Brawlhalla controller not working on a Mac
Usually the fix is one of three checks: the Mac sees the pad, the pad was awake before the game launched, and the Steam Input override is set the other way. If none of those work, map the controller to Brawlhalla's keyboard keys, which always works. Brawlhalla is free, it is on the Mac through Steam, and it is a controller game on every other platform, but on a Mac a pad that does nothing in it is a common complaint, and PS5 pads come up most.
  1. Steps
  2. Check that the Mac sees the controller
  3. If the game still ignores the pad
  4. Why this happens more on a Mac
  5. Play it with keyboard keys
    1. Step 1: Write down the game's keys
    2. Step 2: Give every control a row
    3. Step 3: Give each row a key
    4. Step 4: Test every button
    5. Step 5: Let it switch on by itself
  6. If you hold a PS5 controller
  7. The short version
  1. Open System Settings, Game Controllers and press a button to confirm the Mac sees the pad.
  2. Quit Brawlhalla, wake the controller, and launch the game again from Steam.
  3. Flip the Steam Input override in Brawlhalla's Properties, Controller, and try Big Picture.
  4. If the game still ignores it, map the controller to Brawlhalla's keyboard keys with InputConfig.
  • You: Open System Settings, click Game Controllers in the sidebar, and press a button.
  • macOS: Lists each paired pad and lights up each button you press.
  • Check: If the controller is not there, or nothing lights up, it is a pairing problem. Forget it in Bluetooth and pair it again: PS5 pairing steps, Xbox pairing steps.
A pad still paired to a console keeps jumping back to it, so unpair it there first. If the buttons light up here, the Mac is fine and the problem is between Steam and the game.
  1. Connect it before you launch. Quit Brawlhalla completely, wake the controller, press a button, then launch the game from Steam. Some games only look for controllers at start-up, and a pad that fell asleep while the game was open may not be picked up again.
  2. Flip the Steam Input override. In the Steam library, right-click Brawlhalla, open Properties, then Controller, and try Disable Steam Input, relaunch, then try Enable. Why the Steam Input switch matters.
  3. Try Big Picture. Some players report that the game picked the pad up when launched from Steam's Big Picture mode.
  4. Look in Brawlhalla's own controls. If the game's controls page offers nothing for your controller, the game is not reading it, whatever macOS and Steam say. Go to play it with keyboard keys.
The first three are free to try and take a minute.
On an Apple silicon Mac, Brawlhalla runs through Rosetta 2, according to player reports on AppleGamingWiki, and reports of the game not seeing controllers on M1 Macs go back to 2021. The Mac build gets far less testing than the Windows one. None of that is something you can fix from your side, which is why the keyboard route exists.
Brawlhalla has full keyboard controls, and a keyboard is never undetected. InputConfig reads your controller and sends the keys the game already listens to, so Brawlhalla sees a keyboard and you hold the pad. It is free, it is on the Mac App Store, and I built it because my own hands need a controller for things that were never made for one.
There is no ready-made Brawlhalla layout in the app yet, so this one you set up yourself, once.
In Brawlhalla, open the controls settings and note the keyboard keys for move, jump, light attack, heavy attack, dodge and throw. Change any you like first.
  • You: In InputConfig, make a new preset. With your controller selected, choose Automatically insert available inputs.
  • InputConfig: Adds a row for every stick, trigger and button.
  • Check: Every control on your pad has a row waiting for a key.
A starting point you can rearrange to suit your hands:
  • Left stick and D-pad. The four movement keys.
  • Bottom face button. Jump.
  • Left face button. Light attack.
  • Top face button. Heavy attack.
  • Right face button. Dodge.
  • A bumper. Throw.
  • You: Press Activate, then in the game press each button once.
  • InputConfig: Sends the key on each row.
  • Check: Each press does one thing. If a press does two things, Brawlhalla is also reading the pad. Turn one of them off.
Add Brawlhalla to the preset's auto-switch list, and switch on automatic switching in Settings, Advanced. The preset turns on whenever the game is in front. Laying out every button at once and per-app auto-switch have the details.
An InputConfig preset with rows for a controller's left stick, face buttons and a bumper, each set to one of Brawlhalla's keyboard keys.
Figure 1. Every row sends one of the keys from Brawlhalla's controls page, so the game only ever sees a keyboard.
A DualSense pairs with a Mac by holding Create and the PS button until the light flashes. If it pairs but games ignore it, the PS5 controller not working on a Mac page goes through the other causes. The keyboard route above does not care which brand of pad you hold.
  • Check Game Controllers. If the buttons light up, the Mac sees the pad.
  • Relaunch and flip Steam Input. Connect the pad first, then try the override both ways.
  • Fall back to keys. Map the pad to Brawlhalla's keyboard controls.
The keyboard route is set up once and keeps working whatever Steam or the Mac build does.
Can you play Brawlhalla on a Mac?
Yes. Steam lists macOS for Brawlhalla, and it is free to play. On Apple silicon Macs it runs through Rosetta 2, according to player reports.
Why is my PS5 controller not working in Brawlhalla on Mac?
Check that System Settings, Game Controllers shows it, relaunch the game with the pad awake, and flip the Steam Input override for Brawlhalla. If the game still ignores it, map the pad to Brawlhalla's keyboard keys with a mapper such as InputConfig.
Does this work with an Xbox or Switch Pro controller?
Yes. The checks are the same, and the keyboard route works with any controller the Mac can connect to, because the game only ever sees key presses.
This page in other languages: العربية, Deutsch, Bahasa Indonesia, Nederlands, Tiếng Việt
