Unreal Engine from a game controller
Download InputConfig on the Mac App StoreThe Unreal Engine 5 layout is built into InputConfig, free on the Mac App Store. You don't have to make an account, there are no subscriptions, and nothing is locked. Optimized for Apple silicon.
On a Mac: The Unreal Editor reads its default shortcuts and mouse buttons from this layout. Your game's own controller input is separate and keeps working.
Yes, you can fly the Unreal Engine 5 viewport on a Mac with a game controller. Unreal flies with the right mouse button held, which suits a held trigger and a stick, the gizmos are Q, W, E and R on the face buttons, and Play in Editor is one button. That matters most when you are testing a controller game with the same controller.
On this page: 7 sections
  3. If your game reads the pad too
  4. Tune it for the viewport
  5. Get it in two clicks
  6. Every binding, as a table
  7. Questions
  • Look. Hold the left trigger and it holds the right mouse button, so the right stick turns the view left and right. Right stick up and down scroll, which zooms.
  • Point and select. The left stick moves the pointer and the right trigger selects.
  • Pick a gizmo. Select, Translate, Rotate and Scale (Q, W, E, R) on the face buttons.
  • Frame and pan. Focus selected (F) on the left bumper, game view (G) on the right, and the left stick click is the middle mouse button for panning.
  • Save and play. Save on Share or View, Play in Editor (Option P) on Options.
Unreal's fly keys work here too: while the right mouse button is held, W moves forward, Q down and E up, and those are on the face buttons. Hold the left trigger and the face buttons fly the camera.
Your game's own controller input is separate and keeps working, so with this preset running, one press can reach the editor and the game at once. Climb this ladder, smallest step first:
  1. List the editor for auto-switch. Add it under Activate when these apps are in front and turn on automatic switching in Settings, Advanced. When the game's own window is in front, the preset steps aside.
  2. Play in a new window. In-editor play shares the editor window, so the preset stays on. Play in a standalone window if your game reads the controller itself.
  3. Stop play from the pad. Escape on the right stick click.
Unreal does not read controllers for editor navigation by default, which is why the layout drives the editor with mouse and key events. A running preset doubles every press in a game that reads the pad, so test in a standalone window.
  • Fly speed. Scrolling while the right mouse button is held changes camera speed, so hold the left trigger and push the right stick up or down.
  • A slower pointer. Use the Pointer speed slider on the preset's page, for the Details panel's small fields.
Speed is the one setting you will change while flying. Hold the trigger and roll the right stick to change fly speed mid-flight.
  2. Search for Unreal Engine 5 and pick it. The layout is created as a preset in your sidebar, named and ready.
The Unreal Engine 5 preset in InputConfig, drawn on a DualSense Edge with each control labeled with the key or action it sends.
Figure 1. The Unreal Engine 5 preset drawn on a DualSense Edge in InputConfig's Live Visualizer. For example, Right trigger is labeled Select (left click), and Left trigger is labeled Fly look (hold right mouse). Any other controller shows the same layout on its own drawing.
Right stick rightMouse motion right (speed 18)Look right (hold RT)
Right stick leftMouse motion left (speed 18)Look left (hold RT)
Right stick downScroll downZoom out
Right stick upScroll upZoom in
Left triggerRight clickFly look (hold right mouse)
A / CrossQSelect mode (Q)
B / CircleWTranslate gizmo (W)
X / SquareERotate gizmo (E)
Y / TriangleRScale gizmo (R)
LB / L1FFocus selected (F)
RB / R1GGame view (G)
L3 (left stick click)Middle clickPan (middle mouse)
Back / Share / SelectCommand (Left), SSave (Cmd+S)
Start / OptionsAlt / Option (Left), PPlay in editor (Alt+P)
Will the controller confuse the game I am testing?
The preset sends keys only while active. Use auto-switch so it is on for the editor and off for the running game's window.
Does Unreal support game controllers in the editor viewport?
Not for editor navigation by default. This layout drives the editor with mouse and key events instead.
