputConfig from the Mac App Store and allow Accessibility access.
  2. Connect the controller, joystick or MIDI device, and tick it under InputConfig, Devices if it is not in the sidebar.
  3. For each thing a ControllerMate page did, add a row: press Scan, press the button, and pick what it sends.
  4. Press Activate.
Match what you built in ControllerMate
In ControllerMateIn InputConfig
A button that sends a keystroke or textA Keyboard Key row, a shortcut, a macro, or Type Text, which can sit beside a macro as a stacked output
Building blocks wired into logicOptions on a row: hold, double tap, turbo, toggle, and chords that need a second button held
MIDI notes and controller values as triggersMIDI as an input: notes, control changes and program changes bind like buttons
A joystick axis moving the pointerA Mouse Motion row with a deadzone and a response curve
Virtual mouse, tablet and joystick devicesPointer movement, clicks and scrolling as system events. No virtual joystick or tablet
If your setup was buttons and MIDI in with keys and clicks out, it carries over, but if it fed a virtual joystick to another app, it does not.
The InputConfig main window with the Desktop Navigation preset selected, its rows listing a controller control on the left and the key or click it sends on the right.
Figure 1. InputConfig's main window: each row names a control and the key or click it sends.
A row in InputConfig's editor with its Options open: one input sending several outputs at once, a key, a click and a MIDI note, with Vibrate and Speak ticked.
Figure 2. One input, several outputs at once: a key, a click and a MIDI note, plus a buzz and a spoken word. That covers a good part of a ControllerMate patch.
Rebuild a setup with Scan
InputConfig cannot open ControllerMate's files, so a setup is rebuilt row by row. That goes faster than it sounds:
  • You: Press Scan on a row and press the button, move the axis, or play the MIDI note.
  • InputConfig: Binds the row to that input, whatever its number.
  • Check: The Live Visualizer lights the control when you use it. Then pick what the row sends.
  • Logic that waited for a held button. Use chords.
  • Repeating keys. Use turbo, or a macro for a sequence.
  • MIDI gear. See MIDI as input.
One row per job replaces most building-block pages.
What InputConfig does not replace
  • Virtual joysticks and tablets. ControllerMate could create devices that other apps saw as real hardware. InputConfig sends keyboard and mouse events and creates no virtual device.
  • Free-form logic. There is no canvas of blocks to wire together. A row has one input and one or more outputs that fire together, shaped by its options.
  • X-keys hardware. ControllerMate had a version made for X-keys. I have not tested X-keys devices with InputConfig.
For a flight simulator that expects a virtual joystick, InputConfig is not the answer.
  • ControllerMate. Its site lists macOS 10.13 and 10.14 and nothing newer.
  • On a current Mac. InputConfig covers buttons and MIDI in, keys, clicks, pointer and macros out.
  • Not covered. Virtual devices and block logic are not covered.
I checked ControllerMate's site on October 6, 2026. I would rebuild the rows you use every day first, because most setups turn out smaller than they looked.
Does ControllerMate work on current macOS or Apple silicon?
Its own site lists macOS 10.13 High Sierra and 10.14 Mojave as compatible with the current version, and older versions for older systems. It lists nothing newer. I have not tried to run it on a current Mac.
Is there a free alternative to ControllerMate?
For buttons, joystick axes and MIDI messages that send keys, clicks, pointer movement and macros, InputConfig is free and open source on the Mac App Store, for macOS 14 and later.
Can InputConfig create a virtual joystick like ControllerMate?
No. InputConfig sends keyboard and mouse events and creates no virtual device, so an app that needs a joystick must see a real one.
Can InputConfig open my ControllerMate files?
No. A setup is rebuilt row by row with Scan: press the button or play the MIDI note, then pick what it sends.
