Mortal Shell on a Mac with a controller
Download InputConfig on the Mac App StoreThe Mortal Shell layout is built into InputConfig, free on the Mac App Store. You don't have to make an account, there are no subscriptions, and nothing is locked. Optimized for Apple silicon.
On a Mac: No Mac version. GeForce NOW carries the Steam and Epic releases (checked September 2026), and it also streams from a Windows PC you own. Either one normally passes a controller to the game's own scheme. This layout is for streams that do not see the pad. It starts from the Souls template, so give the harden and parry rows the game's keys.
Yes, Mortal Shell plays on a Mac with a controller, through GeForce NOW or a stream from a Windows PC. Its one idea is harden, which turns you to stone mid-swing and eats a hit, and it is the best idea a Souls-like has had for a stream: it forgives latency by design. This layout is the Souls layout for a stream that misses your pad. Short game, good idea, plays fine from a chair.
  5. Mortal Shell controller support: controller or keyboard
  6. If your controller is not working in Mortal Shell
  8. Mortal Shell controls: every button and the key it sends
  • Right hand. R1 is a left click for the light attack, R2 Shift plus left click for the heavy.
  • Left hand. L1 is a right click, labeled block, and L2 Shift plus right click, labeled parry.
  • Move and look. The left stick walks on W, A, S and D. The right stick moves the mouse at speed 18. Lock on with the left stick click (middle click).
  • Face buttons. Roll and sprint on the bottom (Space), interact on the right (E), the healing item on the top (R), the left sends F.
  • D-pad and menus. The arrow keys, labeled weapon, spell and item swaps. Menu on Start (Escape), inventory on Back (Tab).
Harden goes on the left trigger, once that row has the game's key.
  • Harden and parry. Set the left bumper and left trigger rows' outputs to harden and parry, as the game's controls menu lists them.
  • Harden timing. Press it a hair early on a stream; it lasts.
Harden a little early, and the stream never catches you.
GeForce NOW or a PC stream normally passes your controller to the game's own scheme. Climb this ladder, smallest step first:
If a dodge in Mortal Shell fires twice, the stream and the preset both have the pad.
Steam's store page lists full controller support for Mortal Shell, so the game was made to be played on a controller, menus included. A keyboard and mouse work as well, and the choice is yours. On a Mac, use the game's own controller support first when it sees your pad; this layout is for a pad it does not see, or for buttons it will not let you move. Full support listed means the controller is a first-class way to play Mortal Shell.
When Mortal Shell does not react to your controller on a Mac, climb this ladder, smallest step first:
  2. Press a button after the stream has started. A stream only picks up a controller that is paired with the Mac, and a browser shows a controller to a page only after a button press. Start Mortal Shell, then press any button. Streaming from your own PC has its own checks, in how to stream PC games to a Mac with a controller.
  3. Play it from keys. If Mortal Shell still ignores the pad, activate this layout. It sends the keyboard and mouse controls Mortal Shell already reads. Turn the game's own controller option off while it runs, or a press can arrive twice. The layout works whether or not Mortal Shell ever sees the controller.
  2. Search for Mortal Shell and pick it. The layout is created as a preset in your sidebar, named and ready.
The Sends column is Mortal Shell's default keyboard and mouse controls, as this layout expects them. If you changed a key in the game's settings, change the same row in InputConfig.
The Mortal Shell preset in InputConfig, drawn on a DualSense Edge with each control labeled with the key or action it sends.
Figure 1. The Mortal Shell preset drawn on a DualSense Edge in InputConfig's Live Visualizer. For example, A / Cross is labeled Roll, backstep, sprint, Space, and B / Circle is labeled Interact, pick up, E. Any other controller shows the same layout on its own drawing.
Left stick leftAMove left, A
Left stick upWMove forward, W
Left stick downSMove back, S
Y / TriangleRUse item, heal, R
L3 (left stick click)Middle clickLock on, reset camera, middle click
D-pad upUpSwitch spell, Up
Does Mortal Shell run on a Mac?
Mortal Shell does not run natively on a Mac. GeForce NOW carries the Steam and Epic releases, and it also streams from a Windows PC you own. This layout covers a stream that does not see the pad.
Does Mortal Shell have controller support?
Yes. Steam lists full controller support for Mortal Shell, so every part of the game can be played on a controller.
Is Mortal Shell better with a controller or a keyboard?
Both work. Steam lists full controller support for Mortal Shell, so it was made to be played on a controller, and a keyboard and mouse work as well.
Why is my controller not working in Mortal Shell on a Mac?
First check the Mac itself sees the controller, with the gamepad tester. If it does and Mortal Shell still ignores it, activate the Mortal Shell layout in InputConfig, which sends the game's keyboard and mouse controls from the controller.
Can I play Mortal Shell on an M1 Mac or a MacBook Air?
Yes, through a stream. Mortal Shell runs on the other end, on a cloud service or your own PC, so the Mac only plays the video and sends your input. An M1 MacBook Air streams it like any other Mac.
