Blur Auto Clicker for Mac
Blur Auto Clicker is a Windows app, published on GitHub and installed through Windows tools, and I found no Mac version. On a Mac, InputConfig is free and open source too, and it covers the same ground: clicks on a timer, random variation in the timing, a click limit, and a key to start and stop.
  1. Install InputConfig from the Mac App Store.
  2. Allow it in System Settings, Privacy & Security, Accessibility.
  3. Activate the built-in Auto Clicker preset.
  4. Set Every, Vary by up to and Stop after in the row's Options.
  5. Press fn F6 to start and stop.
Match the settings you used
In Blur Auto ClickerIn InputConfig
Click speedEvery, the gap in milliseconds, from 5 ms to a minute
Randomization and speed variationVary by up to, a random plus or minus on each gap
A click limitStop after
Toggle or holdRepeats until pressed again, or Repeats while held
KeybindsAny key, mouse button or controller button, set with Scan
I have not found a match in InputConfig for every Blur option, so check the list above against what you use. The auto clicker test shows the real rate and spread, so you can tune the Mac to what you had.
Open the auto clicker test to measure it.
The Auto Clicker preset in the InputConfig editor, showing its keyboard and mouse rows: fn F6 auto click 10 a second on and off, fn F7 auto right click 5 a second on and off, and mouse button 4 auto click 15 a second while held.
Figure 1. InputConfig's built-in Auto Clicker preset: fn F6 starts and stops a left click 10 times a second.
A row in InputConfig's editor with its Options open: fn F6 as the input, a left click as the output, set to Repeats until pressed again every 100 ms.
Figure 2. The fn F6 row of the built-in Auto Clicker. Every is the click interval, Vary by up to is the random offset, and Stop after is the click limit.
  • Blur Auto Clicker. Windows.
  • On a Mac. InputConfig, free and open source, with random timing and a click limit.
The full setup is on the free auto clicker for Mac page.
Is there a Blur Auto Clicker for macOS?
I found no Mac version. Blur Auto Clicker is published for Windows. InputConfig is a free, open-source Mac auto clicker with random timing and a click limit.
