How to use Joy-Cons or a Switch Pro Controller as a MIDI controller on a Mac
Pair the Switch Pro Controller or the Joy-Cons with the Mac, open InputConfig, and turn on one of its built-in MIDI presets. The face buttons then play notes, the sticks send Control Change and pitch bend, and music apps see a MIDI input named InputConfig. Two things differ from other pads: ZL and ZR are on or off, not analog, and the face buttons are bound by position, not by letter.
I make InputConfig. It is free on the Mac App Store, with no account and nothing to buy inside it.
  1. Steps
  2. Set it up
  3. Mind the button positions
  4. Put expression on a stick, not a trigger
  5. Play one Joy-Con or a pair
  6. If the music app hears nothing
  7. What it cannot do
  8. The short version
  1. Pair the Switch Pro Controller or the Joy-Cons with the Mac over Bluetooth, on macOS 13 or later.
  2. Open InputConfig and activate the built-in preset MIDI: CC Dials or MIDI: DAW Performance.
  3. In the music app, enable the InputConfig MIDI input and arm an instrument track.
  4. Press the bottom face button, B, to play a note.
Set it up
  • You: Pair the controller, open InputConfig, and activate MIDI: DAW Performance from the built-in presets. Arm a software instrument track in the music app and press B, the bottom face button.
  • InputConfig: Publishes a MIDI source named InputConfig while it runs, and sends a note for as long as the button is held.
  • Check: The track's meter moves and you hear middle C.
  • Logic Pro and GarageBand. Nothing to switch on. They listen to every MIDI source, InputConfig included.
  • Ableton Live. In Settings, Link, Tempo and MIDI, switch on Track for the InputConfig input to play notes, and Remote to map controls.
  • FL Studio, Reaper, Bitwig and others. Enable the InputConfig input in the app's MIDI settings.
There is no IAC Driver to set up and no virtual MIDI cable to install. How to connect a Switch Pro Controller to a Mac and Joy-Cons have the pairing steps.
Gamepad Synth preset in the editor with note rows on the face buttons and CC rows on the triggers.
Figure 1. The Gamepad Synth preset in InputConfig: MIDI notes on the face buttons and CC on the triggers.
Nintendo prints B at the bottom and A on the right, the opposite of an Xbox pad. InputConfig binds by position, so a preset row labeled A / Cross fires on the bottom button, which a Switch controller calls B.
PositionPrinted on a Switch controllerSends, in MIDI: DAW Performance
BottomBNote C4 (60)
RightANote E4 (64)
LeftYNote G4 (67)
TopXNote C5 (72)
Right stick, left and rightPitch bend, down and up
Right stick, downCC 1, modulation
D-pad up, down, rightMIDI Start, Stop, Continue
Go by where the button is, not by the letter printed on it. To bind a row to a button of your choice, press Scan and press the button.
MIDI: DAW Performance drawn on a Switch Pro Controller in InputConfig's Live Visualizer.
Figure 2. MIDI: DAW Performance on a Switch Pro Controller. The notes sit on the face buttons by position, so read the drawing, not the letters you remember from an Xbox pad.
ZL and ZR on a Switch Pro Controller and on Joy-Cons are digital. A CC bound to one jumps from nothing to full, where an Xbox or PlayStation trigger would glide. The sticks are fully analog, so use them for anything that should move by degrees.
  • Sweeps and swells. MIDI: CC Dials puts CC 1, CC 11, CC 74 and CC 71 on the two sticks.
  • Notes and switches. ZL and ZR make good extra notes, or a CC that is either on or off, such as sustain, CC 64.
On a Nintendo pad the sticks are the faders and the triggers are buttons.
InputConfig's editor showing the MIDI rows of the MIDI: DAW Performance preset.
Figure 3. The preset's rows. On a Switch pad the triggers are plain buttons, so move the expression row to a stick, as this section says.
  • A pair. With both connected, macOS can show a combined Joy-Con Pair that behaves like a full-size gamepad, with two sticks and a full set of buttons.
  • One Joy-Con, sideways. Four face buttons, two rail buttons and a stick: four notes, two more on the rail, and pitch bend on the stick. Bind each stick direction with Scan, pushing the stick the way you want, and the sideways offset comes out right.
  • Two players. Each Joy-Con is its own controller, so two people can play one each.
Bindings made on the pair do not carry over to a single Joy-Con. Choose a pair or single Joy-Cons, and build the preset for that.
  1. Check InputConfig is running and the preset is active. The MIDI port exists only while the app runs.
  2. Open the Live Visualizer and press a button. If nothing lights, the Mac is not reading the controller.
  3. Enable the InputConfig input in the music app, and arm the track.
  4. Match the channel. A track that listens to one channel must be set to the channel in the row.
If you hear nothing, check for a track that is not armed or an input that is switched off before anything else. The Switch Pro Controller tester and the Joy-Con tester show whether the browser can read the pad at all.
What it cannot do
  • Analog triggers. ZL and ZR are on or off.
  • Rumble. macOS does not pass through the HD rumble of Nintendo controllers, so there is no vibration on a note. Motion rows read the Pro Controller's gyroscope, and a Joy-Con's when macOS reports it.
  • Velocity from the buttons. Each note plays at the velocity set in its row, from 1 to 127.
Buttons and sticks work in full, and that is enough for notes, bends and four controllers.
  • Pair. Pair it over Bluetooth, on macOS 13 or later.
  • Activate. Use MIDI: DAW Performance for notes and MIDI: CC Dials for knobs.
  • Remember. Go by the bottom button first, and put your sweeps on the sticks.
A Joy-Con is the smallest MIDI controller most people already own.
Can Joy-Cons be used as a MIDI controller on a Mac?
Yes. InputConfig, a free Mac app, sends MIDI notes from Joy-Con buttons and Control Change or pitch bend from the stick, through a MIDI port music apps can use.
Can a Switch Pro Controller send MIDI?
Yes, on a Mac with InputConfig. The buttons play notes and both sticks send Control Change or pitch bend that follows their position.
Why does my Switch controller's trigger jump from 0 to 127?
ZL and ZR are digital buttons, not analog triggers. Put controls that should move by degrees on a stick.
Can I use Joy-Con motion controls for MIDI on a Mac?
When macOS reports a Joy-Con's gyroscope and accelerometer, InputConfig's Motion rows read them, and a Motion row can send MIDI like any other row. Buttons and sticks always come through.
Why does pressing A play the wrong note?
InputConfig binds by position. A row labeled A / Cross fires on the bottom face button, which Nintendo prints as B. Press Scan on the row and press the button you want.
Do I need the IAC Driver?
No. InputConfig creates its own MIDI source, named InputConfig, whenever it runs.
