Why a controller needs Input Monitoring on a Mac
Because that controller is also a keyboard. Some arcade sticks, leverless controllers, macro pads and adapters present a small keyboard or keypad to the Mac beside the gamepad, and macOS puts anything that can type behind the Input Monitoring permission. An app that wants to read such a device directly needs that switch, even for the gamepad half.
Ordinary PlayStation, Xbox and Switch controllers are not affected: macOS reads those through its own controller support, with no permission at all. InputConfig, the free mapper I make, never asks for Input Monitoring. It tells you when a controller needs it and leaves the choice to you.
  1. Check whether your controller is one of them
  2. Confirm this is the problem
  3. Turn on Input Monitoring for InputConfig
    1. Step 1: Open the setting
    2. Step 2: Turn on the switch
    3. Step 3: Switch back
  4. If it still does not appear
  5. Know what you are allowing
  6. If you would rather not allow it
  7. Other apps that ask for it
  8. The short version
These are the controllers that carry a keyboard:
  • Arcade sticks and leverless controllers. Some firmware adds a keyboard, often for menu buttons or a keyboard mode.
  • Macro pads and button boxes. They send keys and also report buttons.
  • Other controllers and adapters. Any device that reports a keyboard or keypad alongside its buttons.
  • The 2026 Steam Controller (experimental). Over Bluetooth, macOS can present it together with its lizard-mode keyboard. The Steam Controller page covers that case.
macOS also marks some devices as needing authorization on its own. Either way the rule is the same: no Input Monitoring, no direct reading.
The sign is a controller that is plugged in, may even type, and never appears at the top of InputConfig's sidebar.
  • You: Open InputConfig, Devices in the menu bar.
  • InputConfig: Lists a controller held back by this permission as its name followed by (needs Input Monitoring).
  • Check: If you see that mark, the next section is your fix.
InputConfig's Devices menu listing an arcade stick marked needs Input Monitoring.
Figure 1. A controller that also presents a keyboard is marked in the Devices menu, and clicking it opens the right pane of System Settings.
With Show the activity log turned on in Settings, Advanced, the log at the bottom of the main window also says the device acts as a keyboard, so macOS lets InputConfig read it only with Input Monitoring.
If the Devices menu shows the controller grayed out with a different reason, such as an Xbox 360 style pad, Input Monitoring will not help. Xbox 360 controllers on a Mac explains that one. The Devices menu names the reason, so read it before changing any setting.
  • You: In InputConfig, open Devices in the InputConfig menu and click the controller marked (needs Input Monitoring).
  • macOS: Opens System Settings at Privacy & Security, Input Monitoring.
  • Check: You are on the Input Monitoring list. You can also go there yourself.
System Settings: The pane to open by hand.
System Settings, Privacy & Security, Input Monitoring
What happens: You see every app that may read input devices, each with a switch.
  • You: Turn on the switch next to InputConfig. If InputConfig is not in the list, click the add button under the list and choose InputConfig from Applications.
  • macOS: Lets InputConfig open controllers that carry a keyboard.
  • Check: The switch next to InputConfig is on.
Step 3: Switch back
  • You: Switch back to InputConfig.
  • InputConfig: Checks again each time it comes to the front and starts reading the controller, with no need to unplug it.
  • Check: The controller now appears at the top of the sidebar.
One switch, then bring InputConfig to the front, and the controller is read.
  1. Bring InputConfig to the front. It checks the permission again each time it does.
  2. Quit and reopen InputConfig. That reads the permission fresh.
  3. Read the Devices menu again. If the mark has gone but the entry is grayed out with another reason, the controller has a different problem, such as a protocol macOS cannot read. The arcade stick page has the modes by maker.
You never need to unplug the controller for the permission to take effect.
Input Monitoring lets an app read input from your keyboard and other input devices while you use other apps. That is a real permission, so give it only to apps you trust.
  • What changes. macOS lets InputConfig open the controllers that carry a keyboard. Nothing else moves.
  • What stays the same. Your Mac's own keyboard is still read the way it was, through the Accessibility permission and only while a preset or Scan uses it. That reading is listen-only, so a bound key still types as normal, and keys from every keyboard count as the same key.
  • What you can check. The Mac App Store build is sandboxed with no permission to use the network, and the source is on GitHub.
  • How to undo it. Turn the switch off later and the controller simply stops being read directly. Nothing else in the app changes.
The permission adds one thing, reading keyboard-type controllers, and you can take it back at any time.
There are three ways around it, from least effort to most:
  1. Use its keys as they are. If the stick types keys, those keys still reach presets as Keyboard Key inputs through Accessibility, so a row can add an action to them. They also keep typing their own key, since InputConfig listens to keys rather than replacing them.
  2. Change the controller's mode. Many sticks have a PC, DirectInput or Switch mode without the keyboard part. The arcade stick page has the modes by maker.
  3. Use the game's own controls. A game or emulator that reads the device itself does not need InputConfig at all.
Switching the stick to a mode without a keyboard avoids the question entirely.
Input Monitoring comes up with controllers for other reasons too:
Those are their own requirements. How Input Monitoring differs from Accessibility, and how to judge any app that asks for either, is on the Accessibility permission on a Mac. Each app asks for its own reasons, so allow it app by app.
  • Why. The controller also reports a keyboard, and macOS guards anything that can type.
  • How to tell. InputConfig, Devices shows the controller with (needs Input Monitoring).
  • The fix. Click that entry, turn on InputConfig in Input Monitoring, and switch back.
  • The alternative. Put the stick in a mode without a keyboard, or use its keys as they are.
Ordinary game controllers never need this permission, and only the ones that can type do.
Does InputConfig need Input Monitoring?
Only for a controller that also presents itself as a keyboard, such as some arcade sticks and macro pads. Game controllers, MIDI devices and your Mac's own keyboard and mouse work without it. InputConfig never asks for it. The Devices menu tells you when a controller needs it.
Is it safe to allow Input Monitoring?
It lets an app read what you type while you use other apps, so allow it only for apps you trust. You can turn it off again at any time in System Settings, Privacy and Security, Input Monitoring.
Why does my arcade stick not show up in InputConfig?
Usually one of two things. In Xbox or XInput mode most sticks speak a protocol macOS cannot read. Switch to PC, DirectInput or Switch mode. If the stick also has a keyboard part, it needs Input Monitoring. The InputConfig, Devices menu shows which.
Do I have to restart after allowing Input Monitoring?
Usually not. InputConfig checks again when it comes back to the front and starts reading the controller. If it still does not appear, quit and reopen InputConfig.
What is the difference between Input Monitoring and Accessibility?
Accessibility lets an app control the Mac, such as sending keys and clicks. Input Monitoring lets it read input devices directly. A mapper needs Accessibility to send anything. InputConfig needs Input Monitoring only for controllers that carry a keyboard.
