Does Safari support Web MIDI?
No. Safari does not support the Web MIDI API, on the Mac or on iPhone and iPad, so a web page in Safari cannot see a MIDI keyboard. On a Mac, use Chrome, Edge or Opera, which have supported it for years, or Firefox, which supports it from version 108 and asks before a site may use it. The device itself is fine: the limit is the browser.
The support list comes from MDN's browser compatibility data, read on October 7, 2026. Outside the browser, InputConfig, the free Mac app I make, reads MIDI devices through macOS itself and turns notes, knobs and pedals into shortcuts.
  1. Know which browsers have it
  2. Allow MIDI in Chrome or Edge
  3. Allow MIDI in Firefox
  4. Test that it works
  5. Know what to do on an iPhone or iPad
  6. Use MIDI without a browser
  7. The short version
BrowserWeb MIDINote
ChromeYes, since version 43Asks for permission the first time a site uses MIDI
EdgeYesSame engine as Chrome
OperaYesSame engine as Chrome
FirefoxYes, since version 108Asks to add a site permission before a site may use MIDI
Safari on a MacNoNot supported
Safari on iPhone and iPadNoNot supported
On a Mac, any browser except Safari will do.
  1. Open the page that uses MIDI and press its start or connect button.
  2. When the browser asks whether the site may use your MIDI devices, choose Allow.
  3. If you chose Block by mistake, click the icon at the left of the address bar, open the site's settings, and set the MIDI permission to Allow.
  4. Reload the page.
A page that sees no devices has usually been blocked, not broken.
Firefox gates Web MIDI behind what it calls a site permission add-on. The first time a page asks for MIDI, Firefox offers to add the permission for that site, and the page gets access once you accept. In Firefox the prompt is an add-on install, which looks heavier than it is. A page must also be served over a secure connection, which every public site with https is.
Test that it works
  1. Open the MIDI tester in Chrome, Edge or Firefox.
  2. Press Start listening and allow MIDI.
  3. Read the list of devices it is listening to.
  4. Play a key and watch the message appear.
If the tester names your device, Web MIDI is working in that browser. The virtual MIDI keyboard and the virtual MIDI controller use the same permission to send MIDI out.
Safari on iPhone and iPad has no Web MIDI, so web MIDI tools do not see a device there. MIDI itself works on those devices: apps from the App Store use Apple's own MIDI system and see a keyboard connected by USB or Bluetooth. On an iPhone or iPad, use an app, not a web page, for MIDI.
A native Mac app does not depend on any browser. InputConfig, the free Mac app I make, reads MIDI devices through macOS itself and turns notes, knobs and pedals into shortcuts, and its Live Visualizer shows every message as it arrives. If Safari is the browser you keep, a native app covers what the web page cannot. MIDI monitors for Mac compares the options.
InputConfig's Live Visualizer in its MIDI layout, showing a keyboard, named dials and an event log.
Figure 1. InputConfig's Live Visualizer in its MIDI layout, with named dials and an event log of what arrives.
InputConfig's editor showing three MIDI note rows sending the letter keys A, S and D.
Figure 2. A web page that cannot hear MIDI can still hear keys. These rows turn three notes into A, S and D.
  • Safari. It has no Web MIDI, on any Apple device.
  • Chrome, Edge, Opera. They all support it, after you allow it.
  • Firefox. It supports it from version 108, after a site permission prompt.
Open the page in Chrome and the MIDI keyboard appears.
Does Safari support the Web MIDI API?
No. Safari does not support Web MIDI on the Mac, the iPhone or the iPad, according to MDN's browser compatibility data as of October 2026.
Which browsers support Web MIDI on a Mac?
Chrome, Edge and Opera, and Firefox from version 108. Each asks for permission before a site may use MIDI devices.
Why does a web MIDI page not see my keyboard?
Either the browser is Safari, which has no Web MIDI, or the site was blocked from using MIDI. Open the page in Chrome and choose Allow when asked.
Does Firefox support Web MIDI?
Yes, from version 108. It asks you to add a site permission the first time a page requests MIDI.
Does Web MIDI work on an iPhone or iPad?
Not in Safari. Use an app from the App Store, which can use MIDI devices connected by USB or Bluetooth.
Is it safe to allow a site to use MIDI?
A site with MIDI permission can see your MIDI devices and exchange messages with them. Allow it for sites you chose to use, and the permission can be removed in the browser's site settings.
