Is there a MIDI Mixer for Mac?
MIDI Mixer is made for Windows. MIDI Mixer's own page describes it as controlling Windows volumes with MIDI, and it mentions no Mac version. On a Mac, InputConfig, the free app I make, turns a MIDI knob or fader into the system volume, one to one, and puts mute, play and pause and track skipping on pads. It does not set the volume of one app at a time, which is the part of MIDI Mixer a Mac has no direct match for.
I read MIDI Mixer's page on October 7, 2026. What follows is what works on a Mac today.
  1. Steps
  2. Make a knob the Mac's volume
  3. Put mute and the media keys on pads
  4. Know what it does not do
  5. Get closer to a mixer for each app
  6. Use the rest of the controller
  7. The short version
  1. Connect the MIDI controller and open InputConfig.
  2. Add a row, press Scan, and move the knob or fader.
  3. Choose System Volume as the output.
  4. Activate the preset and move the knob.
  • You: Add a row, press Scan, and move the knob or fader. Choose System Volume as the output.
  • InputConfig: Sets the Mac's volume to the position of the control, all the way down at one end and all the way up at the other.
  • Check: Move the fader and the Mac's volume follows it.
System Volume takes over only once you move the control, so plugging the controller in does not yank the volume to wherever the fader happens to sit. A fader on the desk beats hunting for the volume keys. System functions lists the Mac's other controls.
A row in the InputConfig editor with a MIDI note from a pad controller as the input and a keyboard shortcut as the output.
Figure 1. An InputConfig row with a MIDI pad's note as the input and a keyboard shortcut as the output.
The MIDI Mixer preset's page in InputConfig, with the Live Visualizer in its MIDI view showing a keyboard, dials and the last notes received.
Figure 2. The mixer preset's page. A knob that jumps instead of nudging is in the wrong Knob mode, and the dial here shows it.
Pad or knobOutputJob
Pad 1Play / PausePause whatever is playing
Pad 2 and 3Next Track, Previous TrackSkip
Pad 4Mute / UnmuteSilence the Mac and bring it back
A second knob, Turn modeVolume Up clockwise, Volume Down counterclockwiseStep the volume, for an endless knob
A third knob, Turn modeBrightness Up and Brightness DownThe display's brightness
These are sent as the Mac's real media keys, so they work with Music, Spotify, a browser tab or whatever else is playing. Media keys act on whatever is playing, with no setup for each app. The built-in MIDI: Media Deck preset is this layout, with the volume fader from the section above, ready to re-scan onto your own controller.
InputConfig's editor with MIDI rows for MIDI Mixer: each pad, key or knob on the left and the key or action it sends on the right.
Figure 3. Four pads for play, next, previous and mute, then knob rows that nudge the Mac's volume and brightness one step per click.
  • Volume for one app. macOS has one system volume and no mixer for individual apps, and InputConfig does not add one.
  • Switching output devices. It has no output of its own for choosing the Mac's sound device.
  • Lighting the controller. It cannot light pads or move motor faders.
One fader for the whole Mac is what it offers, not a fader for each app.
Many apps have their own volume shortcut, and a knob can send it. In the Music app, Command Up Arrow and Command Down Arrow change Music's own volume. Set a knob to Turn mode with those two shortcuts, and give the preset an auto-switch entry for Music. While Music is in front, the knob moves Music's volume and leaves the system volume alone. A shortcut reaches an app's own volume only while that app is in front. It is a partial answer, and I would rather say so.
  • Pads as shortcuts. Any pad can send a key, a macro, a Siri Shortcut or open an app.
  • A pedal as push to talk. A sustain pedal can hold a key down for as long as your foot is on it.
  • Scenes for streaming. A MIDI controller for OBS puts scene switches on pads.
The volume fader is one row, and the other pads are free for anything else. A MIDI controller as a macro pad and control surface builds a full layout.
  • MIDI Mixer. It is a Windows app.
  • On a Mac. InputConfig makes a knob the system volume, with mute and media keys on pads.
  • Not included. It does not give you a separate volume for each app.
For the Mac's own volume, one row and one knob are all it takes.
Is MIDI Mixer available for Mac?
Its own page describes it as controlling Windows volumes and mentions no Mac version.
How do I control Mac volume with a MIDI controller?
In InputConfig, a free Mac app, add a row, press Scan, move the knob or fader, and choose System Volume. The Mac's volume then follows the control.
Can a MIDI controller change the volume of one app on a Mac?
Not directly. macOS has a single system volume. A knob can send an app's own volume shortcut while that app is in front, which works for apps that have one.
Can a MIDI pad mute the Mac?
Yes. Give the pad the Mute system function. Play / Pause, Next Track and Previous Track work the same way.
Will the volume jump when I plug the controller in?
No. System Volume takes over only once you move the knob or fader.
Is it free?
InputConfig is free on the Mac App Store, with no account and nothing to buy inside it.
