Built-in preset
Desktop Navigation preset
Download InputConfig on the Mac App StoreThis preset ships inside InputConfig, free on the Mac App Store. You don't have to make an account, there are no subscriptions, and nothing is locked. Optimized for Apple silicon.
Desktop Navigation is the preset most people activate first. It turns any controller into a complete mouse with a few macOS shortcuts attached, and it is the base that the Easy Browse and Office Controller guide presets were built from.
Left stick = cursor, right stick = scroll, face buttons = shortcuts
Where it is in the app
Every binding
InputSendsOptionsNote
Right stick leftScroll leftScroll left
Right stick rightScroll rightScroll right
D-pad upUpUp arrow
D-pad downDownDown arrow
D-pad leftLeftLeft arrow
D-pad rightRightRight arrow
A / CrossLeft clickLeft click
B / CircleCommand ZUndo (Cmd Z)
X / SquareCommand XCut (Cmd X)
Y / TriangleCommand VPaste (Cmd V)
LB / L1Command TabNext app (Cmd Tab)
RB / R1Command Shift TabPrevious app (Cmd Shift Tab)
R3 (right stick click)Command ASelect all (Cmd A)
Back / Share / SelectCommand SpaceSpotlight (Cmd Space)
Start / OptionsReturnReturn
23 rows. Button names are the Xbox / PlayStation pair the editor shows; a Switch Pro Controller fires by position. Options are the row settings that differ from the defaults.
Notes
  • Variable pointer speed. A small push is precise and a full push crosses the screen.
  • Drift at rest. Raise the Deadzone on the four left-stick rows, or use Stick settings on the input device's ⋯ menu to change all four at once.
If the pointer creeps when you let go, the deadzone is the first thing to change.
Download
