What is Joystick Doctor for Mac?
Joystick Doctor is a small Mac App Store app that identifies a connected game controller, draws its layout, shows its details and gives advice on connecting it. It costs $0.99, its latest version is 1.0.1 from August 2016, and it needs macOS 10.11 or later. It is a tester. It does not map buttons to keys, so it will not make a controller work in a game that ignores it.
I have not used it, so those facts are from its Mac App Store listing, which I read on October 7, 2026. This site has free testers that run in a browser, and I make InputConfig, a free Mac app that tests a controller and maps it.
Know what Joystick Doctor covers
| Joystick Doctor | |
| Price | $0.99 |
| Latest version | 1.0.1, August 5, 2016 |
| macOS | 10.11 or later |
| Does | Identifies controllers, shows their layout and details, gives connection guidance |
| Does not | Map buttons to keys or the mouse |
Its listing says the developer has not given Apple details of its privacy practices. It answers one question, whether the Mac sees the controller.
Test a controller free, in a browser
- You: Open the gamepad tester in Chrome, Safari, Edge or Firefox, and press a button on the controller.
- The browser: Hands the browser the controller.
- Check: Every button lights, the sticks draw their position, and the triggers show how far they are pressed.
- Stick drift. The stick drift test measures a stick at rest.
- Triggers. The trigger test shows their full travel.
- Vibration. The vibration test runs the motors.
A browser tab is enough to test a controller, so there is nothing to install or buy.
Check what macOS itself sees
Open System Settings and click Game Controllers in the sidebar. A controller macOS supports is listed there, and pressing a button lights it on the picture. A plain USB gamepad or joystick will not appear there, and shows under System Information, USB instead: hold Option, open the Apple menu and choose System Information. Game Controllers lists what macOS supports, and System Information lists everything plugged in. The Mac's built-in controller settings covers that screen.
Test and map in one app
InputConfig's Live Visualizer draws the connected controller and lights each control as you press it, plain USB pads included. The difference from a tester is the next step: every control is also a row you can give a job, a key, a click, pointer movement or a macro. Seeing the press tells you the controller works, and giving that press a job is what makes it useful. The Live Visualizer has the details.
If the controller shows up nowhere
- Wake it. Press a button. Some testers list a controller only after its first press.
- Pair it again. Remove it in System Settings, Bluetooth, put it in pairing mode, and connect it fresh.
- Change the cable. Many USB cables only charge.
- Check the mode. Pads with a mode switch are only readable in some positions.
A controller no tester can see has a connection problem, not a software one. Controller not recognized on a Mac goes through each case.
- Joystick Doctor. It is a $0.99 tester from 2016, and it does no mapping.
- Free tests. Use a browser tester, or System Settings, Game Controllers.
- Test and map. InputConfig does both.
You can test a controller on a Mac for free, and you can map it for free too.
Is Joystick Doctor free?
No. Its Mac App Store listing gives a price of $0.99.
Does Joystick Doctor map controller buttons to keys?
No. It identifies and tests a controller and shows its layout. A mapper such as InputConfig is what turns buttons into keys.
How do I test a controller on a Mac for free?
Open a browser gamepad tester and press a button, or open System Settings, Game Controllers. Both show whether the Mac is receiving the controller.
Does Joystick Doctor work on current macOS?
I have not tested it. Its listing gives macOS 10.11 or later, and its latest version is from August 2016.
What is a free alternative to Joystick Doctor?
The gamepad tester on this site, which runs in a browser, or InputConfig's Live Visualizer, which also lets you map what you test.
