Need for Speed Unbound on a Mac with a controller
The Need for Speed Unbound layout is built into InputConfig, free on the Mac App Store. You don't have to make an account, there are no subscriptions, and nothing is locked. Optimized for Apple silicon.
On a Mac: No Mac version. Xbox Cloud Gaming carries it in its US library (checked September 2026) and plays in a browser on the Mac. It also streams from a Windows PC you own. Both normally pass a controller to the game's own scheme. This layout is for streams that do not see the pad.
Yes, Need for Speed Unbound plays on a Mac with a controller, through Xbox Cloud Gaming in a browser or a stream from a Windows PC. Both normally pass your pad to the game. This layout is for a stream that does not, and in an arcade racer where the handbrake is the point, the handbrake is on the big button.
- The layout, control by control
- How the layout thinks
- Tune it
- If the game sees the pad
- Need for Speed Unbound controller support: controller or keyboard
- If your controller is not working in Need for Speed Unbound
- Get it in two clicks
- Need for Speed Unbound controls: every button and the key it sends
- Questions
- Steer and drive. The left stick steers (A and D). The right trigger accelerates (W), the left trigger brakes and reverses (S).
- Face buttons. Handbrake on the bottom (Space), clutch on the right (Shift), horn on the left (H), rewind on the top (R).
- Gears. Shift up on the right bumper (E), down on the left (Q).
- D-pad. The map on up (M), the camera on down (Tab), the assist on right (C).
- Menus. Pause on Back (Escape), confirm on Start (Return).
Rewind sits on the top face button, because everyone crashes.
- Boost. Both stick clicks are empty. Put the boost key on one.
- Steering threshold. The steering rows send keys, and the deadzone is how far you push before a key goes down. Raise it if a light touch turns the car.
Latency on a stream is the only real problem, and Unbound's drifting forgives it. A higher steering deadzone settles a twitchy car.
A stream normally passes your controller to Need for Speed Unbound's own scheme, which reads the triggers in full. Use it whenever it works, with this preset off. Press Activate only if the stream ignores the pad, and never run both, or every press does two things.
The game's own controls give you analog throttle, so this layout is the backup.
Steam's store page lists partial controller support for Need for Speed Unbound: it plays on a controller, but some parts, such as a launcher, text entry or a menu, still expect a keyboard or a mouse. This layout sends keys and mouse movement from the pad, which can cover the parts the game's own support leaves out. With partial support, a layout fills the gaps the game leaves.
When Need for Speed Unbound does not react to your controller on a Mac, climb this ladder, smallest step first:
- Check that the Mac sees the controller. Open the gamepad tester and press a button. If nothing lights up there, the problem is the connection, and a controller that is connected but not working covers that first.
- Press a button after the stream has started. A stream only picks up a controller that is paired with the Mac, and a browser shows a controller to a page only after a button press. Start Need for Speed Unbound, then press any button. Streaming from your own PC has its own checks, in how to stream PC games to a Mac with a controller.
- Play it from keys. If Need for Speed Unbound still ignores the pad, activate this layout. It sends the keyboard and mouse controls Need for Speed Unbound already reads. Turn the game's own controller option off while it runs, or a press can arrive twice. The layout works whether or not Need for Speed Unbound ever sees the controller.
- Get InputConfig free on the Mac App Store, open it, and click Smart Preset Maker on the welcome screen.
- Search for Need for Speed Unbound and pick it. The layout is created as a preset in your sidebar, named and ready.
- Press Activate. Every row can be changed afterwards: the editor's Scan button rebinds any control the moment you touch it.
The Sends column is Need for Speed Unbound's default keyboard and mouse controls, as this layout expects them. If you changed a key in the game's settings, change the same row in InputConfig.
| Controller | Sends | What it does |
| Right trigger | W | RT = accelerate (W) |
| Left trigger | S | LT = brake / reverse (S) |
| Left stick left | A | Left stick left = steer left (A) |
| Left stick right | D | Left stick right = steer right (D) |
| A / Cross | Space | Cross = handbrake / e-brake (Space) |
| RB / R1 | E | R1 = shift up (E) |
| LB / L1 | Q | L1 = shift down (Q) |
| B / Circle | Shift (Left) | Circle = clutch (Left Shift) |
| Y / Triangle | R | Triangle = rewind (R) |
| X / Square | H | Square = horn (H) |
| D-pad down | Tab | D-pad down = change camera (Tab) |
| D-pad right | C | D-pad right = assist (C) |
| D-pad up | M | D-pad up = view map (M) |
| Back / Share / Select | Escape | Back = pause / menu (Esc) |
| Start / Options | Return | Start = activate / confirm (Enter) |
Does Need for Speed Unbound run on a Mac?
Need for Speed Unbound does not run natively on a Mac. Xbox Cloud Gaming carries it in a Mac browser, and it also streams from a Windows PC you own. This layout covers a stream that does not see the pad.
Does Need for Speed Unbound have controller support?
Partly. Steam lists partial controller support for Need for Speed Unbound: it plays on a controller, but some screens still expect a keyboard or mouse.
Is Need for Speed Unbound better with a controller or a keyboard?
A controller works for most of it. Steam lists partial controller support for Need for Speed Unbound, so some screens still expect a keyboard or a mouse, and a layout like this one can put those on the pad.
Why is my controller not working in Need for Speed Unbound on a Mac?
First check the Mac itself sees the controller, with the gamepad tester. If it does and Need for Speed Unbound still ignores it, activate the Need for Speed Unbound layout in InputConfig, which sends the game's keyboard and mouse controls from the controller.
Can I play Need for Speed Unbound on an M1 Mac or a MacBook Air?
Yes, through a stream. Need for Speed Unbound runs on the other end, on a cloud service or your own PC, so the Mac only plays the video and sends your input. An M1 MacBook Air streams it like any other Mac.
Does Need for Speed Unbound run in CrossOver on a Mac?
I have not tested Need for Speed Unbound in CrossOver. CodeWeavers keeps a compatibility list where players report how each Windows game runs. If it runs and the controller is not seen, this layout plays it from the keys and mouse.
