Web Browsing preset
This preset ships inside InputConfig, free on the Mac App Store. You don't have to make an account, there are no subscriptions, and nothing is locked. Optimized for Apple silicon.
Web Browsing extends the desktop layout with the shortcuts a browser uses all day: back and forward on the bumpers, previous and next tab on the triggers, new tab on Y, close tab on X, and the address bar on the Back / Share button. The left stick is the pointer, the right stick scrolls, A clicks and B right-clicks. It works in Safari, Chrome, Firefox, and Arc because it sends the shortcuts they share. For a whole couch setup with video and dictation, see couch browsing and media.
Browse, scroll, switch tabs, navigate history
Where it is in the app
Every binding
| Input | Sends | Options | Note |
| Left stick left | Mouse motion left (speed 18) | Pointer left | |
| Left stick right | Mouse motion right (speed 18) | Pointer right | |
| Left stick up | Mouse motion up (speed 18) | Pointer up | |
| Left stick down | Mouse motion down (speed 18) | Pointer down | |
| Right stick left | Scroll left | Scroll left | |
| Right stick right | Scroll right | Scroll right | |
| Right stick up | Scroll up | Scroll up | |
| Right stick down | Scroll down | Scroll down | |
| Left trigger | Command Shift [ | Previous tab (Cmd Shift [) | |
| Right trigger | Command Shift ] | Next tab (Cmd Shift ]) | |
| A / Cross | Left click | Left click | |
| B / Circle | Right click | Right click | |
| X / Square | Command W | Close tab (Cmd W) | |
| Y / Triangle | Command T | New tab (Cmd T) | |
| LB / L1 | Command [ | Back (Cmd [) | |
| RB / R1 | Command ] | Forward (Cmd ]) | |
| Back / Share / Select | Command L | Address bar (Cmd L) | |
| Start / Options | Command Tab | Switch app (Cmd Tab) |
18 rows. Button names are the Xbox / PlayStation pair the editor shows; a Switch Pro Controller fires by position. Options are the row settings that differ from the defaults.
Notes
- Auto-switch. Add the browser to the preset's auto-switch list and the preset activates itself when the browser comes to the front.
- Typing by voice. Put Start Dictation on a spare button to type addresses and searches.
Auto-switch is what makes it feel built in: pick up the pad, bring the browser forward, and it is ready.
Download
- Web Browsing presetMouse, scroll, tabs, and browser shortcuts 11 KB
