Giving the right Command and Option keys their own job
The right Command and Option keys can have jobs of their own, but not through System Settings, whose Modifier Keys setting treats both sides as one key. There are two ways around that. You can turn the right-hand key into a different key, with a command built into macOS or with Karabiner-Elements. Or you can keep it as a modifier and give it an extra job when you hold it or double tap it, which is what InputConfig, the free app I make, does. Pick by whether you still want the key to work as Command. Most people never use the right-hand Command, Option or Shift, so they are good keys to put to work.
Know what macOS does on its own
System Settings, Keyboard, Keyboard Shortcuts, Modifier Keys swaps Caps Lock, Control, Option, Command and Globe, per keyboard, but always both sides together. Caps Lock to Escape is in that list, so that common request needs no app at all.
If all you want is Dictation from a modifier, look first at System Settings, Keyboard, Dictation, Shortcut: one of its choices is pressing Control twice.
Keep it as Command and add a job when held
InputConfig reads each side of every modifier separately, and listens alongside macOS, so a right-hand key keeps working in every shortcut. The built-in Modifier Holds preset gives the right-hand keys a job only when held on their own or double tapped:
| Key | Held (450 ms) | Double tapped |
| Right Command | Spotlight | Launchpad |
| Right Option | Start Dictation | |
| Right Shift | Mission Control |
- Install InputConfig from the Mac App Store and allow Accessibility access.
- Open the built-in Modifier Holds preset, or add a row, press Scan and press Right Command.
- In the row's Options, turn on a hold action or a double-tap action and pick what it does.
- You: Activate the preset and hold Right Command on its own.
- InputConfig: Opens Spotlight once the key has been held for 450 ms. A plain press does nothing extra.
- Check: Command C with the right-hand key still copies.
Change any output to Open App, a macro, Type Text, a Siri Shortcut or anything else in the list, and change the timing in the row's Options. Every keyboard reports to InputConfig as one device, so the same right-hand key on an external keyboard does the same job.
Watch for the one catch
The hold fires as soon as the key has been down past the threshold, even if you press another key meanwhile. Hold Right Command through a slow Command Tab and Spotlight opens as well. Use the left-hand key for long shortcuts, or raise the hold to around 700 ms.
Turn it into a different key
InputConfig cannot do this part, because it adds to a key rather than replacing it. macOS can, with the built-in hidutil command in Terminal. It lasts until the next restart.
Terminal: Turn Right Command into Right Option.
hidutil property --set '{"UserKeyMapping":[{"HIDKeyboardModifierMappingSrc":0x7000000E7,"HIDKeyboardModifierMappingDst":0x7000000E6}]}'What happens: Right Command acts as Right Option until the next restart.
Terminal: Turn Right Command into F18, a key nothing uses.
hidutil property --set '{"UserKeyMapping":[{"HIDKeyboardModifierMappingSrc":0x7000000E7,"HIDKeyboardModifierMappingDst":0x70000006D}]}'What happens: Right Command sends F18, which InputConfig can then give up to four jobs.
Terminal: Put the keyboard back to normal.
hidutil property --set '{"UserKeyMapping":[]}'What happens: Every key does its own job again.
To keep a remap after a restart, or to have a key do one thing when tapped and another when held while still acting as a modifier, use Karabiner-Elements. It is free and open source, and it installs a driver that macOS asks you to approve.
- A different key, for good. Use Karabiner-Elements.
- A remap to try, nothing installed. Use hidutil, which lasts until the next restart.
- Still Command, plus a job when held. Use InputConfig's Modifier Holds.
They combine: with Right Command sent as F18 by hidutil, InputConfig can make a tap, a hold, a double tap and a triple tap on it four different things. Decide first whether the key should still be Command.
Can I remap only the right Command key on a Mac?
Not in System Settings, which changes both sides together. The built-in hidutil command can, until the next restart, and Karabiner-Elements can permanently.
Does InputConfig stop Right Command from working as Command?
No. It listens alongside macOS, so the key works in every shortcut as before. It only adds a job when the key is held on its own or double tapped.
Can InputConfig make a Hyper key?
No. A Hyper key replaces what Caps Lock does, and InputConfig cannot take a key's own job away. Karabiner-Elements or the Hyperkey app do that.
Can a double press of Command do something?
Yes. Give the Right Command row a double-tap action in InputConfig. The window is 300 ms in Modifier Holds and can be changed in the row's Options.
Does hidutil survive a restart?
No. The mapping clears when the Mac restarts, which makes it a safe way to try a remap. Run the command again, or use Karabiner-Elements, to keep it.
