Death's Door on a Mac with a controller
Download InputConfig on the Mac App StoreThe Death's Door layout is built into InputConfig, free on the Mac App Store. You don't have to make an account, there are no subscriptions, and nothing is locked. Optimized for Apple silicon.
On a Mac: No Mac version. It runs on Apple silicon through CrossOver or the Game Porting Toolkit. The game has native gamepad support, which a wrapper often does not pass.
Yes, Death's Door plays on a Mac with a controller, through a wrapper. A crow with a sword and a fixed camera makes the layout simple: move with the left stick, aim the bow with the right, swing on a trigger, roll on the big button. This layout is the pad for when the wrapper does not pass yours.
  5. Death's Door controller support: controller or keyboard
  6. If your controller is not working in Death's Door
  8. Death's Door controls: every button and the key it sends
  • Move and aim. The left stick moves and the right stick aims the ranged weapon.
  • Fight. The right trigger is the melee attack, the left trigger aims and fires the bow or spell, and the right bumper the charged attack.
  • Dodge and use. Dodge roll and confirm (Space) are the bottom face button, and interact (E) the left.
  • Spells. The top and right face buttons switch to spell 1 and spell 2.
  • Look and menus. The left bumper holds Left Shift to look ahead. D-pad left and right step through menus (Z and X), and Escape is on Options.
Swing on a trigger and roll on the big button, and the crow handles like it does on a pad.
  • Aim speed. Keep it at 16 and try the Smooth curve. The bow wants a calm hand.
  • Turbo. No. The sword has a rhythm.
The Smooth curve keeps small bow adjustments small.
If the game sees the pad on its own, play on its scheme and keep this preset off, because both at once make every press land twice. Roll once with the preset off, and if the crow rolls, you have no need for the layout.
Steam's store page lists full controller support for Death's Door, so the game was made to be played on a controller, menus included. A keyboard and mouse work as well, and the choice is yours. On a Mac, use the game's own controller support first when it sees your pad; this layout is for a pad it does not see, or for buttons it will not let you move. Full support listed means the controller is a first-class way to play Death's Door.
When Death's Door does not react to your controller on a Mac, climb this ladder, smallest step first:
  2. Expect less inside a wrapper. In CrossOver or the Game Porting Toolkit, Wine passes a controller to Death's Door only some of the time, and the keyboard and mouse get through every time. Using a controller with CrossOver games has the checks.
  3. Play it from keys. If Death's Door still ignores the pad, activate this layout. It sends the keyboard and mouse controls Death's Door already reads. Turn the game's own controller option off while it runs, or a press can arrive twice. The layout works whether or not Death's Door ever sees the controller.
  2. Search for Death's Door and pick it. The layout is created as a preset in your sidebar, named and ready.
The Sends column is Death's Door's default keyboard and mouse controls, as this layout expects them. If you changed a key in the game's settings, change the same row in InputConfig.
The Death's Door preset in InputConfig, drawn on a DualSense Edge with each control labeled with the key or action it sends.
Figure 1. The Death's Door preset drawn on a DualSense Edge in InputConfig's Live Visualizer. For example, Right trigger is labeled Melee attack (left click / V), and RB / R1 is labeled Charged attack (middle click / B). Any other controller shows the same layout on its own drawing.
Left stick upWMove up (W)
Left stick downSMove down (S)
Right stick leftMouse motion left (speed 20)Aim ranged left
Right stick rightMouse motion right (speed 20)Aim ranged right
Right stick upMouse motion up (speed 14)Aim ranged up
Right stick downMouse motion down (speed 14)Aim ranged down
Right triggerLeft clickMelee attack (left click / V)
Left triggerRight clickAim & fire ranged weapon (right click / Q)
RB / R1Middle clickCharged attack (middle click / B)
A / CrossSpaceDodge roll / confirm (Space)
X / SquareEInteract (E)
LB / L1Shift (Left)Look ahead (hold Left Shift)
B / Circle2Switch spell / weapon 2 (2)
Y / Triangle1Switch spell / weapon 1 (1)
D-pad leftZMenu left (Z)
D-pad rightXMenu right (X)
Does Death's Door run on a Mac?
Death's Door does not run natively on a Mac. CrossOver and the Game Porting Toolkit run it. This layout is for wrappers that do not pass the controller.
Does Death's Door have controller support?
Yes. Steam lists full controller support for Death's Door, so every part of the game can be played on a controller.
Is Death's Door better with a controller or a keyboard?
Both work. Steam lists full controller support for Death's Door, so it was made to be played on a controller, and a keyboard and mouse work as well.
Why is my controller not working in Death's Door on a Mac?
First check the Mac itself sees the controller, with the gamepad tester. If it does and Death's Door still ignores it, activate the Death's Door layout in InputConfig, which sends the game's keyboard and mouse controls from the controller.
Can I play Death's Door on an M1 Mac or a MacBook Air?
Death's Door has no Mac version, so it runs through a wrapper such as CrossOver or the Game Porting Toolkit, and how well depends on the Mac's chip and memory. I have not tested it on each Mac.
