Can a MIDI controller control OBS on a Mac?
Yes. Give each pad a key that no keyboard has, F13 to F19, and set those keys as hotkeys in OBS. InputConfig, the free Mac app I make, sends the key when the pad is hit, and OBS switches the scene, mutes the microphone or starts the recording. No OBS plug-in is involved, so the same pads work in any app with hotkey fields.
Two limits come first: OBS never tells the controller which scene is live, and InputConfig cannot light a pad controller's pads.
  1. Steps
  2. Give each pad a key nothing else uses
  3. Set the hotkeys in OBS
  4. Put the stream and the recording on a hold
  5. Use the knobs and the other pads
  6. Know what it cannot do
  7. Keep playing music on the same controller
  8. The short version
  1. Connect the MIDI controller and open InputConfig.
  2. Add a row for each pad, press Scan, hit the pad, and give it a key from F13 to F19.
  3. Activate the preset.
  4. In OBS, open Settings, Hotkeys, click a field and hit the pad for it.
  5. Click Apply.
  • You: Add a row for each pad, press Scan, hit the pad, and choose a key from F13 to F19.
  • InputConfig: Sends a real F13 when that pad is hit, as if a keyboard had the key.
  • Check: The Live Visualizer lights the pad, and the row shows the key.
OBS ships with no hotkeys set, so you choose them. F13 to F19 exist in macOS and no app uses them by default, which means a scene hotkey can never collide with a shortcut in a game or an editor. A key no keyboard sends is a hotkey nothing else can trigger by accident.
A row in the InputConfig editor with a MIDI note from a pad controller as the input and a keyboard shortcut as the output.
Figure 1. An InputConfig row with a MIDI pad's note as the input and a keyboard shortcut as the output.
InputConfig's editor with MIDI rows for OBS: each pad, key or knob on the left and the key or action it sends on the right.
Figure 2. Each pad sends one of F13 to F19, keys no other app uses. Pads 6 and 7 fire only on a hold, so a stray tap cannot end a stream.
  1. With the preset active, open OBS, Settings, Hotkeys.
  2. Click in the field for a scene, such as Switch to scene, and hit the pad you want for it.
  3. Repeat for each scene, for Mute, and for Start and Stop Recording.
  4. Click Apply.
PadKeyA typical job
Pad 1F13Starting scene
Pad 2F14Main scene
Pad 3F15Break scene
Pad 4F19Ending scene
Pad 5F16Mute the microphone
Pad 6, on a holdF17Start and stop streaming
Pad 7, on a holdF18Start and stop recording
OBS captures the pad's key exactly as if you had pressed it on a keyboard.
A row can fire on a hold instead of a tap. Set the pads for streaming and recording to fire after a one second hold, so a stray touch cannot end a stream. A row can also speak a word when it fires, so you hear Recording without looking at OBS. Anything you cannot take back belongs on a hold. Hold and double-tap actions and spoken feedback have the settings.
  • A knob for the Mac's volume. System Volume follows a knob or a fader one to one.
  • Pads for everything outside OBS. A Siri Shortcut for the lights, Open App, media keys, or a typed line of text for chat.
  • A pedal for push to talk. A sustain pedal held down holds the talk key down.
A keystroke cannot move a fader in OBS's audio mixer, so a knob controls the Mac's volume, not a single OBS source. Pads do everything OBS has a hotkey for, and a fader in OBS's mixer is not one of them.
The OBS preset's page in InputConfig, with the Live Visualizer in its MIDI view showing a keyboard, dials and the last notes received.
Figure 3. The OBS pads in the Live Visualizer's MIDI view. Press a pad and its note lights on the keyboard before OBS ever sees a key.
  • Show which scene is live. There is no link from OBS back to the controller.
  • Light the pads. InputConfig sends MIDI only through its own virtual port, so it cannot light a pad controller's pads.
  • Put pictures on keys. Pads have none. A strip of tape and a pen does the job.
If you need a live status on every key, a Stream Deck or an OBS plug-in is the right tool. The free Stream Deck alternative guide compares the options and has a ready preset.
A pad types nothing on its own, so no stray letter leaks into the stream, and the music app still hears every pad, because InputConfig reads a copy of the MIDI. Use a bank of pads or a MIDI channel that the music app ignores for the OBS rows. One controller can be a drum pad and a scene switcher, on different pads. A MIDI controller as a macro pad shows how to split one.
  • In InputConfig. Scan each pad and give it F13 to F19.
  • In OBS. Open Settings, Hotkeys, click a field, hit the pad, and press Apply.
  • Limits. No live status and no pad lights.
A pad controller you already own is a free scene switcher.
Can I use a MIDI controller as a Stream Deck?
For the buttons, yes. On a Mac, InputConfig turns each pad into a hotkey, a Siri Shortcut, an app launch or a media key. The pads have no screens, and they cannot show which scene is live.
Does OBS support MIDI on a Mac without a plug-in?
OBS takes hotkeys. A MIDI pad reaches it by sending a key that you have set as a hotkey in OBS, Settings, Hotkeys, which needs no OBS plug-in.
Can a MIDI fader control an OBS audio source?
Not through hotkeys. A keystroke cannot move a mixer fader. A knob can control the Mac's system volume.
Why use F13 to F19?
macOS has those keys, no app uses them by default, and most keyboards do not have them, so nothing else can trigger your scene hotkeys by accident.
Will the pad work while a game is in front?
Yes. InputConfig sends the key whichever app is in front, so a scene can be switched from inside a game.
Is it free?
InputConfig is free on the Mac App Store, with no account and nothing to buy inside it.
