Built-in preset
One-Stick Driving preset
One-Stick Driving runs the whole car from one joystick, for the PlayStation Access Controller, the Xbox Adaptive Controller, or any single stick. Push forward to accelerate, pull back to brake, left and right to steer, and snap the stick back twice to shift into Reverse. Let go and the car slows on its own, the way a power chair stops when you release the stick.
This preset ships inside InputConfig, free on the Mac App Store. macOS 14 or later, no account, no tracking, open source.
The stick drives (see the One-Stick Driving section); sockets are handbrake, horn, boost, reset, gears, camera, rewind
Where it is in the app
Every binding
| Input | Sends | Options | Note |
| A / Cross | Space | Cross: handbrake (Space) | |
| B / Circle | H | Circle: horn (H) | |
| X / Square | Shift | Square: boost (Shift) | |
| Y / Triangle | R | Triangle: reset the car (R) | |
| LB / L1 | Q | L1: shift down (Q) | |
| RB / R1 | E | R1: shift up (E) | |
| LT / L2 (digital) | C | L2: change camera (C) | |
| RT / R2 (digital) | Tab | R2: rewind / flashback (Tab) | |
| Back / Share / Select | Escape | Create: pause (Escape) | |
| Start / Options | Return | Options: confirm (Return) |
10 rows. Button names are the Xbox / PlayStation pair the editor shows; a Switch Pro Controller fires by position. Options are the row settings that differ from the defaults.
One-stick driving
This preset has one-stick driving switched on: the left stick steers by the A and D keys, forward presses W and back presses S, and 2 quick snaps back within 700 ms shift into reverse.
Notes
- The stick is not in the rows. The One-Stick Driving section at the bottom of the editor owns it: stick and slot, deadzone, steering and throttle curves, keys or mouse steering, the coast brake, and the reverse gesture.
- The rows are the buttons. Handbrake, horn, boost, reset, gears, camera and rewind.
- Access Controller base profile. Only Cross (the center button), Circle (socket 5) and Options (socket 7) send.
- The game's own keys. Change the letters to match them.
Tune the stick in the One-Stick Driving section, not in the rows.
Download
- One-Stick Driving presetSteer, gas, brake, and reverse from one joystick 7 KB
Free. macOS 14 or later. No account, nothing leaves your Mac. Open source on GitHub.
