A free alternative to MurGaa Auto Clicker for Mac
MurGaa sells its Mac auto clicker as a subscription after a free trial. InputConfig does the same job for free, with nothing locked, and its source is public on GitHub. It clicks at the gap you set, a set number of times or until you stop it, where the pointer is or at a fixed spot.
  1. Install InputConfig from the Mac App Store.
  2. Allow it in System Settings, Privacy & Security, Accessibility.
  3. Activate the built-in Auto Clicker preset.
  4. Set the gap, the limit and the spot in the row's Options.
  5. Press fn F6 to start and stop.
Set the same options
  • The interval. Every sets the gap between clicks in milliseconds, from 5 ms to a minute.
  • Random timing. Vary by up to adds a random plus or minus to each gap.
  • A number of clicks. Stop after ends the run after that many.
  • A fixed spot. At a fixed point clicks one place on screen, set with a spoken countdown or typed X and Y.
  • The start key. Any key, mouse button or controller button you Scan.
Everything the paid app does here is free, and nothing in InputConfig is locked.
A row in InputConfig's editor with its Options open: a click row from the Auto Clicker preset with its interval, random variation and click limit fields.
Figure 1. The same three choices MurGaa gives you: how often, how much to vary it, and when to stop.
Check the price yourself
Reviews list MurGaa's Mac Auto Clicker at a few dollars per six months after its trial, and the sources disagree on the exact figure, so check murgaa.com for today's price. MurGaa also sells a separate recorder, and a macro recorder for Mac covers the free ways to record.
  • MurGaa. A subscription after a trial.
  • InputConfig. Free, open source, with the same options.
The full setup is on the free auto clicker for Mac page.
Is MurGaa Auto Clicker free on Mac?
It has a free trial, then a subscription. InputConfig is a free alternative with an interval, a click limit, random timing and a fixed spot.
What is a free auto clicker for Mac like MurGaa?
InputConfig, on the Mac App Store. Its built-in Auto Clicker preset starts with fn F6, and the source is on GitHub.
