Elden Ring Nightreign on a Mac with a controller
The Elden Ring Nightreign layout is built into InputConfig, free on the Mac App Store. You don't have to make an account, there are no subscriptions, and nothing is locked. Optimized for Apple silicon.
On a Mac: No Mac version. It can stream to a Mac from a Windows PC you own, or from a cloud service such as GeForce NOW if it carries the game. The stream normally passes a controller to the game's native scheme. This layout is for streams that do not see the pad.
Yes, Elden Ring Nightreign plays on a Mac with a controller, streamed from a Windows PC or a service such as GeForce NOW if it carries the game. Nightreign shares Elden Ring's keyboard scheme, so this layout follows Elden Ring's, and it is for a stream that misses your pad. The pace is faster than Elden Ring's, and a stream shows it in the boss fights.
- Move and camera. The left stick walks on W, A, S and D. The right stick moves the mouse at speed 18 across and 14 up and down.
- Fight. The right trigger attacks (left click), the left trigger guards (right click). The skill on the right bumper (Q).
- Face buttons. Roll, dodge and sprint on the bottom (Space), interact on the right (E), use item on the left (R), the event and jump action on the top (F).
- Clicks and menu. Crouch on the left stick click (V), lock on with the right (O). Menu on Start (Escape).
The event action has a face button, because the game keeps asking for it.
- Ping. It is a co-op game, and the D-pad is empty. Put the ping key there.
- Camera. Pointer speed on the preset's page scales all four camera rows together.
- A buzz on the flask. Turn on Vibrate in the use item row's Options.
Ping on the D-pad is the row your teammates will notice.
A stream normally passes your controller to Elden Ring Nightreign's own scheme. Climb this ladder, smallest step first:
- Try the stream on its own. Leave the preset off and push the left stick. If you move, use the game's own scheme.
- Activate the layout. If nothing moves, press Activate, and the pad sends the keys and clicks above.
- Turn one off if presses double. If one press does two things, the game reads the pad and the preset at once. Press Deactivate.
Nightreign plays best on the pad the stream passes through, and this layout is for when it does not.
Elden Ring Nightreign controller support: controller or keyboard
Steam's store page lists full controller support for Elden Ring Nightreign, so the game was made to be played on a controller, menus included. A keyboard and mouse work as well, and the choice is yours. On a Mac, use the game's own controller support first when it sees your pad; this layout is for a pad it does not see, or for buttons it will not let you move. Full support listed means the controller is a first-class way to play Elden Ring Nightreign.
If your controller is not working in Elden Ring Nightreign
When Elden Ring Nightreign does not react to your controller on a Mac, climb this ladder, smallest step first:
- Check that the Mac sees the controller. Open the gamepad tester and press a button. If nothing lights up there, the problem is the connection, and a controller that is connected but not working covers that first.
- Press a button after the stream has started. A stream only picks up a controller that is paired with the Mac, and a browser shows a controller to a page only after a button press. Start Elden Ring Nightreign, then press any button. Streaming from your own PC has its own checks, in how to stream PC games to a Mac with a controller.
- Play it from keys. If Elden Ring Nightreign still ignores the pad, activate this layout. It sends the keyboard and mouse controls Elden Ring Nightreign already reads. Turn the game's own controller option off while it runs, or a press can arrive twice. The layout works whether or not Elden Ring Nightreign ever sees the controller.
- Get InputConfig free on the Mac App Store, open it, and click Smart Preset Maker on the welcome screen.
- Search for Elden Ring Nightreign and pick it. The layout is created as a preset in your sidebar, named and ready.
- Press Activate. Every row can be changed afterwards: the editor's Scan button rebinds any control the moment you touch it.
Elden Ring Nightreign controls: every button and the key it sends
The Sends column is Elden Ring Nightreign's default keyboard and mouse controls, as this layout expects them. If you changed a key in the game's settings, change the same row in InputConfig.
| Controller | Sends | What it does |
| Left stick left | A | Move left |
| Left stick right | D | Move right |
| Left stick up | W | Move forward |
| Left stick down | S | Move back |
| Right stick right | Mouse motion right (speed 18) | Camera right |
| Right stick left | Mouse motion left (speed 18) | Camera left |
| Right stick down | Mouse motion down (speed 14) | Camera down |
| Right stick up | Mouse motion up (speed 14) | Camera up |
| Right trigger | Left click | Right-hand attack |
| Left trigger | Right click | Guard / block |
| A / Cross | Space | Roll / dodge / sprint |
| B / Circle | E | Interact / confirm (E) |
| X / Square | R | Use item (R) |
| Y / Triangle | F | Event / jump action (F) |
| RB / R1 | Q | Skill / weapon art (Q) |
| L3 (left stick click) | V | Crouch (V) |
| R3 (right stick click) | O | Reset camera / lock-on (O) |
| Start / Options | Escape | Menu (Esc) |
Does Elden Ring Nightreign run on a Mac?
Elden Ring Nightreign does not run natively on a Mac. It streams from a Windows PC, or from a cloud service if one carries it, and the stream usually passes a controller through. This layout covers a stream that does not see the pad.
Does Elden Ring Nightreign have controller support?
Yes. Steam lists full controller support for Elden Ring Nightreign, so every part of the game can be played on a controller.
Is Elden Ring Nightreign better with a controller or a keyboard?
Both work. Steam lists full controller support for Elden Ring Nightreign, so it was made to be played on a controller, and a keyboard and mouse work as well.
Why is my controller not working in Elden Ring Nightreign on a Mac?
First check the Mac itself sees the controller, with the gamepad tester. If it does and Elden Ring Nightreign still ignores it, activate the Elden Ring Nightreign layout in InputConfig, which sends the game's keyboard and mouse controls from the controller.
Can I play Elden Ring Nightreign on an M1 Mac or a MacBook Air?
Yes, through a stream. Elden Ring Nightreign runs on the other end, on a cloud service or your own PC, so the Mac only plays the video and sends your input. An M1 MacBook Air streams it like any other Mac.
Does Elden Ring Nightreign run in CrossOver on a Mac?
I have not tested Elden Ring Nightreign in CrossOver. CodeWeavers keeps a compatibility list where players report how each Windows game runs. If it runs and the controller is not seen, this layout plays it from the keys and mouse.
