What are MIDI channels?
A MIDI connection carries 16 channels, numbered 1 to 16. Every note, knob movement and program change is tagged with one of them, and a receiving instrument answers only the channels it is set to hear. That is how one cable can play sixteen different parts. In General MIDI, channel 10 is reserved for drums.
I make InputConfig, a free Mac app that maps MIDI to shortcuts and sends MIDI from game controllers, so the last section says how channels behave there.
  1. Steps
  2. See where the channel sits in a message
  3. Match the sender and the receiver
  4. Know why channel 10 is drums
  5. Know what does not have a channel
  6. Use more than sixteen
  7. Set channels in InputConfig
  8. The short version
  1. Find the channel your keyboard or pad sends on, in its settings or with a MIDI monitor.
  2. Set the receiving instrument or track to the same channel, or to all channels.
  3. For drums on a General MIDI device, send on channel 10.
The channel is part of the first byte of a message. The first half of that byte says what kind of message it is, and the second half is the channel, written 0 to 15 for channels 1 to 16.
First byteMessageChannel
0x90Note On1
0x99Note On10
0xB0Control Change1
0xCFProgram Change16
Channel 1 is 0 inside the message, so the channel on the wire is always one less than the channel on the screen.
InputConfig's Live Visualizer on its MIDI view, showing a knob's CC number and value changing as it turns.
Figure 1. InputConfig's Live Visualizer shows a knob's CC number and value change as it turns.
  • Same channel. The instrument plays.
  • Different channels. The instrument ignores the notes. This is the most common reason a connected keyboard is silent.
  • Receiver set to all channels. Often called omni. It plays whatever arrives.
When a keyboard is connected and nothing sounds, compare the two channel numbers first. The MIDI tester shows the channel of every message a device sends.
General MIDI sets channel 10 aside for percussion. On that channel a note number picks a drum, not a pitch: 36 is the kick, 38 the snare, 42 the closed hi-hat. On the other fifteen channels the same numbers play notes. A drum pad that plays pitched notes on a General MIDI device is sending on the wrong channel. The General MIDI drum map lists every drum.
Timing and transport messages belong to the whole connection, not to a channel: MIDI clock, Start, Continue and Stop. So does System Exclusive data. A device set to channel 5 still follows the clock.
Notes, knobs, bends and program changes have channels, and clock and transport do not.
Sixteen is the limit of one MIDI port. A second port is a second set of sixteen, which is why interfaces and music apps offer several ports. Some expressive controllers use the channels differently and send each held note on a channel of its own, so every finger can bend separately. More than sixteen parts means more than one port, not a seventeenth channel.
  • MIDI coming in. A row made with Scan keeps the channel it was scanned on. Choose Any channel for a controller that plays each note on its own channel.
  • Splitting a keyboard. Pick a channel on a row to give one zone of a keyboard its own shortcuts.
  • MIDI going out. Each MIDI output on a row has its own channel, so one controller can play drums on channel 10 and a synth on channel 1.
If a pad lights in the Live Visualizer and its row does nothing, the row's channel does not match the pad's. MIDI to keystroke on a Mac has the filters.
InputConfig's editor showing note rows on channels 1, 2 and 10, with the channel field at the end of each row.
Figure 2. The channel is the last field on each row. Piano on 1, strings on 2 and two drums on 10, all from one controller.
  • How many. There are sixteen in one port.
  • What for. They carry sixteen parts over one connection, with each instrument hearing its own.
  • Channel 10. It is the drum channel in General MIDI.
Sender and receiver on the same channel, and the notes arrive.
How many MIDI channels are there?
Sixteen in each MIDI port, numbered 1 to 16. Inside a message they are written 0 to 15.
What is MIDI channel 10 used for?
Drums and percussion, in General MIDI. On channel 10 each note number is a different drum, not a pitch.
Why does my MIDI keyboard make no sound?
Often the keyboard sends on one channel and the instrument listens to another. Set both to the same channel, or set the instrument to receive all channels.
What is omni mode?
A receiving mode where an instrument responds to messages on every channel, whatever channel they were sent on.
Does MIDI clock have a channel?
No. Clock, Start, Continue and Stop are sent to the whole connection, so every device on it follows them whatever its channel.
