Is there Controller Companion for Mac?
No. Steam lists Controller Companion for Windows and not for macOS. Its pitch is steering the desktop from the couch: the mouse, media keys and typing from a controller. On a Mac that is what a controller mapper does. I make InputConfig, a free, open-source Mac app whose built-in Desktop Navigation preset does it out of the box: a stick moves the pointer, buttons click, and the rest of the pad runs the Mac.
- Install InputConfig from the Mac App Store and allow Accessibility access.
- Pair the controller with the Mac.
- Choose the built-in Desktop Navigation preset.
- Press Activate.
- Move the stick to steer the pointer, and press the bottom face button to click.
Match Controller Companion on a Mac
| What you want | In InputConfig on a Mac |
| The mouse from a stick | Mouse Motion rows with deadzones and speed curves, and the DualSense touchpad as a trackpad |
| Clicks and scrolling | Buttons for left, right and middle click, and a stick or the D-pad for scrolling |
| Media keys and volume | System functions on any button |
| Typing | The macOS Accessibility Keyboard clicked with the stick, Start Dictation on a button, and Type Text for saved phrases |
| Different controls per app | Per-app auto-switch: the preset changes when the app comes to the front |
A stick for the pointer and buttons for clicks is one built-in preset away.
Start with Desktop Navigation
- You: Pair the controller, open InputConfig, choose Desktop Navigation and press Activate.
- InputConfig: Starts sending pointer movement, clicks, scrolling and shortcuts from the controller.
- Check: Move the stick and the pointer follows.
How to use a game controller as a mouse on a Mac has the full layout, and couch browsing and media builds the sofa setup. Change any row afterward, since the preset is only a starting point.
What works differently
- The on-screen keyboard. InputConfig draws none of its own. It works with the Accessibility Keyboard built into macOS.
- The login window. It starts after you log in, so it does not run there.
- Games that read the pad themselves. Deactivate the preset for those, so the controller is not also sending keys.
It uses the Mac's own on-screen keyboard and does not replace it.
- Controller Companion. It is Windows only, on Steam.
- On a Mac. Use InputConfig with the Desktop Navigation preset.
- Typing. Use the macOS Accessibility Keyboard, dictation, or saved text.
Running a Mac from the couch takes a controller and one free app.
No. Steam lists it for Windows only. On a Mac, InputConfig turns a controller into the mouse, the keyboard and the media keys for free.
What is the Mac alternative to Controller Companion?
InputConfig, a free and open-source app on the Mac App Store. Its built-in Desktop Navigation preset moves the pointer with a stick and puts clicks, scrolling and shortcuts on the buttons.
Can I type with a controller on a Mac?
Yes. Click the keys of the macOS Accessibility Keyboard with the stick, start dictation from a button, or put saved phrases on buttons with Type Text.
Does it work with a PS5 or Xbox controller?
Yes. It works with PlayStation, Xbox, Switch and 8BitDo controllers that the Mac can read, and with many plain USB pads.
