Help
Your first preset
Five minutes gets you from install to a controller that moves the pointer, clicks, scrolls and types in every app on the Mac. You install InputConfig, connect a controller, activate the built-in Desktop Navigation preset, and switch on one permission when macOS asks for it. Most of the five minutes is that permission. This page is for the first time you open the app. If the pointer does not move after that, go to the permission ladder.
  1. Steps
  2. Allow the one permission
  3. What Desktop Navigation does
  4. Change one thing
  5. Make a preset of your own, step by step
    1. Step 1: Start a new preset
    2. Step 2: Name it
    3. Step 3: Let InputConfig add the rows
    4. Step 4: Point a row at a button with Scan
    5. Step 5: Choose what it sends
    6. Step 6: Look at Options, then leave them
    7. Step 7: Save and activate
    8. Step 8: Know where to stop it
  6. If the pointer does not move
  7. If your Mac is not in English
  8. The short version
  1. Install InputConfig from the Mac App Store and open it. It needs macOS 14 or later.
  2. Connect a controller with a USB-C cable, or pair it in System Settings, Bluetooth. It shows up at the top of the sidebar within a few seconds, with its battery level.
  3. In the sidebar, open Desktop & Productivity and click Desktop Navigation.
  4. Click Activate. The first time, macOS asks for the Accessibility permission. Open System Settings, Privacy & Security, Accessibility, and switch InputConfig on.
  5. Move the left stick. The pointer moves. Press A / Cross to click. The right stick scrolls.
  6. To stop, click Deactivate, or hold Back and Start together on the controller for three seconds. That hold is the emergency stop and it works no matter what the preset maps those buttons to.
InputConfig turns controller input into the same keyboard and mouse events a real keyboard sends, and macOS only lets an app do that with the Accessibility permission.
  • You: Click Activate on Desktop Navigation. When macOS asks, open System Settings, Privacy & Security, Accessibility, and switch InputConfig on.
  • macOS: Lets InputConfig send keystrokes, clicks and pointer movement to other apps. Rows start working the moment the permission is granted.
  • Check: Move the left stick and the pointer moves. If the InputConfig icon in the menu bar is orange, the running preset is still waiting for the permission.
The permission is mostly about sending. The app watches your own keyboard, mouse or trackpad only when a preset uses one of their keys or buttons as an input, and then only while that preset, Scan or the Live Visualizer needs it. Keys are only listened to, so a bound key still does its normal job. A mouse's middle or side button is held back from its own action only when its row turns on Block the button's own action. All of that rides on the same permission. For most setups nothing else is asked for, and the app has no network access. A controller that also acts as a keyboard needs Input Monitoring, and macOS may ask about Bluetooth when you use Disconnect on a Bluetooth controller. More on what the Accessibility permission allows.
One row in the InputConfig binding editor, showing the drag handle, row number, Scan button, input type, input, arrow, output type, output, Notes line and Options.
Figure 1. One row in InputConfig's editor: the input on the left, the arrow, and the output it sends on the right.
Desktop Navigation is a pointer plus the everyday shortcuts, for using the Mac without touching the keyboard.
  • Point and scroll. The left stick moves the pointer: a small push is precise and a full push is fast. The right stick scrolls.
  • Click. The right trigger is left click and the left trigger is right click. A / Cross clicks too.
  • Edit. B / Circle undoes, X / Square cuts and Y / Triangle pastes. Pressing the right stick selects all.
  • Get around. The bumpers switch apps and the D-pad sends the arrow keys. Back / Share opens Spotlight and Start / Options presses Return.
There is no copy button in the layout; add a row for Command C, or change B. Every row carries a note saying what it does, so the preset explains itself.
Change one thing
Every row in the editor is one control and what it sends, so a change is one row.
  • You: Click Edit. To change what a button does, change the output on its row. To move a row to a different button, press Scan on the row and press the button you want. Then click Save.
  • InputConfig: Saves the preset, and a running preset picks the change up at once.
  • Check: Choose Activate at the top of the editor, press the button and watch the new output happen. A preset that is on keeps working while you edit, so turn it off again with Deactivate before you change much more.
Change one row, try it, then change the next. The binding editor page explains every part of a row.
Desktop Navigation gets you moving. This part builds a preset from nothing, one row at a time, so you can see how every other preset is made. It takes about five minutes, and you need a controller connected.
Click New Preset at the top of the sidebar. Your controller is listed just above it, which tells you InputConfig can see it.
The InputConfig sidebar with New Preset at the top and a connected controller listed above it.
Figure 2. New Preset is the first line under your controller.
Step 2: Name it
The editor opens on an empty preset. Type a name, and a tag if you want a line of description under it in the sidebar. Below those is one empty input device, waiting for rows.
The editor of a new preset: a name field, a tag field and one empty input device.
Figure 3. A new preset has a name, a tag and one empty input device.
Click Automatically insert available inputs. InputConfig names the controller it found and adds a row for each of its controls, grouped by part. Every row is waiting for an output.
You can also skip this and click Add a new bind for one row at a time.
An empty input device in the editor offering Automatically insert available inputs and naming the connected controller.
Figure 4. One click adds a row for every control on the controller it names.
The editor after the rows were inserted, grouped by part of the controller, each waiting for an output.
Figure 5. The inserted rows, grouped by sticks, buttons and triggers.
To choose a row's control by pressing it, click Scan on the row. The row waits. Press the button on the controller, and the row takes it as its input.
A row in the editor after Scan was clicked, waiting with Press a control.
Figure 6. After Scan, the row waits for you to press something.
The same row after the press, with Cross as its input.
Figure 7. The row now reads Cross, the button that was pressed.
On the right side of the row, open the output menu and pick the kind of thing the row sends. For a key, choose Keyboard Key, then pick the key. This row sends Space.
The output kind menu open on a row in the editor.
Figure 8. The output menu lists everything a row can send.
The row with Keyboard Key as the output and Space chosen.
Figure 9. Cross now sends Space.
Options under a row holds the extras: repeating, toggling, a different action on a hold or a double tap, a macro, and a buzz or a spoken word as feedback. A first preset needs none of them. Just know where they are.
A row's Options open in the editor, with How it fires, Macro, Feedback and Extra actions.
Figure 10. Options is where a row gets turbo, toggle, hold, double tap and feedback.
Click Save. The editor closes and the preset's page shows your layout in the Live Visualizer. Click Activate, and allow the Accessibility permission if macOS asks. Press the button: its label lights up, and Space is typed wherever the cursor is.
The editor with the pointer on the Save button.
Figure 11. Save is at the bottom right of the editor.
The preset's page with Activate, and the Live Visualizer lit by a press.
Figure 12. After Activate, a press lights its label in the Live Visualizer.
A running preset shows in the menu bar. Click the InputConfig icon there to see which preset is running and to stop it. The emergency stop from earlier works here too.
The menu bar popover naming the running preset, with a button to stop it.
Figure 13. The menu bar popover names the running preset and stops it.
A preset is a list of rows, and a row is one control and what it sends. Everything else in the app is a variation on these eight steps. The binding editor page covers each part of a row.
A missing permission is the usual cause, so climb this ladder, smallest step first:
  1. Check the permission. Open System Settings, Privacy & Security, Accessibility, and make sure InputConfig is switched on.
  2. Remove it and add it again. If it is already on the list and the pointer still does not move, remove it with the minus button, add it again, and relaunch InputConfig.
  3. Check the preset is running. The button on the preset's page reads Deactivate while it runs. If it reads Activate, click it.
  4. Check the controller. It should be at the top of the sidebar with its battery level. If it is not, connecting a controller has the fixes.
Start at the top: the permission is the step people skip.
The permission step reads System Settings, Privacy & Security, Accessibility. On a Mac set to another language, the same three places are called:
Mac languageSystem SettingsPrivacy & SecurityAccessibility
Spanish (Spain)Ajustes del SistemaPrivacidad y seguridadAccesibilidad
Spanish (Latin America)Configuración del SistemaPrivacidad y seguridadAccesibilidad
Portuguese (Brazil)Ajustes do SistemaPrivacidade e SegurançaAcessibilidade
Portuguese (Portugal)Definições do SistemaPrivacidade e segurançaAcessibilidade
FrenchRéglages SystèmeConfidentialité et sécuritéAccessibilité
GermanSystemeinstellungenDatenschutz & SicherheitBedienungshilfen
ItalianImpostazioni di SistemaPrivacy e sicurezzaAccessibilità
Japaneseシステム設定プライバシーとセキュリティアクセシビリティ
Korean시스템 설정개인정보 보호 및 보안손쉬운 사용
Chinese (Simplified)系统设置隐私与安全性辅助功能
Chinese (Traditional)系統設定隱私權與安全性輔助使用
These are the names on macOS 26 Tahoe; older versions may word them a little differently. InputConfig itself comes in 26 languages: it follows the language set for it in System Settings, or pick one in Settings, General, Language. The mapping works the same in every language. Key names follow your keyboard layout, covered in the binding editor help.
  • Install and connect. InputConfig from the Mac App Store, then a controller by cable or Bluetooth.
  • Activate Desktop Navigation. Allow Accessibility once when macOS asks.
  • Stop any time. Click Deactivate, or hold Back and Start together for three seconds.
  • Then make it yours. Change one row at a time, or start a layout for a game with the Smart Preset Maker.
Five minutes of setup, and the controller runs the whole Mac.
Do I need drivers?
No. macOS handles the controller over USB or Bluetooth and InputConfig reads it through Apple's own framework. MIDI devices are found on their own too.
Does it work with games that have no controller support?
The game sees a keyboard and a mouse, because that is what InputConfig sends.
Is InputConfig free?
It is free and open source on the Mac App Store, with no account and nothing locked. The optional tip jar unlocks nothing.
I searched the Mac App Store for a controller mapper and InputConfig was not at the top. How do I find it?
Search for InputConfig, one word. App Store search ranks apps with words like mapper or gamepad in their name first, so a search for controller mapper can list other apps above it. The right one is by Ryleigh Newman, free, for macOS 14 or later.
Can I download InputConfig from GitHub instead?
The full source code is on GitHub under the MIT license, but the GitHub releases are source only, with no ready-to-run app attached. The signed, ready-to-run copy is the free one on the Mac App Store. If you would rather build it yourself, open the project in Xcode 26 or later, choose your own signing team, and build; the README has the steps.
Is InputConfig available in my language?
Yes, in 26 languages: Arabic, Chinese (Simplified and Traditional), Czech, Danish, Dutch, Finnish, French, German, Hebrew, Hungarian, Indonesian, Italian, Japanese, Korean, Norwegian, Polish, Portuguese, Russian, Slovak, Spanish, Swedish, Thai, Turkish, Ukrainian and Vietnamese. The editor, the built-in presets, the Smart Preset Maker and this help are all translated. InputConfig follows the Mac's language; to pick another, open Settings, General, Language and choose Restart Now.
