Can a MIDI controller run DaVinci Resolve on a Mac?
Yes, for editing, through an app that turns each pad and knob into one of Resolve's keyboard shortcuts. InputConfig, the free Mac app I make, does the turning: pads run the transport, mark, cut and undo, and a knob steps the playhead a frame at a time like a jog wheel. It finds a class-compliant MIDI device over USB or Bluetooth MIDI with no driver.
One limit comes first. A keystroke mapper presses keys. It cannot grab a color wheel or a grading knob, which is what dedicated panels are for.
  1. Steps
  2. Map the pads to Resolve's shortcuts
  3. Choose a mode for each knob
  4. Put the risky keys on a hold
  5. Know what a keystroke mapper cannot do in Resolve
  6. Share one controller between Resolve and a music app
  7. If a game controller is simpler
  8. The short version
  1. Connect the MIDI controller over USB or Bluetooth MIDI.
  2. In InputConfig, add a row, press Scan, and hit a pad.
  3. Pick the Resolve shortcut for that pad, such as J, K or L.
  4. Set a knob to Turn mode on the Left and Right arrow keys.
  5. Activate the preset and bring DaVinci Resolve to the front.
  • You: Add a row for each pad, press Scan, hit the pad, and pick the key.
  • InputConfig: Sends that key to Resolve whenever you hit the pad, and holds it for as long as the pad is held.
  • Check: With Resolve in front, hit the pad for L and playback starts.
Pad or knobResolve keyJob
Pad 1JPlay in reverse
Pad 2KPause
Pad 3LPlay forward
Pad 4SpacePlay and pause
Pad 5IMark in
Pad 6OMark out
Pad 7Command BCut at the playhead
Pad 8Command ZUndo
Pad 9ASelection mode
Pad 10BBlade mode
Pad 11Command SSave
Knob 1, Turn modeRight Arrow clockwise, Left Arrow counterclockwiseStep a frame at a time
Knob 2, Turn modeCommand Plus clockwise, Command Minus counterclockwiseZoom the timeline
Knob 3, Dial modeHorizontal mouse wheelMove along the timeline, faster the further you turn
These are Resolve's default keys. If you have changed the keyboard layout in Resolve, use your own. J, K and L under three fingers and a jog knob under the thumb cover most of an edit.
A row in the InputConfig editor with a MIDI note from a pad controller as the input and a keyboard shortcut as the output.
Figure 1. An InputConfig row with a MIDI pad's note as the input and a keyboard shortcut as the output.
InputConfig's editor with MIDI rows for DaVinci Resolve: each pad, key or knob on the left and the key or action it sends on the right.
Figure 2. Nine pads, nine Resolve shortcuts. Pads 1 to 3 send J, K and L, so the top row is your transport.
A knob can be read three ways:
  • Turn. Fires a short nudge every few steps of rotation, clockwise for one row and counterclockwise for the other. This is the mode for stepping.
  • Dial. Treats the center as rest, like a stick: the further from the center, the faster the output runs. This is the mode for scrolling.
  • Switch. Fires once past halfway, for pedals and buttons that send a Control Change.
Turn Step sets how far you turn for each frame. Turn mode on the arrow keys is what makes a knob a jog wheel. The built-in MIDI: Knob Deck preset has both kinds to copy from.
The DaVinci Resolve preset's page in InputConfig, with the Live Visualizer in its MIDI view showing a keyboard, dials and the last notes received.
Figure 3. The same preset on its page. The MIDI view shows the keyboard, the dials and the note that last arrived, which is how you check a pad before you open Resolve.
Every row can carry a second action on a hold and a third on a double tap. Put Undo on a tap and Save on a hold of the same pad, or keep the cut on a pad you cannot brush by accident. One pad can carry several keys in order too, as a macro: mark in, mark out and cut, for example. A hold costs half a second and saves a wrong cut. Hold and double-tap actions has the settings.
  • Color wheels and grading knobs. They are not keys. For grading by hand, Resolve users reach for dedicated panels or tools built for Resolve.
  • Faders in the mixer. A keystroke cannot move one.
  • Feedback. Resolve never tells the controller anything, so no pad lights to show a state.
If Resolve has a keyboard shortcut for it, a pad can do it, and if it does not, a pad cannot.
If the same controller also plays instruments in a music app, give this preset an auto-switch entry for DaVinci Resolve. The pads send its shortcuts while it is in front, and the preset that was running before comes back when you leave. Turn automatic switching on in Settings, Advanced first. InputConfig reads a copy of the MIDI, so the music app still hears the notes.
With auto-switch on, the pads only belong to Resolve while Resolve is in front.
If you do not already own MIDI gear, a game controller in the off hand does the transport and marking jobs with no desk space. The DaVinci Resolve preset is ready in two clicks, and MIDI rows and controller rows can live in the same preset. The controller you already own can be the edit remote. The video editing controller guide compares Resolve, Final Cut Pro and Premiere Pro row by row.
  • Pads. Give them J, K, L, Space, I, O, Command B and Command Z.
  • Knobs. Turn for frame-by-frame jogging and zoom, Dial for scrolling the timeline.
  • Limit. It sends keys only, so it cannot drive color wheels or faders.
For cutting, a pad controller and a free mapper are enough.
Can I use a MIDI controller with DaVinci Resolve?
Yes, for anything with a keyboard shortcut. An app such as InputConfig turns pads and knobs into Resolve's keys: transport, marks, cuts, undo and frame stepping.
Can a MIDI knob be a jog wheel in Resolve?
Yes. Set the knob to Turn mode with Right Arrow on clockwise and Left Arrow on counterclockwise, and it steps the playhead a frame at a time.
Can a MIDI controller control color wheels in Resolve?
Not through a keystroke mapper. Color wheels are not keyboard shortcuts. Dedicated panels and Resolve-specific tools do that.
Do I need a driver for my MIDI controller?
Not for a class-compliant USB or Bluetooth MIDI device, which is most of them.
Does it work in the free version of Resolve?
Yes. It sends ordinary keystrokes, which every edition of Resolve accepts.
Is it free?
InputConfig is free on the Mac App Store, with no account and nothing to buy inside it.
