Built-in preset
Stick Zones & Gestures preset
Download InputConfig on the Mac App StoreThis preset ships inside InputConfig, free on the Mac App Store. You don't have to make an account, there are no subscriptions, and nothing is locked. Optimized for Apple silicon.
Stick Zones & Gestures is the showcase for the parts of a stick or trigger that can be buttons of their own. The left stick walks with W, A, S and D, and pushed all the way up it also holds Shift to sprint: that Sprint ring shares the stick with the walking rows. The right stick is a four-way menu of rings, one arrow key each. The left trigger has two bands, a half pull for 1 and a full pull for 2. Pull the left stick straight back twice for Escape, or flick it right twice for Tab.
Works with any controller: walk on the left stick, a four-way menu on the right, two pulls on the left trigger, and two gestures
Where it is in the app
Every binding
InputSendsOptionsNote
Left stick upWLeft stick up: W, walk forward
Left stick downSLeft stick down: S, walk back
Left stick leftALeft stick left: A
Left stick rightDLeft stick right: D
Left stick regionShiftAll the way up: Shift to sprint, as well as W (this ring shares the stick)
Right stick regionUpRight stick up ring: Up arrow
Right stick regionRightRight stick right ring: Right arrow
Right stick regionDownRight stick down ring: Down arrow
Right stick regionLeftRight stick left ring: Left arrow
Left trigger band1Left trigger half pulled: 1
Left trigger band2Left trigger pulled all the way: 2
Stick gestureEscapePull the left stick straight back twice: Escape
Stick gestureTabFlick the left stick right twice: Tab (each flick also steps right with D)
13 rows. Button names are the Xbox / PlayStation pair the editor shows; a Switch Pro Controller fires by position. Options are the row settings that differ from the defaults.
Notes
  • The Sprint ring. It covers the outer tenth of the left stick's travel (Inner 90%, Outer 100%) from 60 to 120 degrees, so within 30 degrees of straight up. It shares the stick, so W keeps walking while Shift is held.
  • The right stick menu. Four rings from half way out to the edge, a quarter turn each, centered on up, right, down and left. The right stick has no direction rows, so each ring fires on its own and the middle stays neutral.
  • The trigger bands. Half pull runs from 30% to 70% of the left trigger's travel and Full pull from 70% to 100%, each one a button.
  • The gestures. Stick Gesture rows: two pulls straight back send Escape, two flicks right send Tab. Each flick also takes a step, since the walking rows still read the stick.
  • Make it yours. The regions belong to this preset. Choose Edit regions in a stick row's direction menu, or open the editor's Regions card, to resize them or draw your own; a region can take over its stick, so only it fires there, or share it with the direction rows.
A ring reads how far the stick is pushed as well as which way, so the same push can walk and sprint.
Download
