GS Auto Clicker for Mac
There is no Mac version of GS Auto Clicker. It is a free Windows app, and a download that claims to be GS Auto Clicker for Mac is not the real one. The same job on a Mac, clicks on a timer with a hotkey to start and stop, is free in InputConfig on the Mac App Store, with a built-in Auto Clicker preset.
  1. Install InputConfig from the Mac App Store.
  2. Allow it in System Settings, Privacy & Security, Accessibility.
  3. Activate the built-in Auto Clicker preset.
  4. Press fn F6 to start clicking and again to stop.
  5. Change the gap in the row's Options to match your GS settings.
Match your GS Auto Clicker settings
In GS Auto ClickerIn InputConfig
Click intervalEvery, the gap in milliseconds, from 5 ms to a minute
Mouse button and single or double clickThe Mouse Button output's button menu for left, right or middle. Every click in a run is a single click, and Repeat 2 on a Fires while held row sends a real double click.
Repeat a number of timesStop after
Click at a fixed spotAt a fixed point, set by a countdown or typed X and Y
Hotkey to start and stopAny key, mouse button or controller button, set with Scan
The CPS calculator turns clicks per second into the gap in milliseconds.
The Auto Clicker preset in the InputConfig editor, showing its keyboard and mouse rows: fn F6 auto click 10 a second on and off, fn F7 auto right click 5 a second on and off, and mouse button 4 auto click 15 a second while held.
Figure 1. InputConfig's built-in Auto Clicker preset: fn F6 starts and stops a left click 10 times a second.
A row in InputConfig's editor with its Options open: fn F7 as the input and a right click as the output, repeating every 200 ms.
Figure 2. GS Auto Clicker's choices map to this box. The fn F7 row right-clicks five times a second until you press it again.
Start the built-in Auto Clicker
  • You: Activate the Auto Clicker preset and press fn F6.
  • InputConfig: Clicks where the pointer is until you press fn F6 again.
  • Check: The CPS test shows the real rate.
The emergency stop, Control Option Command period, ends any clicking at once.
Avoid a fake GS Auto Clicker for Mac
Sites that offer GS Auto Clicker for Mac are offering something else under its name. An auto clicker needs Accessibility access, which lets it click and type anywhere. Is an auto clicker safe on a Mac has the checks I would run first.
  • GS Auto Clicker. Windows only.
  • On a Mac. InputConfig's Auto Clicker preset, free, started with fn F6.
  • Other options. Mac auto clickers compared lists the rest.
Is GS Auto Clicker available for Mac?
No. GS Auto Clicker is a Windows app. On a Mac, InputConfig does the same job for free, with a built-in Auto Clicker preset.
What is the Mac equivalent of GS Auto Clicker?
A free auto clicker such as InputConfig, on the Mac App Store, with an interval in milliseconds, a click limit, a fixed spot, and a hotkey to start and stop.
