Media Controller preset
This preset ships inside InputConfig, free on the Mac App Store. You don't have to make an account, there are no subscriptions, and nothing is locked. Optimized for Apple silicon.
Media Controller is for running music and video from a controller, at a desk or across the room. It sends the same media key events a keyboard's media keys produce, so play / pause, next, and previous reach whichever app is playing: Music, Spotify, TV, a YouTube tab. Volume and mute are system functions, so they work everywhere.
Face buttons control playback, D-pad controls volume
Where it is in the app
Every binding
| Input | Sends | Options | Note |
| Left stick left | Previous Track | Previous track | |
| Left stick right | Next Track | Next track | |
| Left stick up | Volume Up | Volume up | |
| Left stick down | Volume Down | Volume down | |
| D-pad up | Volume Up | Volume up | |
| D-pad down | Volume Down | Volume down | |
| D-pad left | Previous Track | Previous track | |
| D-pad right | Next Track | Next track | |
| A / Cross | Play / Pause | Play or pause | |
| B / Circle | Next Track | Next track | |
| X / Square | Previous Track | Previous track | |
| Y / Triangle | Mute / Unmute | Mute | |
| LB / L1 | Volume Down | Volume down | |
| RB / R1 | Volume Up | Volume up | |
| Back / Share / Select | Escape | Escape (leave full screen) |
15 rows. Button names are the Xbox / PlayStation pair the editor shows; a Switch Pro Controller fires by position. Options are the row settings that differ from the defaults.
Notes
- A living-room pair. Run it with Web Browsing on per-app auto-switch, and give it a light bar color so you can see which one is active.
- A volume fader. Change the right trigger's output to System Volume and the level follows the pull.
Media keys reach whichever app is playing, so one preset covers Music, Spotify and a browser tab.
Download
- Media Controller presetPlay, pause, volume, track skip 8 KB
