Can a MIDI controller run Premiere Pro on a Mac?
Yes, for editing, through an app that turns each pad and knob into one of Premiere's keyboard shortcuts. InputConfig, the free Mac app I make, does the turning: pads run the transport, mark, cut and delete, and a knob steps the playhead a frame at a time like a jog wheel. It finds a class-compliant MIDI device over USB or Bluetooth MIDI with no driver.
The keys in this layout are from Adobe's list of Premiere keyboard shortcuts, read on October 7, 2026. They are the defaults, so if you have changed yours, use your own.
  1. Steps
  2. Map the pads to Premiere's shortcuts
  3. Choose a mode for each knob
  4. Put two cuts on one pad
  5. Know what a keystroke mapper cannot do in Premiere
  6. Share one controller between Premiere and a music app
  7. If a game controller is simpler
  8. The short version
  1. Connect the MIDI controller over USB or Bluetooth MIDI.
  2. In InputConfig, add a row, press Scan, and hit a pad.
  3. Pick the Premiere shortcut for that pad, such as Command K for Add Edit.
  4. Set a knob to Turn mode on the Left and Right arrow keys.
  5. Activate the preset and bring Premiere Pro to the front.
  • You: Add a row for each pad, press Scan, hit the pad, and pick the key.
  • InputConfig: Sends that key to Premiere whenever you hit the pad, and holds it for as long as the pad is held.
  • Check: With Premiere in front and the timeline active, hit the pad for Space and playback starts.
Pad or knobPremiere keyJob
Pad 1JShuttle in reverse
Pad 2KStop
Pad 3LShuttle forward
Pad 4SpacePlay and stop
Pad 5IMark In
Pad 6OMark Out
Pad 7Command KAdd Edit, the cut at the playhead
Pad 8Option DeleteRipple Delete
Pad 9MAdd Marker
Pad 10SemicolonLift
Pad 11ApostropheExtract
Pad 12Command ZUndo
Knob 1, Turn modeRight Arrow clockwise, Left Arrow counterclockwiseStep forward and backward a frame
Knob 2, Turn modeEquals clockwise, minus counterclockwiseZoom the timeline in and out
Knob 3, Dial modeHorizontal mouse wheelMove along the timeline, faster the further you turn
Shift Command K is Add Edit to All Tracks, which suits a hold on the same pad as Command K. Cut, ripple delete and a jog knob are most of a rough cut.
A row in the InputConfig editor with a MIDI note from a pad controller as the input and a keyboard shortcut as the output.
Figure 1. An InputConfig row with a MIDI pad's note as the input and a keyboard shortcut as the output.
InputConfig's editor with MIDI rows for Premiere Pro: each pad, key or knob on the left and the key or action it sends on the right.
Figure 2. The Premiere pads: shuttle, play, mark In and Out, add edit, ripple delete and add marker.
A knob can be read three ways:
  • Turn. Fires a short nudge every few steps of rotation, clockwise for one row and counterclockwise for the other. This is the mode for stepping.
  • Dial. Treats the center as rest, like a stick: the further from the center, the faster the output runs. This is the mode for scrolling.
  • Switch. Fires once past halfway, for pedals and buttons that send a Control Change.
Turn Step sets how far you turn for each frame. Set the knob to Turn mode on the arrow keys, and it behaves like a jog wheel. The built-in MIDI: Knob Deck preset has both kinds to copy from.
The Premiere Pro preset's page in InputConfig, with the Live Visualizer in its MIDI view showing a keyboard, dials and the last notes received.
Figure 3. The same preset's page. Turn a knob and watch its dial move here to see which CC number it sends.
Every row can carry a second action on a hold and a third on a double tap. A tap for Add Edit and a hold for Add Edit to All Tracks keeps both under one finger. A macro can chain keys in order, such as Mark In, Mark Out and Extract. One pad can hold a tap, a hold and a double tap. Hold and double-tap actions has the settings.
  • Mixer faders and effect knobs. They are not keys. Premiere has a Control Surface page in its settings for the hardware protocols Adobe supports, which is the route for faders.
  • Feedback. Premiere never tells the controller anything, so no pad lights to show a state.
  • Panels that are not in front. A shortcut acts on the active panel, so click the timeline once before you start.
If Premiere has a keyboard shortcut for it, a pad can do it.
If the same controller also plays instruments in a music app, give this preset an auto-switch entry for Premiere Pro. The pads send its shortcuts while it is in front, and the preset that was running before comes back when you leave. Turn automatic switching on in Settings, Advanced first. InputConfig reads a copy of the MIDI, so the music app still hears the notes. Turn on auto-switch so the pads are Premiere's only while Premiere is the app in front.
If you do not already own MIDI gear, a game controller in the off hand does the transport and marking jobs with no desk space. The Premiere Pro preset is ready in two clicks, and MIDI rows and controller rows can live in the same preset. A pad controller you already have on the desk can run the edit. The video editing controller guide compares Premiere Pro, Final Cut Pro and DaVinci Resolve row by row.
  • Pads. Give them J, K, L, Space, I, O, Command K, Option Delete and M.
  • Knobs. Turn for frame stepping and zoom, Dial for scrolling the timeline.
  • Limit. Keys only: faders go through Premiere's own Control Surface settings.
For a rough cut, a pad controller and a free mapper will do the job.
Can I use a MIDI controller with Premiere Pro?
Yes, for anything with a keyboard shortcut. An app such as InputConfig turns pads and knobs into Premiere's keys: transport, marks, Add Edit, ripple delete and frame stepping.
Can a MIDI knob be a jog wheel in Premiere Pro?
Yes. Set the knob to Turn mode with Right Arrow on clockwise and Left Arrow on counterclockwise, and it steps a frame at a time.
What is the shortcut to cut at the playhead in Premiere Pro?
Command K on a Mac, which is Add Edit. Shift Command K adds the edit to all tracks.
Can a MIDI fader control Premiere's audio mixer?
Not through a keystroke mapper. Premiere has Control Surface settings for the hardware protocols Adobe supports.
Do I need a driver for my MIDI controller?
Not for a class-compliant USB or Bluetooth MIDI device, which is most of them.
Is it free?
InputConfig is free on the Mac App Store, with no account and nothing to buy inside it.
