Ready-made controller profiles for Mac games
You do not have to build a controller layout from a blank page. InputConfig comes with ready layouts for more than 450 games and apps: type the title, pick the controller in your hands, and a complete profile appears with a note on every button. It is free, and every profile is yours to change.
I make InputConfig, a free Mac app that maps a controller to keys and mouse. In the app a profile is called a preset. I built the library because the hardest part of any mapper is knowing where to start.
On this page: 10 sections
  1. Steps
  2. Get a profile for your game
  3. Look before you download anything
  4. Add the extras for your controller
  5. Change anything you like
  6. Switch profiles automatically
  7. Share a profile, or use someone else's
  8. When your game is not in the list
  9. The short version
  10. Questions
  1. Open the Smart Preset Maker from the welcome screen or the wand button in the sidebar.
  2. Type the name of the game or app.
  3. Pick your controller.
  4. Turn on any extras in the Fine-tune step.
  5. Click Create, select the new preset, and click Activate.
  • You: Open the Smart Preset Maker from the welcome screen or the wand button in the sidebar. Type the game or app.
  • InputConfig: Lists the title if it has a ready layout.
  • Check: Pick it, then pick your controller so the button names match.
The Smart Preset Maker's second step with a game typed into the search field.
Figure 1. Type a game or an app. A title with a ready layout appears under the field.
The Smart Preset Maker's third step, the list of controllers.
Figure 2. Pick the controller you will hold, so the button names match.
Click Create, select the new preset, and click Activate. Each row carries a note saying what it does in that game.
The finished preset's page, made by the Smart Preset Maker.
Figure 3. The finished preset on its page, named and ready to Activate.
The preset library on this site lists every title with its full button map, so you can read a layout before you make it. Games, creative apps, browsers, editors and accessibility layouts are all there.
The Fine-tune step offers only what fits the game and the controller you picked:
  • Touchpad as a trackpad. On a pad with a touchpad.
  • Gyro fine aim. On a pad with motion sensors, in a game that looks with the mouse.
  • Rumble when a trigger clicks. A short buzz on each trigger row that clicks the mouse.
  • Back paddles. Filled in on a pad that has them.
  • A light bar color. For a PlayStation controller.
The Smart Preset Maker's fourth step with its fine-tune switches.
Figure 4. The fine-tune switches. Leave anything you are unsure about off; it can be added later.
A ready profile is an ordinary preset from the moment it exists. Click Edit to scan a row to another button, change what it sends, add a hold or a double tap, or delete a row you do not want. Nothing about it is locked.
A preset can be tied to one or more apps. With automatic preset switching turned on in Settings, Advanced, the game's profile turns on when the game comes to the front, and your previous one comes back when you leave. Presets and folders covers it.
  • Export. A preset's menu writes it to a file you can send to a friend.
  • Import. Open a preset file, or drop it on the Dock icon. The import sheet lists everything the preset does before it is added.
  • Convert. Convert To makes a copy for another controller family, so a PlayStation layout gets an Xbox twin.
The import sheet in InputConfig listing a shared preset's actions that open apps or websites, with the choice to remove them before the preset is added.
Figure 5. Importing a shared preset. Anything that would open an app or a website is listed first, so you decide.
  • Pick the closest title. A game in the same genre usually needs the same controls.
  • Start from a shape. There are FPS presets per controller family, a Racing Game preset, and Minecraft.
  • Duplicate and rename. Then scan only the rows that differ.
Play any Mac game with a controller walks through building one by hand.
  • Search. More than 450 games and apps have a ready profile.
  • Pick your controller. PS5, PS4, Xbox, Switch, 8BitDo and more.
  • Edit freely. It is your preset, and it is free.
Let the app write the first draft, then make it yours.
Where can I download controller profiles for Mac games?
InputConfig, free on the Mac App Store, has ready layouts for more than 450 games and apps built in. Search for the title in the Smart Preset Maker and pick your controller.
Do the profiles work with a PS5 controller?
Yes. Pick the DualSense when you make the preset and the rows use PlayStation button names. The same titles are available for Xbox, Switch and other controllers.
Can I edit a ready-made profile?
Yes. It is an ordinary preset. Change any row, add new ones, or delete what you do not need.
Can I share a profile with someone else?
Yes. Export writes a preset to a file, and Import adds one. The import sheet shows what the preset does before it is added.
What if my game is missing?
Pick a game in the same genre, or start from a general preset such as FPS or Racing Game, and change the rows that differ.
