Using an iPad as a drawing tablet for a Mac
An iPad can be a drawing tablet for a Mac with Sidecar, built into macOS: it uses the iPad as a second display, and the Apple Pencil draws in Mac apps on that screen. If you own an iPad and a Pencil, you already have a drawing tablet for your Mac. The Pencil is the sure way to draw, and a finger is a maybe, covered below.
What Sidecar does not have is the row of shortcut buttons a drawing tablet has. That is where a game controller in the other hand comes in, through InputConfig, the free Mac app I make.
  1. Steps
  2. Set up Sidecar
  3. Know what works, and what does not
  4. Find out whether you can draw with a finger
  5. Use it with Photoshop, Illustrator, Blender and Krita
  6. Add the shortcut keys with a controller
  7. If the shortcuts do nothing on the iPad screen
  8. Know when a dedicated tablet is the better buy
  9. The short version
  10. Questions
  1. Sign the Mac and iPad in to the same Apple Account, or join them with a USB cable.
  2. In System Settings, Displays, add the iPad as a display.
  3. Drag your art app onto the iPad screen and draw with the Pencil.
  4. For shortcut keys, pick your art app's layout in InputConfig's Smart Preset Maker.
Set up Sidecar
Sidecar needs a Mac and an iPad that support it, both signed in to the same Apple Account, with Bluetooth, Wi-Fi and Handoff turned on, or the two joined by a USB cable.
  • You: In System Settings, Displays, use the add display menu and choose the iPad, or pick it from Screen Mirroring in Control Center.
  • macOS: Extends the desktop onto the iPad.
  • Check: Drag your art app's window onto the iPad screen and draw on it with the Pencil.
A cable is steadier than a wireless connection, and it charges the iPad during a long session.
  • Mac apps, on the iPad screen. The Pencil works in Mac apps that accept a stylus. How much of the Pencil's pressure a brush uses depends on the app, so test your own brushes before a big piece.
  • A sidebar of modifiers. Sidecar puts Command, Option, Control and Shift, Undo, and buttons for the menu bar, the Dock and a keyboard down the edge of the iPad screen.
  • No iPad apps. Sidecar shows Mac apps on the iPad, not the other way round. Procreate is an iPad app and does not run on the Mac this way.
  • No shortcut keys you can feel. The sidebar is on glass. There is nothing to rest a thumb on, which is the gap the next section fills.
Test your own brushes first: pressure support is up to each Mac app.
Apple's Sidecar page, which I read on October 27, 2026, says you can use the Apple Pencil in place of the mouse or trackpad connected to your Mac, and that the sidebar buttons work with a finger or the Pencil. It also says earlier versions of macOS and iPadOS support a limited set of iPad gestures, such as two-finger scrolling and cut, copy, paste and undo, and that iPadOS 27 and macOS 27 greatly expand touch for Mac windows and menus.
That is touch for moving around Mac windows and menus. The page does not promise that a finger paints strokes in a drawing app, and I have not tested it, so try a few strokes in your own app before you plan around it. The Pencil is the safe answer for drawing, and the finger is worth a test.
Sidecar shows whatever Mac app is on the iPad screen, so these four work the same way: open the app on the Mac and drag its window to the iPad. What differs is how much of the Pencil each one reads. Pressure and tilt depend on the app and its brush settings, and I have not tested all four, so try a brush before a big piece.
  • Photoshop. The Smart Preset Maker has a ready Photoshop layout for the shortcut keys.
  • Krita. It has a ready layout too, with the brush, the eraser toggle, undo and redo, brush size and the color picker. The Krita layout shows it.
  • Illustrator and Blender. Both use their own shortcut keys, so check them against the rows and change the rows to match.
Whatever the app, the keys go to the Mac app in front.
A drawing tablet's ExpressKeys are a handful of shortcuts under the off hand. A game controller is that, with more buttons and two sticks. InputConfig sends the keys to the Mac, and the Mac app on the iPad screen gets them, the same as if you pressed them on the keyboard.
  • Brush and eraser. B and E on two face buttons.
  • Brush size. The bracket keys on the bumpers. Turn on turbo or Repeat keys while held so holding a bumper keeps resizing.
  • Undo and redo. Command Z and Command Shift Z.
  • Held modifiers. Option on a trigger for the eyedropper in Photoshop and most painting apps, Space on the other for the hand tool. A plain row holds its key for as long as you hold the trigger.
  • Zoom. Command Plus and Command Minus on the D-pad.
The Krita layout in InputConfig: brush, eraser, undo and redo on the face buttons, brush size on the bumpers.
Figure 1. The shortcut keys a drawing tablet has, on a controller in the other hand.
Ready decks for Photoshop, Krita, Clip Studio Paint, Affinity and the rest are in the Smart Preset Maker, and the drawing and photo editing guide explains the layout. A single Joy-Con held sideways is small enough to rest beside the iPad.
  1. Click the art app. Keys go to the Mac app in front, and that app is what Sidecar shows on the iPad.
  2. Activate the preset. Rows only work while it runs.
  3. Check the app's keys. If your art app uses different shortcuts, change the rows to match.
InputConfig runs on the Mac and sends keys to Mac apps, never to an iPad app.
A pen display or a screenless tablet plugs in, has its own driver and keys, and has no wireless display in between. If you draw every day and do not already own an iPad and a Pencil, a dedicated tablet is less fuss. If you do own them, Sidecar plus a controller costs nothing extra, and the controller keeps working with a tablet later.
  • The tablet. Use Sidecar, with the art app's window on the iPad.
  • The keys. Hold a controller in your off hand, with a layout from the Smart Preset Maker.
  • The limit. Mac apps only. Procreate stays on the iPad.
An iPad you already own and a controller you already own make a full drawing setup.
Can I use Procreate on my Mac with Sidecar?
No. Sidecar shows Mac apps on the iPad. Procreate is an iPad app. On the Mac, use a Mac painting app such as Krita, Photoshop, Affinity or Clip Studio Paint.
Does Apple Pencil pressure work in Sidecar?
The Pencil works in Mac apps that accept a stylus, and how much pressure a brush uses depends on the app. Test your own brushes.
Can I draw on a Mac with my finger on an iPad?
Maybe. Apple's Sidecar page says the sidebar works with a finger or the Pencil and that touch for Mac windows and menus is greatly expanded in iPadOS 27 and macOS 27, but it does not promise finger strokes in a drawing app. I have not tested it, so try your app.
Can I use an iPad as a drawing tablet for a Mac without Sidecar?
Third-party apps such as Astropad and Duet Display also turn an iPad into a Mac display. I have not tested them and they have their own requirements, so check each maker's page before you buy.
Can I use an iPad as a drawing tablet on a Mac mini or iMac?
Yes, if the Mac is on Apple's Sidecar list, which includes desktop models such as iMacs. Check your own model in Apple's Sidecar article.
Can InputConfig send keys to an iPad app?
No. It runs on the Mac and sends keys to Mac apps. The keys go to the Mac app in front, which is what Sidecar shows on the iPad.
