Can a MIDI controller run Lightroom Classic on a Mac?
Yes, through an app that turns each pad and knob into one of Lightroom Classic's keyboard shortcuts. Lightroom Classic has no MIDI settings of its own. InputConfig, the free Mac app I make, does the turning: pads flag, rate and step through photos, and two knobs reach every slider in the Basic panel, one to choose the slider and one to move it. For a knob per slider across the whole Develop module, the free plug-in MIDI2LR goes further, and it has its own section below.
The keys in this layout come from Adobe's shortcut list for Lightroom Classic, read on October 7, 2026.
- Connect the MIDI controller over USB or Bluetooth MIDI.
- In InputConfig, add a row, press Scan, and hit a pad.
- Pick the Lightroom key for that pad, such as P to flag a pick.
- Set two knobs to Turn mode: one on period and comma, one on plus and minus.
- Activate the preset and bring Lightroom Classic to the front.
Map the pads for culling
- You: Add a row for each pad, press Scan, hit the pad, and pick the key.
- InputConfig: Sends that key to Lightroom Classic whenever you hit the pad.
- Check: With a photo selected in the Library, hit the pad for P and the pick flag appears.
| Pad | Lightroom key | Job |
| Pad 1 | Left Arrow | Previous photo |
| Pad 2 | Right Arrow | Next photo |
| Pad 3 | P | Flag as a pick |
| Pad 4 | X | Flag as a reject |
| Pad 5 | U | Remove the flag |
| Pads 6 to 10 | 1 to 5 | Set the star rating |
| Pad 11 | 0 | Remove the star rating |
| Pad 12 | D | Open the photo in Develop |
| Pad 13 | G | Back to the Library grid |
| Pad 14 | Y | Before and after, side by side |
| Pad 15 | Command U | Auto tone |
| Pad 16 | Command Z | Undo |
Adobe's list also has a version of each flag and rating that moves to the next photo: hold Shift. Put Shift P and Shift X on two pads and a whole shoot can be culled with two fingers. Flag and advance in one press is the fastest way through a shoot.
Reach every Basic slider with two knobs
| Knob | Mode | Keys | Job |
| Knob 1 | Turn | Period clockwise, comma counterclockwise | Choose the Basic panel setting: Exposure, Contrast and so on down the panel |
| Knob 2 | Turn | Plus clockwise, minus counterclockwise | Move the chosen slider in small steps |
| Knob 3 | Turn | Shift plus clockwise, Shift minus counterclockwise | Move it in larger steps |
In the Develop module, period and comma cycle forward and backward through the Basic panel's settings, and plus and minus move whichever one is selected. Adobe lists Up Arrow and Down Arrow as doing the same as plus and minus. One knob chooses the slider and the next one turns it. For a slider outside the Basic panel, select it with the mouse first, and the plus and minus knob moves that one.
Choose a mode for each knob
A knob can be read three ways:
- Turn. Fires a short nudge every few steps of rotation, clockwise for one row and counterclockwise for the other. This is the mode for stepping.
- Dial. Treats the center as rest, like a stick: the further from the center, the faster the output runs. This is the mode for scrolling.
- Switch. Fires once past halfway, for pedals and buttons that send a Control Change.
Turn Step sets how far you turn for each press, so a slider can be made coarse or fine. To find what a knob sends, open the Live Visualizer's MIDI view and turn it. The built-in MIDI: Knob Deck preset has a Turn knob and a Dial knob to copy from.
Know when MIDI2LR is the better tool
MIDI2LR is an application and plug-in made for this one job, offered as a free download. Its page describes it as translating MIDI commands into Lightroom actions, with versions 5 and later supporting Lightroom Classic 11 and later, on macOS including Apple silicon. It talks to Lightroom directly, so a knob can be tied to one slider, where a keystroke mapper can only press keys.
- Choose MIDI2LR. If you want a physical knob for each Develop slider and you work mostly in Lightroom.
- Choose InputConfig. If you want the same controller to work in every app, to cull with pads, or to use a game controller or a foot pedal beside it.
A plug-in can set a slider, and a mapper can press the keys that move it. The two can run together, on different pads and knobs.
Share one controller between Lightroom and a music app
If the same controller also plays instruments in a music app, give this preset an auto-switch entry for Lightroom Classic. The pads send its shortcuts while it is in front, and the preset that was running before comes back when you leave. Turn automatic switching on in Settings, Advanced first. InputConfig reads a copy of the MIDI, so the music app still hears the notes.
Auto-switch hands the pads to Lightroom only while it is in front.
If a game controller is simpler
Culling needs only a handful of buttons, and a game controller in one hand has them. The Lightroom preset flips photos on the stick, rates and flags on the D-pad and opens Develop on a face button. MIDI rows and controller rows can live in the same preset. I would cull with a controller and develop with a knob box. The photo editing guide has more layouts.
- Pads. Give them the arrows, P, X, U, 1 to 5, D, G and Y.
- Knobs. Period and comma choose a Basic slider, plus and minus move it.
- Deeper. MIDI2LR ties a knob to a slider directly.
Lightroom Classic listens to keys, so any pad or knob that sends a key can drive it.
Does Lightroom Classic support MIDI controllers?
Not by itself. It has no MIDI settings. A MIDI controller needs an app that turns pads and knobs into Lightroom's keyboard shortcuts, or the MIDI2LR plug-in.
Can a MIDI knob move a Lightroom slider?
Yes. In the Develop module, plus and minus move the selected slider, so a knob that sends those keys turns it. Period and comma choose which Basic panel slider is selected.
What is MIDI2LR?
An application and plug-in, free to download, that translates MIDI commands into Lightroom Classic actions on macOS and Windows. It can tie a knob to a specific slider.
What is the best MIDI controller for Lightroom?
For culling, anything with eight or more pads. For developing, one with several knobs. InputConfig reads endless encoders in absolute mode, so set them that way.
Does this work with Lightroom, not Classic?
The keys here are from Adobe's list for Lightroom Classic. Check the shortcut list of the Lightroom you use before copying the layout.
Is it free?
InputConfig is free on the Mac App Store, with no account and nothing to buy inside it. MIDI2LR is free as well.
