How to play Minecraft on a Mac without a mouse
You can play Minecraft Java on a Mac without a mouse. A two-finger click places blocks, moving Attack to a key removes the need to hold a click while you look, and a game controller makes it comfortable. Minecraft is built for a mouse: hold the left button to mine, press the right one to place, and move the mouse to look, often all at once. A MacBook trackpad can do each of those, just not comfortably together, so here are the three fixes, from settings you already have to a controller, and you can mix them.
  1. Place blocks with the trackpad's right click
  2. Mine without holding a click
  3. Fix all of it with a controller
  4. If one hand does most of the work
  5. The short version
  6. Questions
Placing a block, opening a chest and eating all use the right mouse button. On a trackpad that is a secondary click.
  • You: In System Settings, Trackpad, set Secondary click to Click or Tap with Two Fingers.
  • macOS: Treats a two-finger click as a right click.
  • Check: In the game, click with two fingers and a block goes down.
Eating works the same way. Food is eaten by holding the right mouse button while it is in your hand, so on a trackpad that is a two-finger click held down. Opening a chest is a single right click on it. If holding two fingers down is awkward, bind Use Item/Place Block to a key in Options, Controls, Key Binds and hold that instead.
Control-click also counts as a right click in Minecraft on a Mac, but Control is the sprint key, so you may start sprinting as you place.
Every way to place a block is on placing blocks in Minecraft without a mouse, and holding Use Item to eat has its own page, eating in Minecraft without a mouse.
The hard part on a trackpad is holding the click to mine while your finger also has to turn the view. Minecraft can fix that itself, in Options, Controls:
  • Key Binds. Move Attack/Destroy and Use Item/Place Block to keys you can reach, so one hand mines and places on the keyboard while the other looks around on the trackpad.
  • Sneak and Sprint. Set both to Toggle so neither needs a held key.
  • Mouse Settings. Turn Mouse Sensitivity down if the trackpad spins you around.
Moving Attack to a key removes the hardest part of trackpad Minecraft.
A PS5, PS4, Xbox or Switch Pro controller gives Minecraft a stick to look with and triggers to mine and place, with no mouse anywhere. Java Edition ignores controllers, so InputConfig, free on the Mac App Store, turns the pad into the keyboard and mouse the game expects.
  • The built-in layout. Its Minecraft preset walks on the left stick, looks on the right, mines on the right trigger and places on the left.
  • Long digs. If holding a trigger tires your hand, give that row Toggle in its Options: one pull starts mining, the next stops it.
The built-in Minecraft preset in InputConfig, with the Live Visualizer key naming mine on the right trigger and place on the left trigger.
Figure 1. The built-in Minecraft preset: look on the right stick, mine and place on the triggers.
The full setup is on how to play Minecraft with a controller on a Mac.
A controller layout can be built around the hand you have: every action within reach of one thumb, a hold or a double tap on one button for a second job, and toggles instead of held buttons. Using a Mac with one hand goes through it.
  • Place. Click with two fingers, after turning on secondary click.
  • Mine. Move Attack/Destroy to a key, and set Sneak and Sprint to Toggle.
  • Everything at once. Use a controller with InputConfig's Minecraft preset.
Start with the settings, and add a controller when the trackpad still gets in the way.
Do you need a mouse to play Minecraft?
No. On a Mac the trackpad looks around and clicks to break blocks, and a two-finger click is the right mouse button that places blocks, opens chests and eats. Moving Attack to a key and using a controller make it more comfortable.
Can you play Minecraft on a MacBook without a mouse?
Yes. Two-finger click places blocks and the trackpad looks around. Moving Attack to a key in Minecraft's Controls removes the hardest part, holding a click while you move. A controller is the most comfortable way.
How do you sprint in Minecraft on a Mac without a mouse?
Sprint is Left Control, or a double tap of W. Sneak is Left Shift. Set both to Toggle in Options, Controls so you do not have to hold them. In InputConfig's Minecraft preset, sprint is the left stick click.
This page in other languages: Deutsch, Español, Français, Bahasa Indonesia, Italiano, 日本語, Nederlands, Polski, Português, Русский, ไทย, Tiếng Việt, 繁體中文, 简体中文
