How to play BioShock on a Mac with a controller
Feral's Mac version of BioShock Remastered supports gamepads, and its FAQ lists more than seventy it tested: PlayStation DualShock pads up to the PS4's, Xbox One and Xbox 360 controllers, and Logitech's F310, F510 and F710 among them. The game needs a pad in DirectInput mode, and both its keyboard and gamepad controls can be customized under Settings, Customize Controls.
Everything here about the game is from Feral's FAQ and manual for BioShock Remastered, which I read on October 7, 2026. I have not tested it myself, and this page does not cover BioShock 2 or Infinite. If your pad does nothing, InputConfig, the free mapper I make, sends the game's keyboard and mouse controls from the pad.
- Connect the controller and check it under System Settings, Game Controllers.
- Quit the game, wake the controller, and open the game again.
- In the game, open Settings, Customize Controls to see or change the layout.
- If the game ignores the pad, send its keyboard and mouse controls from the pad with a mapper.
Start with the game's own gamepad support
Connect the pad before you start BioShock. With a tested pad the game uses it, and Settings, Customize Controls lets you change what each button does. Feral's FAQ names fifteen older pads that work only in part. Newer pads such as the PS5 DualSense are not on the list. Both the PS4 and the Xbox One controller are on Feral's tested list, which makes them the safe picks.
If the pad does nothing
- The Mac sees the pad. Open System Settings, click Game Controllers, and press a button on the pad.
- Relaunch with the pad awake. Quit BioShock, press a button on the controller, and open it again.
- Flip the Steam Input override. In the Steam library, right-click BioShock, open Properties, then Controller, and try the other setting.
- Set a Logitech pad to D. Feral's FAQ says the game needs DirectInput mode, the D position on an F310, F510 or F710.
If nothing lights up there, BioShock has no chance of seeing the pad either. Controller works in Steam but not in the game has more on the Steam layer.
Send the game its keys instead
BioShock is a keyboard and mouse game at heart, and a keyboard is never undetected. These are the default keys from Feral's manual:
| Action | Key |
| Move | W A S D |
| Look | Mouse |
| Jump | Space |
| Crouch | C |
| Fire the plasmid or weapon | Left mouse button |
| Switch between plasmids and weapons | Right mouse button |
| Use | E |
| Reload or EVE hypo | R |
| First aid | F |
| Hack | V |
| Zoom | Z |
| Next or previous ammo | Q or B |
| Map | M |
| Weapons | 1 to 8 |
| Plasmid slots | F1 to F6 |
Fire on the left mouse button and the plasmid switch on the right are the two that matter most.
Build the layout
- You: In InputConfig, make a new preset. Set the left stick to WASD and the right stick to mouse movement. Put the left mouse button on the right trigger and the right mouse button on the left trigger.
- InputConfig: Sends those keys and mouse moves while the preset is active.
- Check: In the game, the right trigger fires and the left trigger swaps between plasmids and weapons.
- Face buttons. Give them Space, E, R and F.
- Shoulders. The scroll wheel up and down, which steps through plasmids or weapons.
- Stick clicks. Use C on one to crouch and Z on the other to zoom.
- D-pad. Q and B for ammo, M for the map, V to hack.
Scroll on the shoulder buttons gives you the weapon wheel without taking a thumb off the stick. Play any Mac game with a controller walks through a layout like this.
Use one route, not both
If BioShock does read your controller, a mapper sending keys at the same time makes every press arrive twice. So pick one route. In InputConfig, a preset tied to the game only runs while that game is in front. If BioShock already reads your pad, you do not need a mapper at all. Per-app switching can tie the preset to BioShock.
- Tested pads. Feral's FAQ lists DualShock pads up to the PS4's, the Xbox One controller, and Logitech pads in D mode.
- Remapping. You can do it in the game, under Settings, Customize Controls.
- Fallback. If the game ignores the pad, send it keys and mouse moves from the pad.
Try your pad first, and if BioShock will not listen, send it keys instead.
Does BioShock Remastered on Mac support controllers?
Yes. Feral's FAQ for the Mac version lists more than seventy tested gamepads, including DualShock pads up to the PS4's, Xbox One and Xbox 360 controllers, and Logitech pads in DirectInput mode.
Does a PS5 controller work with BioShock on a Mac?
The DualSense is not on Feral's tested list for BioShock, and I have not tested it. If the game ignores it, a mapper can send the game's keyboard and mouse controls from it.
Can I remap the controller in BioShock Remastered on a Mac?
Yes. Feral's manual says keyboard and gamepad controls can both be customized under Settings, Customize Controls.
Why is my controller not working in BioShock on a Mac?
Connect it before starting the game, check it under System Settings, Game Controllers, try the Steam Input override both ways, and set a Logitech pad's switch to D.
Which keys does BioShock use on a Mac?
By Feral's manual: W A S D to move, Space to jump, C to crouch, E to use, R to reload, F for first aid, the left mouse button to fire and the right to switch between plasmids and weapons.
