Do PowerA controllers work on a Mac?
Not officially. PowerA's own FAQ says its Nintendo Switch controllers are not compatible with Mac OS, and its Xbox controllers are licensed by Microsoft and default to XInput, a mode a Mac does not read from most third-party pads. Some PowerA pads still reach a Mac as plain USB gamepads, and a mapper can put those to work. The quickest way to know which kind you have is to plug it in and look.
What PowerA says comes from its support pages, read on October 7, 2026. I make InputConfig, a free Mac app that maps a controller to keys and mouse and reads plain USB pads that macOS does not list as game controllers. I have not tested a PowerA controller myself.
  1. Know what PowerA says
  2. Check yours in a minute
  3. Know what a Mac can read
  4. Map a pad that is read
  5. Mind the Switch button layout
  6. If nothing reads it
  7. The short version
  • Switch controllers. Not compatible with Mac OS, in PowerA's words. On Windows 10 they can be used, and PowerA does not support that either.
  • Wired and wireless. PowerA's wired Switch controllers must stay plugged in. Its wireless ones work on a cable or wirelessly.
  • Xbox controllers. They are licensed by Microsoft, and they default to XInput.
  • The Gamer HQ app. For Windows 10 and 11 and Xbox consoles. PowerA says it does not work on a Mac.
Nothing on this page is promised by PowerA, so check your own pad before you rely on it.
  1. Plug the controller into the Mac with a cable that carries data.
  2. Open the gamepad tester in a browser and press a button.
  3. If nothing draws, open InputConfig and look in its Devices menu.
  4. Read what it says: listed to tick means readable, and grayed out means it is not, with the reason.
The Devices menu is the fastest way to find out, because it names the reason when a pad cannot be read.
The InputConfig Devices menu with Bluetooth, USB and MIDI headings, a USB gamepad with a checkmark, and a keyboard listed in gray beside its kind.
Figure 1. InputConfig's Devices menu lists what is connected, with a checkmark on each device the app can read.
The popover for the PowerA Xbox Series Controller at the top of InputConfig's sidebar, listing its brand, type, buttons, axes and battery, with Refresh Controllers and Disconnect.
Figure 2. A PowerA Xbox Series Controller the Mac can read. If the sidebar shows this, the pad is fine and you can map it.
  • Wired Switch pads. Several reach a computer as plain USB gamepads. The controller list InputConfig bundles, which comes from a community database, has Mac entries for the PowerA Nintendo Switch Controller, the PowerA Pro Ex and the PowerA Core Plus GameCube-style pad, so their buttons are named and placed correctly.
  • Xbox pads in XInput. Most third-party XInput pads do not present as ordinary USB input devices. macOS does not read them, and a Mac App Store app cannot either. InputConfig lists such a pad grayed out, with the reason.
  • Microsoft's own Xbox pads on a cable. macOS 15 and later reads those over USB. I do not know whether that extends to a PowerA Xbox controller, and I have not tested it.
A plain USB gamepad can be read and mapped, and an XInput-only pad cannot. The controller ID lookup searches the same list by name.
A PowerA pad that InputConfig reads this way is not a game controller as far as macOS is concerned, so games with controller support of their own may ignore it. Mapping gets around that: sticks become WASD and mouse look, and buttons become keys, clicks and macros, in any game or app. Mapped to keys and mouse, the pad works in every game, supported or not. Generic USB gamepads on a Mac covers this kind of pad in more depth.
InputConfig's Live Visualizer with the Desktop Navigation preset and the PowerA Xbox Series Controller connected, its pressed controls lit.
Figure 3. Desktop Navigation on the PowerA pad, with the right trigger pulled to 100 percent. The note under the drawing says which macOS versions read Xbox pads over USB.
A Switch-style pad prints B at the bottom and A on the right, the opposite of an Xbox pad. InputConfig binds by position, so a layout made for an Xbox controller still puts each action under the same thumb. To bind a row to a particular button, press Scan and press it. Go by where a button is, not by the letter printed on it. The Switch Pro Controller on a Mac explains the swapped letters.
If nothing reads it
If the tester shows nothing and the Devices menu grays the pad out, no setting on the Mac will change that. A controller macOS supports with no driver is the reliable fix: a DualSense, an Xbox Wireless Controller over Bluetooth, or a Switch Pro Controller. When a pad cannot be read at all, the answer is a different pad, not a driver. What controllers work with a Mac lists the ones that need no setup.
  • PowerA's word. Switch controllers are not compatible with Mac OS, and Xbox ones default to XInput.
  • In practice. Some wired Switch-style pads arrive as plain USB gamepads and can be mapped.
  • The test. Open a gamepad tester first, then InputConfig's Devices menu.
I would just plug it in and look, because one minute of that tells you more than any compatibility list.
Are PowerA controllers compatible with Mac?
PowerA says its Nintendo Switch controllers are not compatible with Mac OS, and its Xbox controllers default to XInput, which a Mac does not read from most third-party pads. Some wired PowerA Switch pads still arrive as plain USB gamepads that a mapper can read.
Does a PowerA Xbox controller work on a Mac?
PowerA's Xbox controllers default to XInput. macOS 15 and later reads Microsoft's own Xbox controllers over USB, and I do not know whether that extends to a PowerA one. InputConfig's Devices menu shows whether yours can be read.
Does a PowerA Switch controller work on a Mac?
Not according to PowerA. In practice some wired models reach a Mac as plain USB gamepads, and InputConfig has Mac entries for a few of them. Plug yours in and check a gamepad tester.
Is there a PowerA app for Mac?
No. PowerA says its Gamer HQ app is for Windows 10 and 11 and Xbox consoles, and does not work on a Mac.
Can I map a PowerA controller to keyboard keys on a Mac?
Yes, if the Mac can read it. InputConfig maps its buttons and sticks to keys, mouse movement, clicks and macros.
