An auto clicker for Cookie Clicker on a Mac
Cookie Clicker is a single-player game, so auto clicking it is your call, and on a Mac the cleanest setup is a click at a fixed point on the big cookie, started and stopped from a control that types nothing. InputConfig, a free app on the Mac App Store, does that with one row of its built-in Auto Clicker preset. It works the same in the browser version and in the Steam version, which lists macOS 11 or later.
  1. Steps
  2. Put the clicks on the big cookie
  3. Pick a pace and a length
  4. Catch golden cookies yourself
  5. Choose a trigger that types nothing
  6. Use the same setup for other idle games
  7. If the cookie does not count the clicks
  8. What it cannot do
  9. The short version
  10. Questions
  1. Install InputConfig from the Mac App Store and allow Accessibility access.
  2. Open Cookie Clicker in your browser or from Steam, and leave its window where it is.
  3. Right-click the built-in Auto Clicker preset, choose Duplicate, and open the copy with Edit.
  4. On the fn F6 row, choose At a fixed point: the pointer's position in a few seconds, then rest the pointer on the big cookie.
  5. Set Stop after if you want the run to end by itself.
  6. Close the editor, activate the copy, and press fn F6 to start and again to stop.
A fixed point keeps every click on the cookie, even if the mouse gets nudged during a long run.
  • You: On the fn F6 row of your copy, open the menu beside the click, which reads at pointer, and choose At a fixed point: the pointer's position in a few seconds. Move the pointer to the middle of the big cookie within three seconds, or ten with Switch Control on.
  • InputConfig: Takes the position when the countdown ends. From then on the pointer jumps to the cookie before every click.
  • Check: The menu reads at x, y. Close the editor, activate the copy, press fn F6, and the cookie count climbs.
The menu beside a click output in the InputConfig editor, open on Where the pointer is and At a fixed point: the pointer's position in a few seconds.
Figure 1. Pick the second item and rest the pointer on the cookie. Three seconds later, or ten with Switch Control on, the row reads at x, y.
The point belongs to the screen, not the window. If you move or resize the game window, capture the point again. During a run the pointer keeps returning to the cookie, so stop the run before you use the mouse. Capture the point once, and every click lands on the cookie until you move the window.
The fn F6 row clicks 10 times a second, and holding the right bumper on a controller clicks 20 a second while held. For the big cookie, 10 to 20 a second is plenty. That is a choice, not a measured limit: very fast clicks may not all count, and I have not tested where Cookie Clicker stops counting.
For a run with a set length, use Stop after in the row's Options. The run takes the count times the gap:
EveryStop afterRun length
100 ms600 presses1 minute
100 ms6,000 presses10 minutes
50 ms12,000 presses10 minutes
The CPS calculator does this sum for any pace. One limit to know: InputConfig sends at most one click per poll, 120 a second on a power adapter and 60 on battery by default, so a 10 ms row on battery runs at about 60 a second.
Golden cookies appear at random spots and vanish, and a fixed point only ever clicks the big cookie. When one shows up, press fn F6 to pause the run, click it, and press fn F6 again. If you would rather keep both hands free, the game has its own auto clicker: the Cursor, the first building in the store. The auto clicker handles the cookie, and the golden ones are still yours to catch.
InputConfig listens to the keyboard and does not block or remap the key itself, so a start key still does its normal job in the browser too. Every keyboard reports as one synthetic device id. If fn F6 does something in your browser, such as moving focus away from the page, pick another trigger:
  • A mouse side button. Tick Block the button's own action on its row, and it stops also going Back a page.
  • F13 to F19. On a full-size keyboard, nothing uses them. See auto clicker hotkeys on a Mac.
  • A controller button. The preset's right trigger starts and stops left clicks and buzzes on pads that vibrate.
The recipe carries over to most clicker and idle games, in a browser or on Steam:
  • One target. A fixed point on the thing you click.
  • A length. Stop after, so the run ends while you are away.
  • Two targets. Two rows, each with its own fixed point and its own trigger. There is no recorded sequence that visits several spots in turn.
  • The rules. Offline idle games are your call. An online one with leaderboards or trading may forbid it, so read its rules.
For a browser game that you would rather play with a controller, see browser games with a controller.
  1. Grant Accessibility. System Settings, Privacy & Security, Accessibility, with InputConfig switched on.
  2. Hold fn. On a MacBook, F6 alone is the Focus key, which never reaches an app.
  3. Check the point. If the pointer lands beside the cookie, the window moved since you captured it. Capture it again.
  4. Keep the game in view. Clicks go to whatever is at the point, so another window over the cookie gets them instead.
  5. Slow down. Try Every at 100 ms if a faster pace seems to count less.
What it cannot do
  • See the screen. It cannot spot a golden cookie or a buff and react to it.
  • Buy upgrades. It clicks one point per row. Shopping is up to you.
  • Follow a moving window. The fixed point stays where it was on the screen.
  • Where. A fixed point on the big cookie.
  • How fast. 10 to 20 a second is plenty.
  • How long. Stop after, or fn F6 again.
It takes one row, one point and one key, and the cookie does the rest.
The auto clicker guide walks through the fixed point, Stop after and the emergency stop in order.
Is it cheating to use an auto clicker in Cookie Clicker?
Cookie Clicker is single-player, so whether to auto click is your call. It affects only your own game.
How fast should an auto clicker click in Cookie Clicker?
10 to 20 clicks a second is plenty for the big cookie. That is a choice, not a measured limit. Very fast clicks may not all count.
Does it work with Cookie Clicker on Steam for Mac?
Yes. The Steam version lists macOS 11 or later, and InputConfig clicks it the same way as the browser version, at the pointer or at a fixed point.
Can an auto clicker click golden cookies?
Not a fixed-point one: golden cookies appear at random spots, and InputConfig clicks only where the pointer is or at the point you set. Pause the run, click the golden cookie, and start again.
How do I make the auto clicker click the same spot?
In InputConfig, open the menu beside the click output, choose At a fixed point: the pointer's position in a few seconds, and rest the pointer on the spot. The position is taken three seconds later, or ten with Switch Control on.
