The Xbox Elite Series 2 controller on a Mac
The Elite Series 2, and the Elite Series 2 Core, pair with a Mac over Bluetooth the same way as any Xbox controller, with no driver, and Apple lists it among its supported controllers. Games with controller support see it as an Xbox pad. The parts that make it an Elite behave a little differently on a Mac, so here is what each one does.
  1. Pair it, or use a cable
  2. Carry profiles over from an Xbox or PC
  3. Give the four paddles their own jobs
  4. Trigger locks, stick tension and the D-pad
  5. Add macros, turbo and more
  6. Know what rumble does
  7. The short version
  • You: Turn it on with the Xbox button, then hold the pairing button on the top edge until the Xbox button blinks fast.
  • macOS: Lists it in System Settings, Bluetooth.
  • Check: Click Connect, then press a button in Game Controllers.
  • A USB-C cable. Works on macOS 15 Sequoia and later. On macOS 14, use Bluetooth and let the cable charge it.
  • The original Elite. The Series 1 has no Bluetooth, and I have not tested one on a Mac.
If it will not pair, see Xbox controller will not connect to a Mac.
The Elite stores up to three profiles inside the controller, made in the Xbox Accessories app on an Xbox or a Windows PC. There is no Mac version of that app, but the profiles travel with the controller: set them up once elsewhere and the profile button switches between them on the Mac as well. With no profile light on, the controller uses its default layout. The profile button and its lights never reach the Mac, so a preset cannot be switched from them. Firmware updates come from the same app. See updating Xbox controller firmware when you have a Mac.
With a profile active, each paddle sends the button the profile gives it, so a game with controller support simply sees a copy of that button.
  • You: In InputConfig, press Scan on a row and press the paddle.
  • InputConfig: Binds whatever the Mac receives, and shows you what that is.
  • Check: If pressing a paddle lights up A, the profile is copying A, and binding it would bind A too. Switch profile, or change that paddle in the Xbox Accessories app, until the paddle stands alone.
A row in the InputConfig editor after Scan, showing an Xbox Elite Series 2 paddle as its own input.
Figure 1. A paddle that scans as itself is free for any job. One that scans as A is only a copy of A.
In the default profile, with no profile light lit, the paddles report as P1 to P4 on their own: P1 and P2 on the right, P3 and P4 on the left. Since 1.8, InputConfig also reads the Elite over Bluetooth itself, paddles and profile included, when macOS does not hand it over as a game controller. It checks which profile is active and reads the paddles on their own only in the default one, the same rule macOS follows.
A paddle that is free makes a good home for a chord modifier, which gives every other button a second action while it is held, or for Emergency Stop.
These are mechanical, so they work on a Mac exactly as they do on an Xbox: the hair trigger locks shorten the pull, the tension tool changes how stiff the sticks feel, and the D-pad swaps like it always does. Nothing on the Mac needs to know.
The Elite has no macros of its own. On a Mac, InputConfig adds them:
It is free and open source, and needs macOS 14 or later.
Rumble goes through macOS's own haptics, and InputConfig can buzz the controller when a binding fires, with strength and duration set per row. It does not drive the small motors inside the triggers.
  • Pairing. It pairs like any Xbox pad, and a cable works from macOS 15 on.
  • Profiles. They are made on an Xbox or a PC and carried in the controller.
  • Paddles. Scan them in InputConfig to see whether they stand alone.
Use the default profile, profile light off, when you want the paddles free for your own jobs.
Does the Xbox Elite Series 2 work on a Mac?
Yes. It pairs over Bluetooth with no driver, and works by USB-C cable on macOS 15 and later. Profiles made on an Xbox or a Windows PC carry over, because they are stored in the controller.
Is there an Xbox Elite controller app for Mac?
No. The Xbox Accessories app runs on Windows and Xbox only. On a Mac, InputConfig remaps the buttons and paddles system-wide, for free.
Can I make macros on an Xbox Elite controller on a Mac?
Yes, with a mapper. The controller has no macros itself. InputConfig lets any button or paddle play a macro, a turbo repeat, or typed text.
Do the Elite Series 2 paddles work on a Mac?
Yes. In the default profile, with no profile light lit, each paddle reports as P1 to P4 on its own, and since 1.8 InputConfig reads them over Bluetooth itself as well. In a custom profile each paddle sends the button the profile assigns, and Scan shows you which.
This page in other languages: Deutsch
