How to play Borderlands 2 on a Mac with a controller
Aspyr, which made the Mac version, lists three controllers for Borderlands 2: the PS4 DualShock 4, the PS3 DualShock 3, and the wired Xbox 360 controller. A PS5 DualSense and the Xbox One and Series controllers are not on its list. Of the three, the DualShock 4 is the one a current Mac still connects without extra work.
That list is from Aspyr's Borderlands 2 Mac FAQ, which I read on October 7, 2026, and I have not tested Borderlands 2 myself. If your pad does nothing in it, the fallback is the keyboard: InputConfig, the free mapper I make, sends keys and mouse moves from the pad, and Borderlands 2 plays fully on those.
  1. Steps
  2. See what Aspyr lists
  3. If the pad does nothing
  4. Send the game keys instead
  5. Start from the Borderlands 3 layout
  6. Tune the aim stick
  7. Use one route, not both
  8. The short version
  1. Connect the controller and check it under System Settings, Game Controllers.
  2. Quit the game, wake the controller, and open the game again.
  3. On Steam, try the game's Steam Input override both ways.
  4. If the game still ignores the pad, send keyboard and mouse controls from the pad with a mapper.
ControllerOn Aspyr's listOn a current Mac
PS4 DualShock 4YesPairs over Bluetooth or plugs in
PS3 DualShock 3YesConnects with a cable first
Xbox 360, wiredYesNo longer read by macOS
PS5 DualSenseNoConnects to the Mac, untested in the game
Xbox One and SeriesNoConnect to the Mac, untested in the game
If you are choosing a pad for this game, a DualShock 4 is the one Aspyr names. How to connect a PS4 controller to a Mac has the steps, and the Xbox 360 controller on a Mac explains why that one stopped working.
  1. The Mac sees the pad. Open System Settings, click Game Controllers, and press a button on the pad.
  2. Relaunch with the pad awake. Quit Borderlands 2, press a button on the controller, and open it again.
  3. Flip the Steam Input override. In the Steam library, right-click Borderlands 2, open Properties, then Controller, and try the other setting. The Mac App Store version has no such layer.
  4. Disconnect other pads while you test. Then you know which one the game is reading.
If nothing lights up there, Borderlands 2 has no chance of seeing the pad either. Controller works in Steam but not in the game has more on the Steam layer.
Borderlands 2 is a keyboard and mouse shooter first, and a keyboard is never undetected. InputConfig reads the controller and sends keys and mouse moves, so the game sees a keyboard and you hold the pad. That works with any pad the Mac can read, a DualSense, an Xbox Series controller or a Switch Pro Controller included. The keyboard route does not care which controllers the game was written for.
A Borderlands 2 layout drawn on a DualSense Edge in InputConfig's Live Visualizer, with each control labeled with the key it sends.
Figure 1. Borderlands 2 on a DualSense Edge: shoot, throw, melee and the action skill, each labeled with its key.
The Borderlands 2 layout in InputConfig's editor, one row for each control and the key it sends.
Figure 2. The Borderlands 2 rows. The look rows run at speed 16, and that number is the first thing to change if aiming feels off.
InputConfig has no ready layout for Borderlands 2, and it has one for Borderlands 3, which is the same kind of game. It is a good starting point:
  • Sticks. The left stick sends W, A, S and D. The right stick moves the mouse.
  • Triggers. The right trigger fires with the left mouse button, and the left trigger aims with the right.
  • Face buttons. Jump, crouch, reload and use.
  • Bumpers. These send the action skill and a grenade.
  • D-pad. It picks the four weapon slots.
I have not checked those keys against Borderlands 2, so compare each row with the game's own key bindings screen and change the ones that differ. Copy the Borderlands 3 layout, then correct it against the game's key list. Presets and folders has more on managing presets.
Tune the aim stick
Mouse aim sent from a stick needs two settings to feel right: a speed that lets you turn around quickly, and a curve that keeps small movements small. In InputConfig both are on the stick's row, with a deadzone for a stick that drifts. Set the look speed first, then the curve, then leave it alone for an hour before judging it. Deadzones and sensitivity has the settings, and gyro aim is there for pads with a motion sensor.
If Borderlands 2 does read your controller, a mapper sending keys at the same time makes every press arrive twice. So pick one route. In InputConfig, a preset tied to the game only runs while that game is in front. If Borderlands 2 already reads your pad, you do not need a mapper at all. Per-app switching can tie the preset to Borderlands 2.
  • Listed pads. Aspyr's FAQ lists the DualShock 4, the DualShock 3 and the wired Xbox 360 controller.
  • Not working. Check Game Controllers, relaunch Borderlands 2, and on Steam flip the Steam Input override.
  • Fallback. Send keys and mouse moves from the pad, starting from the Borderlands 3 layout.
A DualShock 4 is the pad Aspyr lists, and for any other controller I would go straight to the keyboard route.
Does Borderlands 2 on Mac support controllers?
Yes. Aspyr's FAQ for the Mac version lists the wired Xbox 360 controller, the PS3 DualShock 3 and the PS4 DualShock 4.
Does a PS5 controller work with Borderlands 2 on a Mac?
The DualSense is not on Aspyr's list, and I have not tested it. If the game ignores it, a mapper can send keyboard and mouse controls from it, which the game accepts like any keyboard.
Does an Xbox One controller work with Borderlands 2 on a Mac?
Aspyr lists only the wired Xbox 360 controller, which current macOS no longer reads. An Xbox One or Series controller pairs with the Mac and can play through a mapper that sends keys.
Why is my controller not working in Borderlands 2 on a Mac?
Check it under System Settings, Game Controllers, relaunch Borderlands 2 with the pad awake, and on Steam try the Steam Input override both ways. If it still does nothing, send keys from the pad.
Which macOS does Borderlands 2 need?
Aspyr's FAQ gives macOS 10.12.6 or newer as the minimum.
