What is the easiest mouse for an elderly person on a Mac?
There is no single best one. Usually the easiest mouse is the one they already have, set up properly: a bigger pointer, a slower tracking speed, and a slower double click. If the wrist, the grip, or the clicking is the real problem, a trackpad, a trackball, or a larger mouse can help. If no mouse works, a game controller can take its place. Any ordinary USB or Bluetooth mouse or trackball works on a Mac with no driver for pointing, clicking, and scrolling.
Change the settings before buying anything
- Bigger pointer: System Settings, Accessibility, Display, Pointer size.
- Slower pointer: System Settings, Mouse, Tracking speed.
- A double click that does not have to be quick: System Settings, Accessibility, Pointer Control, Double-click speed.
- Find a lost pointer: leave Shake mouse pointer to locate on, in the same Pointer settings.
The guide to setting up a Mac for an elderly parent covers text size, the Dock, and dictation too.
The options, and who each suits
| Option | Suits someone who | Watch out for |
| Trackpad | Finds pressing a button hard. Turn on Tap to click in System Settings, Trackpad, and a light tap clicks. | Needs a finger that glides steadily; a resting palm can move the pointer. |
| Large or ergonomic mouse | Already knows a mouse but finds a small one hard to grip. | Still needs a steady wrist and a firm click. |
| Trackball | Tires moving the whole arm. The hand stays still and a thumb or fingers roll the ball. | Takes a few days to learn; the buttons still need a press. |
| Game controller with InputConfig | Cannot get on with any mouse. It rests in two hands, a thumb moves the pointer, and a stick pushed gently moves it gently. | Needs half an hour of setup with them, and the free app. |
I have not tested particular brands, so this page names kinds of device, not models.
InputConfig is free on the Mac App Store. macOS 14 or later, no account, no tracking, open source.
When a controller is the answer
I built InputConfig because my own hands do not work well with a mouse. With it, a PlayStation or Xbox controller becomes the Mac's mouse: the left stick moves the pointer, a deadzone ignores a resting thumb, and a small number of buttons click, go back, and close pop-ups. Everything else can be left doing nothing, so a wrong press is harmless. The elderly parent guide has a ready layout, Easy Mac, to download, and the built-in Accessibility Pointer preset is a precise alternative. For a hand that shakes, see the tremor and limited mobility guide.
Extra buttons on a mouse
A mouse with side buttons can give them simple jobs, such as Back in Safari, without the maker's software: InputConfig reads extra mouse buttons and the scroll wheel as inputs. See mouse buttons and keys as shortcuts.
Is a trackpad or a mouse easier for seniors?
It depends on the hands. A trackpad with Tap to click needs no pressing, which helps weak fingers. A mouse suits someone who already knows one and has a steady wrist. Try both for a week if you can.
How do I make the mouse pointer bigger on a Mac?
System Settings, Accessibility, Display, then drag Pointer size to the right.
Can a game controller replace the mouse for my mother or father?
Yes, with InputConfig, which is free on the Mac App Store and needs macOS 14 or later. It adds to the mouse rather than replacing it, so both work at once while they learn.
Is there a mouse that steadies a tremor on a Mac?
InputConfig does not steady an ordinary mouse. It can make a controller stick ignore small shakes with a deadzone and slow the pointer near the centre. The tremor guide has settings to start from.
Free. macOS 14 or later. No account, nothing leaves your Mac. Open source on GitHub.
