Steam Controller (2026) preset
Download on the Mac App StoreThis preset ships inside InputConfig, free on the Mac App Store. You don't have to make an account, there are no subscriptions, and nothing is locked. Optimized for Apple silicon.
This is the built-in preset for Valve's 2026 Steam Controller, on a USB cable, over Bluetooth, or through its Steam Controller Puck (experimental). The right trackpad moves the pointer like a Mac trackpad, and a tap or a press on it clicks. The right trigger clicks and the left trigger right-clicks. The left trackpad and the right stick scroll.
Plug in, pair over Bluetooth, or use the Steam Controller Puck; quit Steam first.
Where it is in the app
It ships in the Feature Showcases folder of the sidebar. Activate it, or press Edit to see every row. The file below is the same preset, inactive and ungrouped.
Every binding
InputSendsOptionsNote
Right stick downScroll downdeadzone 20%Right stick down: scroll down
Right stick upScroll updeadzone 20%Right stick up: scroll up
Touchpad finger 1 swipe downScroll downLeft trackpad down: scroll down
Touchpad finger 1 swipe upScroll upLeft trackpad up: scroll up
Touchpad finger 1 swipe rightMouse motion right (speed 12)Right trackpad: pointer right
Touchpad finger 1 swipe leftMouse motion left (speed 12)Right trackpad: pointer left
Touchpad finger 1 swipe downMouse motion down (speed 12)Right trackpad: pointer down
Touchpad finger 1 swipe upMouse motion up (speed 12)Right trackpad: pointer up
Touchpad two-finger tapLeft clickRight trackpad tap: left click
Paddle 4Left clickRight trackpad press: left click
Right triggerLeft clickRight trigger: left click
Left triggerRight clickLeft trigger: right click
A / CrossReturnA: Return
B / CircleEscapeB: Escape
X / SquareTabX: Tab
Y / TriangleSpaceY: Space
LB / L1Command [Left bumper: Cmd [ (back)
RB / R1Command ]Right bumper: Cmd ] (forward)
ShareShiftL4 (left back button): Shift (held)
Microphone / MuteOptionR4 (right back button): Option (held)
Home / PS / GuideCommand SpaceSteam button: Spotlight (Cmd Space)
21 rows. Button names are the Xbox / PlayStation pair the editor shows; a Switch Pro Controller fires by position. Options are the row settings that differ from the defaults.
Notes
  • Buttons. A is Return, B is Escape, X is Tab and Y is Space. The bumpers send Command [ and Command ] for back and forward, the Steam button opens Spotlight, and the back buttons L4 and R4 hold Shift and Option.
  • Quit Steam first. Steam takes the controller over while it runs.
  • The 2015 controller. The original Steam Controller has its own preset.
Support for this controller is experimental, so close Steam and expect rough edges.
Download
To add one, drop the file on InputConfig's Dock icon, or see importing a preset. It arrives inactive, and any launch target in it is cleared.
