Does the Razer Tartarus work on a Mac?
Yes, as a keyboard: a Tartarus types its keys on a Mac with nothing installed. The catch is the same as on any keypad, which is that every key arrives as a keyboard key, so a Mac sees you typing. To give those keys jobs of their own, set eight of them to F13 to F20, which type nothing, in Razer's software or the keypad's memory, and then bind those keys.
I make InputConfig, a free Mac app that listens to the keyboard alongside macOS and gives any key a job. I have checked it with a Razer mouse, and I have not tested a Tartarus myself, so the keypad specifics here come from Razer's pages. No Tartarus is on the Razer Synapse for Mac list quoted on Razer mouse on a Mac.
On this page: 11 sections
  1. Steps
  2. What the Tartarus does on a Mac, and what Synapse does
  3. Find out what each key sends
  4. The F13 to F20 plan
    1. Step 1: Change the keys
    2. Step 2: Scan and bind
  5. Macros and multi-step jobs
  6. Options that make a keypad better
  7. Ideas for people who use a Tartarus
  8. If a key does not do what you expect
  9. What it cannot do
  10. The short version
  11. Questions
  1. Plug in the Tartarus and check that its keys type in a text editor.
  2. Set eight keys you want to use as buttons to F13 to F20 in Razer Synapse, on a Windows PC if you have one.
  3. Open InputConfig, add a Keyboard input, press Scan and press each of those keys.
  4. Choose what each F key sends, then Save and Activate the preset.
  5. Make a preset for each app and switch layouts by the front app.
I read Razer's pages for the Tartarus V2 and Tartarus Pro on October 21, 2026.
ModelKeysThumb padNotable
Tartarus V232 programmable keys8-way directional thumb padMecha-Membrane keys
Tartarus Pro32 programmable keys8-way directional thumb padAnalog optical switches, actuation 1.5 to 3.6 mm, up to 8 profiles switched with a side button
Neither model is on the Synapse for Mac list I read, so a Mac cannot run Razer's settings screen for them, and the Tartarus types its default keys. Razer's V2 page did not mention onboard memory in what I read. If you want to change what the keys send, you need Synapse on a Windows PC, and the question is whether the keypad remembers the change when you plug it into the Mac.
A Tartarus is a keyboard, so there are no Button 4 or Button 9 names here. Scan will name a key.
  • You: In InputConfig, make a preset, click Add a new Input Device, choose a keyboard, add a Keyboard Key row, press Scan, and press one Tartarus key.
  • InputConfig: Names the key it received, such as a letter, a number or an arrow.
  • Check: A key name means the key types in every app. InputConfig lists every keyboard as one, so the Tartarus 1 and the 1 on your main keyboard are the same to it.
ControlHow it reportsWhat to do
Main keysKeyboard keys, usually the letters and numbers a game expectsMove your eight favorites to F13 to F20
Thumb pad, eight directionsRazer calls it an 8-way directional pad, so I expect keys, press Scan on each directionBind the ones that scan
Thumb buttonProbably a key too, Scan to seeBind it
Analog depth on the ProHandled inside the keypad, a Mac sees a key or nothingDo not expect depth
Profile switch on the ProTalks to the keypadUse it on the keypad
A Keyboard input in InputConfig with three rows: F13 opens the Mail app, F14 types a sign-off with Type Text, and F15 runs a Siri Shortcut.
Figure 1. A Keyboard input with F13, F14 and F15 as separate rows. Your Tartarus keys become rows like these once they send F keys.
The F13 to F20 plan
InputConfig does not block or remap a key itself, so a Tartarus key that types a letter still types it while a row also fires. The cure is to send a key that types nothing. F13 to F20 are the eight that Mac apps do not use, and F21 to F24 are not passed to apps by macOS, so skip those. F13 to F19 on a Mac explains why.
If you have no Windows PC, Karabiner-Elements is a free Mac remapper, and Mac users have used it with a Tartarus because a Mac treats the pad as a plain keyboard. One guide I read shows the keys typing their defaults until remapped. Styxpad is a free Mac app built for the Tartarus Pro with key remapping and macros. I have tried neither, and both can run beside InputConfig.
  • You: In Razer Synapse, on a Windows PC or wherever your model is supported, assign F13 to F20 to the eight keys you most want as buttons.
  • InputConfig: Nothing yet. This is the keypad's own step.
  • Check: Plug the keypad into the Mac and press one in a text editor. Nothing should type.
  • You: In InputConfig, add a Keyboard Key row, press Scan and press the key. Choose the output, such as Open App, Type Text, a shortcut or a system function. Save and Activate.
  • InputConfig: Runs the row each time that F key arrives, in every app.
  • Check: Press the Tartarus key and see the result.
A single Keyboard row in InputConfig where F13 from any keyboard runs the Open App output with Mail.
Figure 2. One Keyboard row, F13 from any keyboard, running Open App with Mail. Each of your eight Tartarus keys gets a row like this one.
Thirty-two keys do not fit into eight, so choose the eight that matter and leave the rest typing.
A key can run a macro, a sequence of key, shortcut and click steps with a wait and a hold time on each. Tick Run a sequence of steps (macro) in the row's Options. How to make a macro on a Mac has the step by step.
  • Editing. Command Z, Shift Command Z and a cut command on keys under your fingers.
  • Writing. Type Text for a signature or a stock reply.
  • Launching. Open App for the five programs you use all day.
  • Chains. Copy, switch app and paste, with a wait between steps.
A row's Options with Run a sequence of steps (macro) ticked and a list of steps that hold Command, tap C, release, tap Tab and tap V, each with a wait and a hold time.
Figure 3. A macro is a list of steps with a wait and a hold on each. A Tartarus key running a list like this does a whole job in one press.
  • Hold and double tap. A row can have a hold action and a double tap action, each a full second output, so eight F keys can be twenty-four jobs.
  • A second control. The While also holding control makes a combo, so a key plus a held key gives a new layer.
  • Repeat while held. A row can repeat while you hold the key.
  • Per app. List apps under Automation & Gaming Utilities and turn on Switch presets when the front app changes. Only one preset runs at a time, so each app gets a complete layout.
  • Emergency stop. Control Option Command period.
Block the button's own action applies to mouse buttons, and it does not apply to a key, which is why the F13 to F20 plan matters.
  • Players on a Mac. A game reads the keys it already knows, so a row can send 1 to 5 from F13 to F17 while a Mac app sees nothing.
  • Editors and designers. A left-hand keypad for undo, brush size and tool changes, with the right hand on the mouse.
  • One-handed users. A thumb pad and 32 keys in one hand replace most of a keyboard. See the one-handed Mac guide.
  • Data entry. Type Text on keys for the phrases you type all day.
  1. Scan it. If nothing scans, the keypad kept the key.
  2. Look for a letter. If the key types in a text editor, it is not on F13 to F20 yet. Redo the Synapse step.
  3. Check the keypad. A change made on another computer may not have stayed in the keypad.
  4. Allow Accessibility. System Settings, Privacy & Security, Accessibility.
  5. Activate the preset. Rows only fire while their preset runs.
If a key names an F key in Scan, it is ready to bind. Keys and mouse buttons as inputs has the background.
What it cannot do
  • Change keys. InputConfig does not remap or block a key. Razer's software or the keypad's memory changes what a key sends.
  • Analog depth. The Pro's adjustable actuation and Rapid Trigger are Synapse features.
  • Two keyboards apart. Every keyboard counts as one, so it cannot give the Tartarus and your main keyboard different jobs for the same key.
  • Lighting. Chroma lighting is Razer's.
  • Works. It types on a Mac.
  • F keys. Move eight keys to F13 to F20.
  • Bind. Scan, choose an output, Save and Activate.
Pick eight keys, move them, and give each a job before you touch the other twenty-four.
Yes, as a keyboard, and its keys type their defaults. No Tartarus is on the Synapse for Mac list I read.
Can I remap the Razer Tartarus on a Mac?
Not with Razer's software on a Mac, because Synapse for Mac does not list it. Set keys to F13 to F20 in Synapse on a Windows PC, then bind those keys in InputConfig.
How do I use the Tartarus thumb pad on a Mac?
Razer describes an 8-way directional pad. Press Scan on each direction to see which key it sends, then bind it.
Why do Tartarus keys type letters on a Mac?
A keypad is a keyboard, so each key types. InputConfig cannot block a key, so move the ones you want as buttons to F13 to F20.
Can I use Karabiner-Elements with a Tartarus on a Mac?
Mac users do, to turn the keypad's keys into other keys. I have not tested it, and InputConfig can then bind the F keys it produces.
Does the Tartarus Pro work on a Mac?
It types as a keyboard. Its analog depth and Rapid Trigger belong to Razer Synapse, which is not on Mac for this keypad.
This page in other languages: العربية, Čeština, Dansk, Deutsch, Español, Suomi, Français, Magyar, Bahasa Indonesia, Italiano, 日本語, 한국어, Norsk, Nederlands, Polski, Português, 繁體中文, 简体中文
