Built-in preset
Steam Controller preset
Download InputConfig on the Mac App StoreThis preset ships inside InputConfig, free on the Mac App Store. You don't have to make an account, there are no subscriptions, and nothing is locked. Optimized for Apple silicon.
This is the layout for Valve's Steam Controller, read directly by the app: the right trackpad is the mouse, the triggers are left and right click, and the face buttons and rear grips carry the keys. It is a comfortable couch layout for a browser or a media app.
Plug in a Steam Controller (wired or wireless dongle); it appears as a virtual slot just past your MFi controllers
Where it is in the app
Every binding
InputSendsOptionsNote
Right stick rightMouse motion right (speed 22)variable sensitivity; Smooth curve; deadzone 12%Right trackpad: pointer right
Right stick leftMouse motion left (speed 22)variable sensitivity; Smooth curve; deadzone 12%Right trackpad: pointer left
Right stick downMouse motion down (speed 18)variable sensitivity; Smooth curve; deadzone 12%Right trackpad: pointer down
Right stick upMouse motion up (speed 18)variable sensitivity; Smooth curve; deadzone 12%Right trackpad: pointer up
Paddle 3Left clickRight trackpad press: left click
Right triggerLeft clickRight trigger: left click
Left triggerRight clickLeft trigger: right click
Y / TriangleCommand [Left bumper: Cmd [ (back)
X / SquareCommand ]Right bumper: Cmd ] (forward)
RT / R2 (digital)ReturnA: Return
RB / R1EscapeB: Escape
LT / L2 (digital)TabX: Tab
LB / L1SpaceY: Space
Microphone / MuteShiftLeft grip: Shift (held)
Left PaddleOptionRight grip: Option (held)
Touchpad pressCommand SpaceSteam button: Spotlight (Cmd Space)
16 rows. Button names are the Xbox / PlayStation pair the editor shows; a Switch Pro Controller fires by position. Options are the row settings that differ from the defaults.
Notes
  • Quit Steam first. Otherwise Steam and InputConfig fight over the controller's lizard mode.
  • Button numbers. The Steam Controller page has the button index table.
Steam has to be closed, every time.
Download
