Built-in preset
MIDI: CC Dials preset
Download InputConfig on the Mac App StoreThis preset ships inside InputConfig, free on the Mac App Store. You don't have to make an account, there are no subscriptions, and nothing is locked. Optimized for Apple silicon.
This preset turns six analog controls into six continuous controllers: the sticks and triggers send CC values that follow their position, ready for a DAW's MIDI learn. Map a stick to a filter, a trigger to a send, and record the movement as automation.
Left stick X/Y = CC 1 / CC 11. Right stick X/Y = CC 74 / CC 71. Triggers = CC 7 / CC 10. Channel 1. Plug into any DAW's MIDI Learn for instant macro control.
Where it is in the app
Every binding
InputSendsOptionsNote
Left stick rightMIDI CC 1 channel 1variable sensitivity; deadzone 5%CC 1, modulation
Left stick leftMIDI CC 1 channel 1variable sensitivity; deadzone 5%CC 1, modulation
Left stick downMIDI CC 11 channel 1variable sensitivity; deadzone 5%CC 11, expression
Right stick rightMIDI CC 74 channel 1variable sensitivity; deadzone 5%CC 74, filter cutoff
Right stick downMIDI CC 71 channel 1variable sensitivity; deadzone 5%CC 71, resonance
Right triggerMIDI CC 7 channel 1variable sensitivity; deadzone 5%CC 7, volume
Left triggerMIDI CC 10 channel 1variable sensitivity; deadzone 5%CC 10, pan
7 rows. Button names are the Xbox / PlayStation pair the editor shows; a Switch Pro Controller fires by position. Options are the row settings that differ from the defaults.
Notes
  • Any CC number. Each row's CC number can be changed. The CC reference lists the conventional assignments.
  • Smooth values. Variable Sensitivity is what makes the value follow the control instead of jumping to full on a press.
Leave Variable Sensitivity on, or a stick becomes a switch.
Download
