How to play Sleeping Dogs on a Mac with a controller
Feral's Mac version of Sleeping Dogs: Definitive Edition supports gamepads. Its FAQ lists the pads Feral tested, with the PS4 and PS3 DualShock, the Xbox One controller on a USB cable and Logitech's F310, F510 and F710 among them. Feral's manual says gamepad controls cannot be customized. Keyboard controls can, under Options, Controller Layout.
I should say up front that I have not tested Sleeping Dogs myself. The facts and the default keys are from Feral's FAQ and manual for the game, which I read on October 7, 2026. If your pad does nothing in it, InputConfig, the free mapper I make, sends the game's keyboard and mouse controls from the pad.
  1. Steps
  2. Start with the game's own gamepad support
  3. If the pad does nothing
  4. Send the game its keys instead
  5. Build the layout
  6. Change a layout the game has fixed
  7. Use one route, not both
  8. The short version
  1. Connect the controller and check it under System Settings, Game Controllers.
  2. Quit the game, wake the controller, and open the game again.
  3. In Steam, try the game's Steam Input override both ways.
  4. If the game still ignores the pad, send its keyboard and mouse controls from the pad with a mapper.
Connect the pad before you start Sleeping Dogs. Feral's FAQ lists the gamepads it tested, the PS4 and PS3 DualShock, Xbox 360 controllers, the Xbox One controller on a USB cable, and Logitech's F310, F510 and F710 among them. It says to write to its pad support address about a gamepad that is not on the list. Newer pads such as the PS5 DualSense are not listed. I would start with a PS4 DualShock, because it is on Feral's tested list and a Mac pairs with it without any extra software. How to connect a PS4 controller to a Mac has the steps.
  1. The Mac sees the pad. Open System Settings, click Game Controllers, and press a button on the pad.
  2. Relaunch with the pad awake. Quit Sleeping Dogs, press a button on the controller, and open it again.
  3. Flip the Steam Input override. In the Steam library, right-click Sleeping Dogs, open Properties, then Controller, and try the other setting.
  4. Set a Logitech pad to D. Feral's FAQ says the game needs DirectInput mode, the D position on an F310, F510 or F710.
If nothing lights up there, Sleeping Dogs has no chance of seeing the pad either. Controller works in Steam but not in the game has more on the Steam layer.
Sleeping Dogs plays fully on a keyboard and mouse, and a keyboard is never undetected. InputConfig reads your controller and sends those keys and mouse moves, so Sleeping Dogs sees a keyboard while you hold the pad. These are the default keys from Feral's manual:
ActionKey
MoveW A S D
CameraMouse
Sprint or vaultShift
Light attackLeft mouse button
Heavy attackLeft mouse button, held
Counter, aim or lock onRight mouse button
GrappleF
Interact or enter a vehicleE
ReloadR
CoverControl
Driving: accelerate, brake, steerW, S, A and D
Driving: handbrakeSpace
Fighting is two mouse buttons and F, which is why it maps to a pad so easily.
Build the layout
  • You: In InputConfig, make a new preset. Set the left stick to WASD and the right stick to mouse movement.
  • InputConfig: Sends those keys and mouse moves while the preset is active.
  • Check: In Sleeping Dogs, the left stick walks and the right stick turns the camera.
  • Face buttons. The left mouse button to strike, the right to counter, F to grapple and E to interact.
  • Shoulders and stick click. Shift to sprint, Control for cover, R to reload.
  • Driving. The same left stick steers, since driving uses W, A, S and D. Put Space on a face button for the handbrake.
I would put Counter on the button under your thumb, because the fights are won on counters. Play any Mac game with a controller walks through a layout like this, and your first preset has the basics.
A Sleeping Dogs layout drawn on a DualSense Edge in InputConfig's Live Visualizer, with each control labeled with the key it sends.
Figure 1. Sleeping Dogs on a DualSense Edge: fighting, grappling and driving all share this one layout.
The Sleeping Dogs layout in InputConfig's editor, one row for each control and the key it sends.
Figure 2. The Sleeping Dogs rows. The stick rows send W, A, S and D, and the right stick moves the camera as a mouse.
Feral's manual says gamepad controls cannot be customized. Keyboard controls can, under Options, Controller Layout. A layout sent from a mapper is yours to edit: move a button, swap the triggers, or put a second action on a hold. Since Sleeping Dogs will not let you change its gamepad layout, a keyboard layout sent from the pad is the one you can edit. Hold and double tap covers the second action.
If Sleeping Dogs does read your controller, a mapper sending keys at the same time makes every press arrive twice. So pick one route. In InputConfig, a preset tied to the game only runs while that game is in front. If Sleeping Dogs already reads your pad, you do not need a mapper at all. Per-app switching can tie the preset to Sleeping Dogs.
  • Tested pads. Feral's FAQ lists the PS4 and PS3 DualShock, the Xbox One controller on USB, and Logitech pads.
  • Not working. Look in Game Controllers, relaunch Sleeping Dogs, then try the Steam Input override.
  • Fallback. Send Sleeping Dogs its keys and mouse moves from the pad.
Try your pad first, and if Sleeping Dogs will not listen, send it keys instead.
Does Sleeping Dogs on Mac support controllers?
Yes. Feral's FAQ for the Mac version of Sleeping Dogs lists the gamepads it tested, including the PS4 and PS3 DualShock, Xbox 360 controllers, the Xbox One controller over USB and Logitech pads.
Does a PS5 controller work with Sleeping Dogs on a Mac?
The DualSense is not on Feral's tested list for Sleeping Dogs, and I have not tested it. If the game ignores it, a mapper can send the game's keyboard and mouse controls from it.
Can I remap the controller in Sleeping Dogs on a Mac?
No. Feral's manual says gamepad controls cannot be customized. Keyboard controls can be, so a mapper that sends keys from the pad gives you a layout you can change.
Why is my controller not working in Sleeping Dogs on a Mac?
Check it under System Settings, Game Controllers, relaunch Sleeping Dogs with the pad awake, and try the Steam Input override both ways. If it still does nothing, send the game's keys from the pad.
Which keys does Sleeping Dogs use on a Mac?
By Feral's manual: W A S D to move, Shift to sprint, the left mouse button to attack, the right to counter, F to grapple, E to interact, and Space for the handbrake when driving.
