How to play Tomb Raider on a Mac with a controller
All three of Feral's Mac versions, Tomb Raider, Rise of the Tomb Raider and Shadow of the Tomb Raider, are made to be played with a gamepad. Feral's FAQs list the pads it tested: the PS4 DualShock, Xbox One and Xbox 360 controllers, and Logitech's F310 and F710. A PS5 DualSense and the Xbox Series controllers are not on those lists. Feral says other gamepads may work but have not been tested.
I have not tested these three games myself, so the lists and the default keys are from Feral's FAQs and manuals for each one, which I read on October 7, 2026. If your pad does nothing in them, the fallback below does not depend on the game seeing a controller at all, because InputConfig, the free mapper I make, sends the game's keyboard and mouse controls from the pad.
  1. Steps
  2. See which pads Feral tested
  3. Check the usual four things
  4. Know the two special cases
  5. Send the game its keys instead
  6. Build the layout
  7. Change a button the game will not let you change
  8. Use one route, not both
  9. The short version
  10. Questions
  1. Connect the controller and check it under System Settings, Game Controllers.
  2. Quit the game, wake the controller, and open the game again.
  3. In Steam, try the game's Steam Input override both ways.
  4. If the game still ignores the pad, send its keyboard and mouse controls from the pad with a mapper.
GameTested gamepads, by Feral's FAQ
Tomb RaiderPS4 DualShock, PS3 DualShock, Xbox One, Xbox 360, Logitech F310, F710 and RumblePad 2, Steam Controller in Big Picture
Rise of the Tomb RaiderPS4 DualShock, PS3 DualShock, Xbox One and One S, Xbox 360, Logitech F310, F710 and RumblePad 2
Shadow of the Tomb RaiderPS4 DualShock, Xbox One, Xbox 360, Logitech F310, F710 and RumblePad 2, Steam Controller in Big Picture
Each FAQ adds that other gamepads may work, and gives a support address to write to about one that does not. A PS4 or Xbox One controller is the tested choice for all three games.
  1. The Mac sees the pad. Open System Settings, click Game Controllers, and press a button on the pad.
  2. Relaunch with the pad awake. Quit Tomb Raider, press a button on the controller, and open it again.
  3. Flip the Steam Input override. In the Steam library, right-click Tomb Raider, open Properties, then Controller, and try the other setting. Relaunch after each change.
  4. Disconnect other pads while you test. Then you know which one the game is reading.
If nothing lights up there, Tomb Raider has no chance of seeing the pad either. Controller works in Steam but not in the game has more on the Steam layer.
  • Logitech pads. Feral's FAQs name a switch position for each game: D for Rise, X for the other two. On a current Mac only D can be read at all, so start there. Logitech F310 and F710 on a Mac explains why.
  • Xbox 360 pads. They are on Feral's lists, which were written when a Mac could still read them. Current macOS does not. The Xbox 360 controller on a Mac has the details.
Test your own pad in the game before trusting any list, Feral's included.
Every Tomb Raider game also plays on a keyboard and mouse, and a keyboard is never undetected. InputConfig reads your controller and sends those keys and mouse moves, so Tomb Raider sees a keyboard while you hold the pad. These are the default keys from Feral's manuals:
ActionShadow of the Tomb RaiderTomb Raider
MoveW A S DW A S D
CameraMouseMouse
Jump or climbSpaceSpace
Roll or dodgeCShift
InteractEE
MeleeFF
Survival InstinctQQ
AimRight mouse button, heldRight mouse button, held
FireLeft mouse buttonLeft mouse button
ReloadRR
Weapons1 to 41 to 4
Journal or mapTabTab
Everything else builds on two rows: the left stick as WASD and the right stick as the mouse. Rise of the Tomb Raider lists its keys in its own keyboard settings.
Build the layout
  • You: In InputConfig, make a new preset. Set the left stick to WASD and the right stick to mouse movement. Put the right mouse button on the left trigger and the left mouse button on the right trigger.
  • InputConfig: Sends those keys and mouse moves whenever the preset is active.
  • Check: In the game, the left stick walks, the right stick looks, the left trigger aims and the right trigger fires.
  • Face buttons. Space, the roll key, E and F, in the places a gamepad would have them.
  • Stick clicks. Put Q on one for Survival Instinct, and Shift on the other to sprint in Shadow.
  • D-pad. Give it 1, 2, 3 and 4 for the weapons.
  • Menu buttons. These get Tab and Escape.
Aim on the left trigger and fire on the right, and it plays like the console version. Play any Mac game with a controller walks through a layout like this, and your first preset has the basics.
A Tomb Raider layout drawn on a DualSense Edge in InputConfig's Live Visualizer, with each control labeled with the key it sends.
Figure 1. Tomb Raider drawn on the controller, with climbing, aiming and Survival Instinct labeled.
The Tomb Raider layout in InputConfig's editor, one row for each control and the key it sends.
Figure 2. Each Tomb Raider key as a row. This is also where you change a button the game itself will not let you move.
Feral's manual for Tomb Raider says its gamepad controls cannot be customized. Its keys can be, and so can a mapper's layout, so the keyboard route is also the way to move a button, swap the triggers, or put two actions on one button with a hold. When the game fixes the gamepad layout, a keyboard layout sent from the pad is the one you can edit. Hold and double tap covers the second action.
If Tomb Raider does read your controller, a mapper sending keys at the same time makes every press arrive twice. So pick one. In InputConfig, a preset tied to the game only runs while that game is in front, and turning it off hands the pad back. If Tomb Raider already reads your pad, you do not need a mapper at all. Per-app switching can tie the preset to Tomb Raider.
  • Tested pads. Feral's FAQs list the PS4 DualShock and the Xbox One controller.
  • Not working. Check Game Controllers, relaunch the game, and flip the Steam Input override.
  • Fallback. Send WASD, the mouse and about a dozen keys from the pad.
Try your pad first, and if Tomb Raider will not listen, send it keys instead.
Does Tomb Raider on Mac support controllers?
Yes. Feral's Mac versions of Tomb Raider, Rise of the Tomb Raider and Shadow of the Tomb Raider all support gamepads, and its FAQs list the PS4 DualShock, Xbox One and Xbox 360 controllers and Logitech pads as tested.
Does a PS5 controller work with Tomb Raider on a Mac?
The DualSense is not on Feral's tested lists, which say other gamepads may work. I have not tested it. If the game ignores it, a mapper can send the game's keyboard and mouse controls from it.
Why is my controller not working in Shadow of the Tomb Raider on a Mac?
Check the pad under System Settings, Game Controllers, relaunch Shadow of the Tomb Raider with the pad awake, and try the Steam Input override both ways. If it still does nothing, send the game's keys from the pad.
Can I remap the controller in Tomb Raider on a Mac?
Feral's manual for Tomb Raider says gamepad controls cannot be customized. Keyboard controls can, so a mapper that sends keys from the pad gives you a layout you can change.
Which keys does Tomb Raider use on a Mac?
By Feral's manuals: W A S D to move, Space to jump, E to interact, F for melee, Q for Survival Instinct, R to reload, the right mouse button to aim and the left to fire.
