Use a QuadStick on a Mac
Yes. QuadStick says its controllers connect directly to Mac computers, and a QuadStick can act as a mouse, a keyboard or a game controller. As a mouse and keyboard it works on a Mac with no app. As a game controller, InputConfig, free on the Mac App Store, can turn each sip, puff and joystick direction into any key, click or shortcut. I have not tested a QuadStick myself, so the facts about the hardware here come from QuadStick's own pages.
- Connect the QuadStick to the Mac over USB, or Bluetooth with the optional module.
- Use its mouse and keyboard modes directly, or its game controller mode.
- In game controller mode, open InputConfig and check it in the Live Visualizer.
- Make a row per sip, puff or direction with Scan.
- Choose the key, click or shortcut for each.
Know which QuadStick you have
- QuadStick FPS. It has a joystick, four sip and puff sensors and a lip position sensor. Each one can send a game controller button or axis, a mouse movement or button, or a keyboard key.
- QuadStick Original. It has the same sensors and the same software as the FPS, with a less expensive joystick.
- QuadStick Singleton. It has a joystick and a single sip and puff sensor. QuadStick describes it as the lower cost choice for running a personal computer when you do not need a full game controller.
All three connect to a Mac over USB. QuadStick also sells a Bluetooth module as an option, and says it connects to Macs as a gamepad or as a mouse and keyboard. A QuadStick needs a mounting arm to hold it in front of you, and that is sold separately.
Pick the mode that fits
- Mouse and keyboard. The QuadStick sends pointer movement, clicks and keys itself, which a Mac reads like any mouse and keyboard.
- Game controller. The QuadStick appears as a gamepad. Games that read a controller can use it, and InputConfig can give each input any job on the Mac.
The QuadStick's own configuration decides what each sip, puff and lip position sends. Use its mouse mode for the desktop, and its controller mode with InputConfig when you want a sip or a puff to run a shortcut.
Map it in InputConfig
- You: Put the QuadStick in game controller mode, open InputConfig, make a row, click Scan and sip, puff or move the joystick.
- InputConfig: Fills the input with what the QuadStick sent, and sends your chosen output each time.
- Check: Watch the Live Visualizer, which shows each input as it arrives.
A row can also fire a different action when held, on a double press or on a triple press, so one sip can do four jobs. Hold and double-tap actions explains it.
Know the limits
- I have not tested a QuadStick. The models and modes above are what QuadStick describes on its own site.
- What each sip sends is set on the QuadStick. Its own configuration decides whether a sip is a mouse click, a key or a controller button. InputConfig takes over from there, in game controller mode.
- Its settings program is for Windows. The QuadStick Manager Program, which adjusts sensitivity and the sip and puff thresholds, runs on Windows. Those are easiest to change on a Windows computer, or with QuadStick's help.
- Bluetooth is an option. It is a module you choose when ordering, and QuadStick's shop sometimes lists it as sold out.
- Desktop. The QuadStick's own mouse and keyboard modes.
- Shortcuts and more. Game controller mode with InputConfig.
For other adaptive hardware, adaptive controllers on a Mac covers the PlayStation Access Controller, the Xbox Adaptive Controller and switches.
Does the QuadStick work with a Mac?
Yes. QuadStick says its controllers connect directly to Mac computers over USB, and its optional Bluetooth module connects to Macs too. A QuadStick can act as a mouse, a keyboard or a game controller.
Can a sip and puff controller run keyboard shortcuts on a Mac?
Yes. In game controller mode, InputConfig can give each sip, puff or direction any key, click or shortcut.
What is the difference between the QuadStick FPS, Original and Singleton?
The FPS and the Original both have a joystick, four sip and puff sensors and a lip position sensor, and the FPS has the more precise joystick. The Singleton has a joystick and one sip and puff sensor, and is meant for running a computer more than for games.
