DualSense touchpad regions and gestures
The DualSense or DualShock 4 touchpad can be carved into regions, and each region is its own input that fires when a finger lands in it. Regions are drawn in the editor, in the controller's Regions section, and they belong to the preset you draw them in. The pad becomes a row of soft buttons: extra keys, hotbar slots, or a tiny keyboard for someone who cannot reach the face buttons. Areas of the screen are a different input, screen regions.
- Open the controller's Regions section in the editor and pick Touchpad.
- Draw rectangles on the pad and name them.
- Add a row with the input type Touchpad Region and pick a region, or press Scan and touch it. Give it an output. Regions carry every option a button does.
Draw regions
- You: In the controller's Regions section, pick Touchpad, then drag on the pad to draw each region and name it in the list. A region's Left, Top, Width and Height fields, in percent, place it by number instead. Then add a row with the input type Touchpad Region and pick a region, or press Scan and touch it.
- InputConfig: Fires the row when a finger lands in the region. Regions carry every option a button does.
- Check: Touch the region and the output fires. The Live Visualizer draws the regions on the pad and fills the one under a finger.
The pad is about 5 by 2.5 cm, so six to eight regions stay easy to hit without looking. Fewer, bigger regions are easier to hit by feel.
Bind a gesture
Touchpad Gesture recognizes a one-finger tap, a two-finger tap and a double tap, all separate from pressing the pad down. As on a Mac trackpad, the second tap of a double tap also fires a one-finger Tap row, so tap-to-click clicks twice and opens a file. Inside a region, a tap fires the region. A double tap also counts as two taps, the way a Mac trackpad works.
Share the pad with pointing
A finger that lands in a region fires it, and a finger that moves drives the motion rows. Keep regions near the edges if the middle is for pointing.
Try a layout
- Two halves. Left half and right half as Page Up and Page Down.
- Three columns. Again, Good and Easy for Anki. See Anki from a controller.
- A strip of five. A hotbar.
- Four corners. Undo, Redo, Copy and Paste.
The Touchpad Zones preset is a working example to start from.
- Draw. Drag on the touchpad in the editor's Regions section.
- Bind. Touchpad Region rows, or Scan and touch the region.
- Combine. Regions at the edges, pointing in the middle.
The touchpad is a whole extra row of buttons under your thumb.
Can regions and mouse motion share the pad?
A finger that lands in a region fires it; a finger that moves drives the motion rows. Keep regions near the edges if the middle is for pointing.
How many regions?
The pad is about 5 by 2.5 cm, so six to eight stay easy to hit without looking.
