Presentation Remote preset
This preset ships inside InputConfig, free on the Mac App Store. You don't have to make an account, there are no subscriptions, and nothing is locked. Optimized for Apple silicon.
A game controller makes a good presentation clicker for a Mac. A and B go to the next and previous slide, X starts or advances the show with Space, Y sends B to blank the screen, Back / Share leaves the show, and the left stick moves the pointer with the bumpers as clicks. It covers Keynote, PowerPoint, and Google Slides with the keys they share.
A/B advance/back, X starts slideshow, left stick aims a pointer
Where it is in the app
Every binding
| Input | Sends | Options | Note |
| Left stick left | Mouse motion left (speed 10) | Pointer left | |
| Left stick right | Mouse motion right (speed 10) | Pointer right | |
| Left stick up | Mouse motion up (speed 10) | Pointer up | |
| Left stick down | Mouse motion down (speed 10) | Pointer down | |
| A / Cross | Right | Next slide (Right arrow) | |
| B / Circle | Left | Previous slide (Left arrow) | |
| X / Square | Space | Start or advance (Space) | |
| Y / Triangle | B | Blank the screen (B) | |
| LB / L1 | Left click | Left click | |
| RB / R1 | Right click | Right click | |
| Back / Share / Select | Escape | Leave the show (Escape) | |
| Start / Options | F5 | Start PowerPoint show (F5) |
12 rows. Button names are the Xbox / PlayStation pair the editor shows; a Switch Pro Controller fires by position. Options are the row settings that differ from the defaults.
Notes
- Hide the pointer. Turn on Hide cursor in the preset's automation section for the show.
- Take questions. Put Start Dictation on a spare button to speak notes as people ask.
Run through the deck once with the pad before the audience arrives.
Download
- Presentation Remote presetSlide navigation, laser pointer, blank screen 7 KB
