What is MIDI velocity?
Velocity is the number a MIDI note carries to say how hard the key or pad was hit, from 1 to 127. A soft touch sends a low number and a hard strike sends a high one. The instrument decides what that means, and it is usually loudness and brightness together. Velocity 0 is a special case: a Note On with velocity 0 means note off.
I make InputConfig, a free Mac app that reads and sends MIDI notes, and the last section says how velocity works with buttons, which cannot feel how hard they are pressed.
  1. Steps
  2. See where velocity sits in a note
  3. Know why velocity 0 is a note off
  4. Learn what release velocity is
  5. Know what the instrument does with it
  6. Test a keyboard's velocity
  7. Pick a velocity curve
  8. Use velocity with buttons
  9. The short version
  10. Questions
  1. Open a MIDI tester, press Start listening and play one key softly, then hard.
  2. Read the lowest and highest velocity it reached.
  3. If hard playing never gets near 127, or soft playing is already loud, change the velocity curve on the keyboard.
  4. If one key stands out, that key's sensor is worn or dirty.
ByteValueMeaning
Status0x90 to 0x9FNote On, channel 1 to 16
Note number0 to 127Which note
Velocity1 to 127How hard. 0 means note off
Velocity is the third byte of every Note On, so each note carries its own. The MIDI note number chart covers the second byte.
MIDI has a Note Off message, and it also treats a Note On with velocity 0 as a note off. Many keyboards send the second kind, because a run of messages of one type can be sent more compactly. A monitor may show either, and both end the note. A Note On with velocity 0 is not a very quiet note, it is the end of one.
A Note Off message has a velocity byte of its own, called release velocity. It says how fast the key was let go, from 0 to 127.
ByteValueMeaning
Status0x80 to 0x8FNote Off, channel 1 to 16
Release velocity0 to 127How fast the key was released
Many keyboards do not measure it and send a fixed value, and many instruments ignore it, so you may never hear it do anything. A few sounds use it to shape how a note dies away. A keyboard that ends notes with a Note On at velocity 0 sends no release velocity at all. Release velocity is real but rare, so do not expect it from a keyboard unless its manual says it sends it.
Velocity is only a number until a sound uses it. A piano sound plays louder and brighter, a drum sample may switch to a harder hit, and an organ sound may ignore it. The same key press can sound different on two instruments that map velocity differently. If everything plays at one loudness, the sound is ignoring velocity, or the keyboard is sending a fixed value.
Open the MIDI tester, play one key as softly as you can and then as hard as you can, and read the velocity range. A healthy key covers most of 1 to 127. A key stuck at one value, or one that never rises past a low number, points to a worn sensor. If every key tops out early, look for a velocity curve setting on the keyboard.
One key that reads differently from its neighbors is a hardware fault, and all keys reading alike is a setting.
A velocity curve is the rule that turns how hard you press into the number that gets sent. Keyboards and many instruments offer a few. The names differ from maker to maker, so these are typical, not exact.
CurveWhat it doesReach for it when
Soft or lightGentle playing reaches high numbers soonerYou play lightly and everything sounds quiet
Normal or linearForce and number rise togetherYou want the default
Hard or heavyYou must press harder to reach high numbersYou play heavily and everything sounds loud
FixedEvery note sends the same numberThe sound ignores velocity, or the keys cannot sense it
Change the curve on the keyboard first, because that fixes the number at the source. Many DAWs can reshape velocity again after it arrives, so two curves can fight each other. Change one curve at a time and test again with the MIDI tester.
A game controller button, a computer key and most foot switches are either down or up, so they cannot report how hard they were pressed. In InputConfig, each MIDI Note output plays at the velocity set in its row, from 1 to 127. For dynamics, put expression on a trigger: it sends every value in between, so a trigger on CC 11 swells the sound the way a harder strike would.
Fixed velocity on the buttons and expression on a trigger makes a controller playable. MIDI output has the setup.
InputConfig's Live Visualizer on its MIDI view, showing a knob's CC number and value changing as it turns.
Figure 1. InputConfig's Live Visualizer shows a knob's CC number and value change as it turns.
InputConfig's editor showing three rows playing the same snare note at velocities 40, 90 and 127, and a trigger row whose velocity follows the trigger.
Figure 2. The same note three times, at velocity 40, 90 and 127. A button cannot feel how hard you press it, so each button gets its own fixed velocity.
  • What. How hard a note was played, 1 to 127.
  • Zero. A Note On with velocity 0 ends the note.
  • Release. A Note Off carries its own velocity, which most gear ignores.
  • Curve. A soft or hard curve changes how force maps to the number.
  • Effect. It does whatever the sound maps it to, usually loudness and tone.
Velocity travels with every note, and the instrument gives it meaning.
What is the MIDI velocity range?
1 to 127 for a sounding note, where 127 is the hardest possible strike. A Note On with velocity 0 is treated as a note off.
What is release velocity?
The velocity byte in a Note Off message, from 0 to 127, which says how fast the key was released. Many keyboards do not measure it and many instruments ignore it.
Is MIDI velocity the same as volume?
No. Velocity is a per-note value that the sound usually maps to loudness and tone. Volume is CC 7, which turns a whole channel up and down.
How do I test MIDI velocity?
Play a key softly and then hard in a MIDI tester and read the lowest and highest velocity. A healthy key covers most of the range from 1 to 127.
Why does my keyboard always send the same velocity?
It has no velocity-sensing keys, or it is set to a fixed velocity. Look for a velocity curve or fixed velocity setting in the keyboard's own menu.
Why is my MIDI keyboard so quiet?
A light touch sends low velocity numbers, and most instruments play those quietly. Look for a velocity curve or touch sensitivity setting on the keyboard, or raise the instrument's volume. A MIDI tester shows the numbers your playing sends.
